staknhalo
#5491 Post by staknhalo » Wed Sep 08, 2021 10:04 pm
Is it possible to remove Dolby Vision from certain scenes/frames only via RPU editing before 'burning' into BL HDR10 hevc stream to make P8 converted file?
Reason I'm asking - I burn forced subs only into the main hevc stream. This way I don't have to worry about for these 'integral parts' the sub format support of what/where I'm watching, subs kicking in or not when they are or are not supposed to, etc etc
When burning them in before making the DV file, the DV overlay gives them a rainbow effect (dunno if discovered before or not, can't be asked to read back 10,000 pages just for that TBH). Burning it in afterwards obviously isn't a choice cause of DV IIRC, correct?
It's not a dealbreaker, nor that distracting TBH, but just wondering if removing the DV from just these scenes/frames/parts via the RPU if possible would giver better overall effect when watching and subs appear on screen (might not also, if I don't remove it from the whole scene/setting for where subs appear might be too distracting seeing the same scene with DV then suddenly without- but have to see first right?)
Obviously sep subs would work but trying to see if way around that for reasons I explained above first (if I even resort to that, like I said it's not too bad really)
RESET_9999 wrote: Wed Sep 08, 2021 9:31 pm
why would you do that now that there's a tool that perfectly converts HDR10+ to true dynamic DV?
You had to manually input (change?) some info into the json, right? Or was the entire thing fully automated? I have some HDR10+ only titles that I could make DV versions for. Shaun of the Dead and American Gangster off the top of my head.
#5492 Post by RESET_9999 » Wed Sep 08, 2021 11:06 pm
staknhalo wrote: Wed Sep 08, 2021 10:04 pm You had to manually input (change?) some info into the json, right? Or was the entire thing fully automated? I have some HDR10+ only titles that I could make DV versions for. Shaun of the Dead and American Gangster off the top of my head.
yes, everything is pretty much automated. I just adjust the l5 active area and the l6 metadata but I don't think it really matters so you could probably just ignore it.
I watched two HDR10+ to DV movies and both were perfect.
mondemon13
#5493 Post by mondemon13 » Thu Sep 09, 2021 3:34 am
I would suggest using the Kodi Dolby Vision builds for this, since it's patched to skip the HDR10+ when Dolby Vision is also present.
Otherwise, you can try this script: https://gist.github.com/quietvoid/175d7 ... 9eb1bd2c38
Which is based on yusesope's script, so it requires python and runs like so:
python hdr10plus_remove.py -i source-video.hevc -o output-video.hevc
Thank you! The script worked like a charm.
cannibalist2
#5494 Post by cannibalist2 » Thu Sep 09, 2021 12:57 pm
Hello, is it possible to convert from truehd + atmos to eac3 + atmos and mux with dolby vision movies?
I have not a receiver so I have to stick to ac3/eac3 but eac3 + atmos is so much better than ac3/eac3.
Like this one
https://imgur.com/a/OhxObMu
mulucy
#5495 Post by mulucy » Thu Sep 09, 2021 5:32 pm
chros wrote: Wed Sep 08, 2021 6:47 pm
Oppo has issue upconverting hdr10+ to DoVi
mulucy wrote: Wed Sep 08, 2021 2:09 pm This is from Sony's website Sony X700 owners:
Firmware update version M43.R.0284 for UBP-X700 | Release Dat 08-24-2021
  • Removes the Gracenote function
    Improves HDMI connection stability
    Supporting Dolby Vision content for Blu-ray Disc, Netflix and VUDU
    Supporting online streaming services
Have not updated mine yet. Whatever DV support means in the text above. Maybe they fixed the DV limitation where you had to know which movie/disk is DV to manually enable it?
Anyone updated yet and tried a Cinavia protected movie?
haven't updated my unit yet. Which titles have Cinavia? I thought the latter was thing of the past lol
#5496 Post by RESET_9999 » Thu Sep 09, 2021 7:08 pm
mulucy wrote: Thu Sep 09, 2021 5:32 pm haven't updated my unit yet. Which titles have Cinavia? I thought the latter was thing of the past lol
cannibalist2 wrote: Thu Sep 09, 2021 12:57 pm Hello, is it possible to convert from truehd + atmos to eac3 + atmos and mux with dolby vision movies?
