OMEGAZULUL
#5476 Post by OMEGAZULUL » Mon Sep 06, 2021 6:50 pm
vantheman wrote: Mon Sep 06, 2021 6:06 am
OMEGAZULUL wrote: Sun Sep 05, 2021 9:14 pm So if I have a TV that supports Tv-led dolby vision then any dolby vision movies I play with the shield wil be Tv-led? Do I need a certain profile or format for it to be Tv-led with Plex? I thought the only way to get Tv-led was with FEL and the shield ignores that. I looked up Vincent's comparison regarding Player-led vs Tv-led and to me Tv-led looked more detailed and brighter. As far as I know the difference between FEL and MEL is only 12 bit vs 10 bit so it should only matter in color banding. These statements contradicts each other so I'm confused right now. How can I get Tv-led dolby vision with Plex and the shield? What am I missing without FEL?
Hi OMEGAZULUL,
My understanding is that although the ShieldTV 2019 is capable (hardware-wise) of TV-led DV, the AndroidTV OS only supports LLDV playback and as a consequence the FEL is ignored.
With regard to HDTVTest's Player-led vs Tv-led DV comparison, this post here suggests that the noticeable difference in colour accuracy is more down to a bug in the Dolby SDK for UHD Blu-ray players.
So which media player has the best Dolby Vision playback and the most supported Dolby Vision profiles,formats? Can any do Tv-led and FEL playback?
MastaG
#5477 Post by MastaG » Mon Sep 06, 2021 7:14 pm
Can anybody with a series 6 LG OLED confirm wether or not they can trigger DV from TS or M2TS container?
Basically when I create STDL DV using yuseope's tool and store them in .TS or .M2TS using tsmuxer they play fine on my LG C8 using both Plex and Emby.
But when I try on my friends B6 the .TS file simply hang te player and the M2TS will only trigger HDR10.
Only MP4 created by Dolby's mp4muxer seems to work.
quietvoid
#5478 Post by quietvoid » Mon Sep 06, 2021 11:53 pm
jaimbo wrote: Mon Sep 06, 2021 5:43 pm Is it normal for extracted or modified HEVC files to not show Dolby Vision info when viewed in Mediainfo:
but for the Dolby Vision info to be visible when the HEVC file is added back into the MKV:
Spent some time thinking I was doing something wrong when adding DV extracted from Web-DL into my Bluray Remux as I was checking the HEVC files as I went and the HEVC files don't seem to show DV info in Mediainfo
Yes it's normal. MediaInfo is only parsing the container for Dolby Vision.
glc650
#5479 Post by glc650 » Tue Sep 07, 2021 12:33 am
vantheman wrote: Mon Sep 06, 2021 6:06 am My understanding is that although the ShieldTV 2019 is capable (hardware-wise) of TV-led DV, the AndroidTV OS only supports LLDV playback and as a consequence the FEL is ignored.
FEL requires two decoders which the Shield (and most other non-blu-ray players) don't have. That is why the Shield cannot play FEL. Has nothing to do with Android version or LLDV. If that was the case I would not be able to play FEL on my system (X800M2 w/LLDV only TV that plays FEL just fine).
glc650
#5480 Post by glc650 » Tue Sep 07, 2021 2:41 am
RESET_9999 wrote: Mon Aug 30, 2021 11:10 pm Just got a Zidoo z9x player.. works great for any file I played but tv-led has the wrong bt2020 flag as well SMH :(
https://slow.pics/c/8zWhGixS
The x700, the Shield, the appleTV, the firestick, Chromecast, Ugoos:
colors are mostly accurate, still have to check DV but at least there is no red push on Doctor Sleep. if they fix the bt2020 flag, it is a better device than the Shield IMO
HDR10 422 12bit
zidoo vs source vs htpc: https://slow.pics/c/sjhJStHn
SDR 422 12bit (444 8bit is the same accuracy):
zidoo vs source vs htpc: https://slow.pics/c/MZyuVwBq
When is the BT2020 flag supposed to show up? Only when using LLDV mode?
#5481 Post by RESET_9999 » Tue Sep 07, 2021 3:05 am
glc650 wrote: Tue Sep 07, 2021 2:41 am When is the BT2020 flag supposed to show up? Only when using LLDV mode?
in tv-led, the player sends a raw DV signal in an RGB 8 bit container (at this stage the video has purple and green color just like profile 5 look on an sdr screen so its not in bt2020 PQ yet).
Then the TV does the tone mapping and the picture, in the end, is 422 12bits bt2020 but only in the TV , not supposed to show up before (in the chain with vertex and player).
in lldv, the player does the tonemapping so the signal that is sent to the tv is already 422 bits bt2020. That is also the reason why @manix can capture it with his shogun atomos but cannot do the same with tv-led signal.
glc650
#5482 Post by glc650 » Tue Sep 07, 2021 5:05 am
RESET_9999 wrote: Tue Sep 07, 2021 3:05 am in tv-led, the player sends a raw DV signal in an RGB 8 bit container (at this stage the video has purple and green color just like profile 5 look on an sdr screen so its not in bt2020 PQ yet).
