"Sin City Extended Recut" Incorrect video order
RogueOne
#1 Post by RogueOne » Wed Feb 16, 2011 3:06 pm
Problem regarding this disc: http://www.amazon.com/Two-Disc-Theatric ... 068&sr=8-1
when I rip this disc, the video streams are in incorrect order... I get 3 seperate Movies with End Credits behind all of them, when they should be mixed into each other. Tried with "index.bdmv" and "MovieObject.bdmv", same result, also MakeMKV 1.63 or 1.65 doesn`t make a difference. These are my settings:
Thanks very much for your help, ripped quite many other movies so far and worked perfectly ! :D
Greetings
setarip_old
Re: "Sin City Extended Recut" Incorrect video order
#2 Post by setarip_old » Thu Feb 17, 2011 5:06 am
Hi!
Please clarify - There are THREE different versions of the movie on the two discs - What do you mean by, "They should be mixed into each other?
RogueOne
#3 Post by RogueOne » Thu Feb 17, 2011 6:37 am
Hi, the movie itself consists of 3 different seperate storylines, maybe thats a better word. On the actual Blu-Ray, they are in different order than when you rip them with MakeMkv. Also, the End Credits on the Bluray show only once - but in the rip, they are after each storyline.
setarip_old
#4 Post by setarip_old » Thu Feb 17, 2011 6:53 am
Please post a screen capture of "Disc 1", similar to the screen capture you posted of "Disc 2".
#5 Post by mike admin » Thu Feb 17, 2011 10:00 am
And please send all CLPI and MPLS per http://www.makemkv.com/faq/item/8/catid/6
RogueOne
#6 Post by RogueOne » Thu Feb 17, 2011 1:20 pm
I am so sorry, my mistake... The Bluray was ripped correctly, it was a mixup with the discs. The Disc 2 I ripped actually had the storylines seperately on it...
Sorry again
setarip_old
#7 Post by setarip_old » Thu Feb 17, 2011 6:37 pm
Glad to hear you've resolved your problem - and it had nothing to do with MakeMKV ;>}