Like this one
I could be wrong but i think you need the Dolby encoding suite for that and I dont think it's cracked.
EDIT: scratch that. theres an old version on russian trackers. Dont know if it supports Atmos though
cannibalist2
#5497 Post by cannibalist2 » Thu Sep 09, 2021 7:53 pm
RESET_9999 wrote: Thu Sep 09, 2021 7:08 pm
Like this one
Thanks, I thought so. Looks like there is no legal way for this unless you pay around 1000$
staknhalo
#5498 Post by staknhalo » Thu Sep 09, 2021 8:28 pm
Don't products like DVDFab remove cinavia or is it through encoding not just 'muxing' it out or whatever?
mulucy
#5499 Post by mulucy » Thu Sep 09, 2021 9:07 pm
staknhalo wrote: Thu Sep 09, 2021 8:28 pm Don't products like DVDFab remove cinavia or is it through encoding not just 'muxing' it out or whatever?
Cinavia is already dead. Most studios don't use it anymore. With the introduction of DRM with online streaming and piracy through 3rd-party players, the cost of it no longer was justified. But I think you are right, DVD Fab has the ability to remove it.
mulucy
#5500 Post by mulucy » Thu Sep 09, 2021 9:08 pm
The new Fire TV Stick came out today - https://www.amazon.com/dp/B08MQZXN1X/re ... CB5HMB36RE. Wonder if the new GPU/CPU supports more DV profiles lol
quietvoid
#5501 Post by quietvoid » Thu Sep 09, 2021 9:40 pm
I've preordered one for AV1, but the speed upgrade is welcomed.
Any Dolby Vision improvement is a bonus to me.
mulucy
#5502 Post by mulucy » Fri Sep 10, 2021 2:18 am
quietvoid wrote: Thu Sep 09, 2021 9:40 pm I've preordered one for AV1, but the speed upgrade is welcomed.
I tried to find some information about the CPU, but found nothing. Very strange...
dysprosium
#5503 Post by dysprosium » Fri Sep 10, 2021 4:40 am
mulucy wrote: Fri Sep 10, 2021 2:18 am I tried to find some information about the CPU, but found nothing. Very strange...
https://developer.amazon.com/docs/fire- ... stick4kmax
Mediatek MT8696
Dolby Vision support for Profile 4-MEL, 5, 8, 9. (Up to Level 9 for profiles 5 and 8. Up to Level 5 for Profile 9.)
mulucy
#5504 Post by mulucy » Fri Sep 10, 2021 6:06 pm
dysprosium wrote: Fri Sep 10, 2021 4:40 am
Mediatek MT8696
Good stuff, pretty much the same DV support. Thank you!
Pixels
#5505 Post by Pixels » Sat Sep 11, 2021 3:39 pm
I've converted the profile 7 to profile 5 DV using mp4muxer.
After extracting the single layer profile 7 mkv
File size                                : 81.3 GiB
Duration                                 : 2 h 34 min
Overall bit rate                         : 75.3 Mb/s
Movie name                               : Transformers: The Last Knight (2017) DV
Encoded date                             : UTC 2021-02-18 10:28:06
Writing application                      : mkvmerge v53.0.0 ('Fool's Gold') 64-bit
Writing library                          : libebml v1.4.1 + libmatroska v1.6.2
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 74.6 GiB (92%)
Audio
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Stream size                              : 708 MiB (1%)
Title                                    : AC-3 5.1-EX
to profile 5 DV mp4 as it triggers DV in my laptop
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 75.3 GiB
Overall bit rate                         : 69.7 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Stream size                              : 74.6 GiB (99%)
Encoded date                             : UTC 2021-08-30 18:13:04
Tagged date                              : UTC 2021-08-30 18:13:04
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
The problem is that the Audio is delayed, I went through the forum and found I had to to use dovi_tool, how do i proceed..?