Explains why I see BT2020 for all DV with my TV (LLDV only).
RESET_9999 wrote: Sun Aug 01, 2021 2:36 am You have to check the pattern in the complete dark. Let your TV warm up for a couple of minutes and also let your eyes adapt to the darkness.
64 is completely black and you won't see it flashing unless you have raised black levels. You should see flashing starting at 66 for ideal shadow details. 65 is almost impossible to notice.
The problem with the C8 ( and CX/C1 from what I can read), is that it starts crushing black at 72ish in DV.
HDR10/SDR levels are correct, I can see 66 flashing.
Finally got around to checking this. I had raised blacks for all 3 of my sources (X800M2, Apple TV 4K gen2, madVR PC all connected directly to TV via different HDMI inputs). The PC w/madVR was way off (decreased from 50 to 33 on the black level adjustment setting). The other two were dropped to 47. On my TV, black level adjustments are available per HDMI port but all the modes (SDR/HDR10/DV) share one setting per port so which test should I use when checking? On the X800M2 I never watch SDR or HDR10 so that is any easy one just use the DV P5 test. On the Apple TV I watch mostly DV (Netflix) with some SDR (YouTube TV so I don't really care how accurate it is there) and HDR10 (Amazon but not much at all) so I used the P5 DV test for that device too. For madVR I used the P8 test (for the HDR10 fallback since madVR doesn't do DV). I watch as much SDR as I do HDR10 on madVR but figured it was more important that the HDR10 mode be set as accurate as possible due to the increased color range HDR brings? Note: my TV was never calibrated - professionally or otherwise.
staknhalo
#5483 Post by staknhalo » Tue Sep 07, 2021 6:03 am
If you mux a ST-DL hevc stream using dolby mp4 muxer as p7 (even though just one input video stream, no problem, still spits it out) you can then play ST-DL DVp7 from an mp4/m4v on CCwGTV, SHIELD TV 2019, and the Hisense 50U6G Android TV I have.
#5484 Post by Manixx2020beyound » Tue Sep 07, 2021 7:59 pm
Any sony x700 & Sony 800m2 users
Updated their firmware:
And if so any noticeable differences
Came out on the 8/24/21
Nitflix,vudu & uhd disc doblyvision
Wondering if they fixed anything DV related.
mondemon13
#5485 Post by mondemon13 » Wed Sep 08, 2021 3:17 am
Hello! Sorry if this is a dumb question. I have an mkv file with both DV and HDR10+. This triggers dolby vision on firestick, but only shows a black screen. How do I solve this? Should I remove the HDR10+ metadata? And if so, how?
mulucy
#5486 Post by mulucy » Wed Sep 08, 2021 2:09 pm
Manixx2020beyound wrote: Tue Sep 07, 2021 7:59 pm Any sony x700 & Sony 800m2 users
This is from Sony's website Sony X700 owners:
Firmware update version M43.R.0284 for UBP-X700 | Release Dat 08-24-2021
  • Removes the Gracenote function
    Improves HDMI connection stability
    Supporting Dolby Vision content for Blu-ray Disc, Netflix and VUDU
    Supporting online streaming services
Have not updated mine yet. Whatever DV support means in the text above. Maybe they fixed the DV limitation where you had to know which movie/disk is DV to manually enable it?
quietvoid
#5487 Post by quietvoid » Wed Sep 08, 2021 2:33 pm
mondemon13 wrote: Wed Sep 08, 2021 3:17 am Hello! Sorry if this is a dumb question. I have an mkv file with both DV and HDR10+. This triggers dolby vision on firestick, but only shows a black screen. How do I solve this? Should I remove the HDR10+ metadata? And if so, how?
I would suggest using the Kodi Dolby Vision builds for this, since it's patched to skip the HDR10+ when Dolby Vision is also present.
Otherwise, you can try this script: https://gist.github.com/quietvoid/175d7 ... 9eb1bd2c38
Which is based on yusesope's script, so it requires python and runs like so:
python hdr10plus_remove.py -i source-video.hevc -o output-video.hevc
#5488 Post by Manixx2020beyound » Wed Sep 08, 2021 4:36 pm
mulucy wrote: Wed Sep 08, 2021 2:09 pm
Yea but nitflix & vudu as well so it might be more than just movie/disk is dv,
Well only 1 way to know,
I updated mines a week ago but haven’t look closely at any changes.
chros
#5489 Post by chros » Wed Sep 08, 2021 6:47 pm
quietvoid wrote: Wed Sep 08, 2021 2:33 pm
Yes, that script worked for me like a charm (Oppo has issue upconverting hdr10+ to DoVi), thanks.
#5490 Post by RESET_9999 » Wed Sep 08, 2021 9:31 pm
chros wrote: Wed Sep 08, 2021 6:47 pm
why would you do that now that there's a tool that perfectly converts HDR10+ to true dynamic DV?
mulucy wrote: Wed Sep 08, 2021 2:09 pm This is from Sony's website Sony X700 owners:
Anyone updated yet and tried a Cinavia protected movie?
