In The Heights UHD Failed to Open Disc
ironeinstein
Post by ironeinstein »
Title says it all: UHD disk failed to open. WH16NS60 using 1.02MK firmware
Dump file attached... thoughts???
MKB20_v76_In_The_Heights_4C46.tgz
(3.34 MiB) Downloaded 393 times
Re: In The Heights UHD Failed to Open Disc
Other than "submitting to svq@makemkv.com is faster than posting on the forum"?
bmillham
Post by bmillham »
I purchased a copy at Walmart today and successfully ripped it.
omk1980
Post by omk1980 »
Still not opening for me. Sent dump file to Mike.
omk1980
Post by omk1980 »
I assume this is a volume key issue due to the error but just want to make sure nothing else is going on bc i do get a debug code as well.
I get this error:
MakeMKV v1.16.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\kolon/MakeMKV_log.txt
Using LibreDrive mode (v06.2 id=6E4B09EE276C)
Backing up disc into folder "H:/Rips/backup/IN_THE_HEIGHTS"
Saved AACS dump file as C:/Users/kolon/Desktop/Files/MakeMKV debug folder/MKB20_v76_IN_THE_HEIGHTS_C57A.tgz
DEBUG: Code 0 at {5RBA^y-#)9OM3ec:29396092
DEBUG: Code 0 at (*:V+7<vBy:Y|eS{=J~:121273342
DEBUG: Code 0 at }}`_u63iz<X&?k/>rv!\:213133457
Backup failed
I saw the guy who picked it up from Walmart, got it to work. But is anyone else having issues ripping this disc?
Movie has been out for over a week and mike usually gets keys out in the first few days. Just wanted to be sure.
omk1980
Post by omk1980 »
Working now. Thanks Mike!
ravedog
Post by ravedog »
omk1980 wrote:
Fri Sep 10, 2021 2:43 pm
So what exactly happened between your posting the problem and "thanks mike"... I have not been able to rip this since it first came out and not sure what to do...
Any ideas?
Debug log started at Sun Sep 12 02:05:17 2021 , written by MakeMKV v1.16.4 darwin(x64-release)
001005:0000 MakeMKV v1.16.4 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/ravedog/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
SDF  v07e: ASUS_BW-16D1HT_3.10_211901041014_KL4K5991951
001011:0000 Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
DEBUG: Code 2147483648 at rhHV->i@V}3]oyDy:121264625
003338:0000 Downloading latest HK to /Volumes/sahara/ scratches/MakeMKV ...
001003:0020 DEBUG: Code 2400288775 at 1CE^z7y\P*zV;k?:29393999
001003:0020 DEBUG: Code 0 at rhHV->i@V}3]oyDy:121267362
003339:0000 Automatic HK downloading is disabled or failed.
003332:0000 Saved AACS dump file as file:///Volumes/sahara/ scratches/MakeMKV/MKB20_v76_In_The_Heights_4C46.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at HE<hEO<!JUR7.k';:29396092
001003:0020 DEBUG: Code 0 at HE<hEO<!JUR7.k';:29395172
Post by d00zah »
ravedog wrote:
Sun Sep 12, 2021 2:15 am
Any ideas?
Fixing Volume Key is Unknown
bellzer
Post by bellzer »
MKB20_v76_In_The_Heights_4C46.tgz which was posted is not the same as your MKB20_v76_IN_THE_HEIGHTS_C57A.tgz file.
Please post your MKB20_v76_IN_THE_HEIGHTS_C57A.tgz file.
Post by d00zah »
bellzer wrote:
Sun Sep 12, 2021 5:05 pm
Posting dumps here accomplishes little. Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
Also, viewtopic.php?p=108809#p108809
Sending the .tgz file to svq@makemkv.com is the right thing to do. Also posting the name of the file you submitted is helpful. Some titles have more than one key. Posting the name of the file you submitted can let people know if they have a different key and should submit their key.
ravedog
Post by ravedog »
dcoke22 wrote:
Sun Sep 12, 2021 11:08 pm
Thanks for the helpful advice...
