Can anyone help or point me to the post/guide on how to convert hdr10/10+ to DV?
I concur, used Staxrip for many years.RESET_9999 wrote: ↑Fri Sep 03, 2021 3:41 pmAFAIK, what matters is what is reported to the TV by the player. Last time I checked, changing the metadata with mkvmerge correctly change what madvr(htpc) send to the TV. I don't know about other players though.staknhalo wrote: ↑Fri Sep 03, 2021 1:27 am
Edit: Yeah, that would only change/set the correct metadata in just the mkv container, not within the actual hevc stream itself (what I'm trying to do) - and oddly when you do that it shows you both info to show you there's container and stream metadata I guess. Thanks though.
Not even ffmpeg could do it apparently (without encoding) - not for the MDL metadata at least
Oh well, I'll have to try some other encoding tools I guess
you could also try this old software: https://www.videohelp.com/software/NVHSP
anyway, my recommendation still stands, forget about handbrake and take a look at staxrip.
Probably been discussed over and over again so sorry, but what are people using to play profile 5 in mkvs currently?
As much as I don’t trust it from profile 7 attempts, I’m guessing it’s probably the nvidia shield? Kodi/plex?
I use a Firestick 4K with Kodi, works well for me.
EL with bitrate around 2 Mbps is MEL for sure
I wonder does anyone tested hybrid UHD HDR10 BL+p5 DV meta on Shield TV reagarding infamous red push issue?
Could be hard to spot...
Please could I have some thoughts on:
A. ShieldTV 2019 PRO supports only LLDV playback.
B. When playing DV profile 7 with FEL MKV on the ShieldTV 2019 with PLEX the FEL is downgraded to MEL (LG CX TV displays the DV logo on top right corner).
C. When playing DV profile 7 with FEL MKV on the ShieldTV 2019 with PLEX the FEL is ignored and only the BL+RPU layer is decoded (LG CX TV displays the DV logo on top right corner).
D. When playing DV profile 7 with MEL MKV on the ShieldTV 2019 with PLEX the MEL is decoded correctly (LG CX TV displays the DV logo on top right corner).
E. Profile 5/8 BL+RPU gives better colour accuracy than HDR10.
I could be wrong, but I believe the process of converting FEL to MEL just discards the FEL video data but leaves the RPU untouched. So when converting to profile 8.1 I don't think you have to do anything special if you have a FEL source because you'll be discarding the whole EL and replacing it with the converted RPU either way.
I'm currently attempting to make my first hybrid profile 8.1 file and I had the same problem with my ffmpeg-demuxed HDR10 file.uhdiznotenough4mee wrote: ↑Tue Aug 31, 2021 1:30 pmBrilliant. It seems to be working fine using mkvextract. Will test the result later but no glitches at all. Thanks so much, kind sir, for all the work you are doing.quietvoid wrote: ↑Tue Aug 31, 2021 12:31 pmHave you tried using mkvextract instead of ffmpeg for the HDR10 base layer demux?uhdiznotenough4mee wrote: ↑Mon Aug 30, 2021 10:08 pmI do not have any errors either in ffmpeg or dovi_tool. All is going smooth. Except when I try to play the final file in either mpv or mpc-hc I see glitches - for example in the beginning when the the logo appears, the picture will freeze for a couple of seconds and the sound is continuing. At that time the glitch in small rectangle in left upper corner will appear. Here are examples:
If there are issues with the injected file, they are probably present in the original demuxed bitstream.
I stumbled on this ffmpeg bug ("hevc_mp4toannexb bsf doesn't insert correct parameter sets if they change in-band") that looks to me like it might be what we're encountering? My source video is also one that makes (heavy) use of seamless branching.
Unfortunately a fix for that bug seems to have gotten bogged down. Do you think it would be good idea to change the dovi_tool usage examples to use mkvextract for now? I'd be happy to submit a pull request if you'd like.
that's the first thing I did with the very first movie I injected DV....
viewtopic.php?p=110933#p110933
i dont know why you guys dont use Tsmuxer for extracting. It works very well and it allows you to extract hevc from seemless branching disc without merging the parts together first.FubbAyH wrote: ↑Sun Sep 05, 2021 1:22 pm
plus i never had glitches with it.
Converting to MEL only changes some fields in the RPU (as documented by Dolby) for the players to recognize as MEL.FubbAyH wrote: ↑Sun Sep 05, 2021 8:02 amI could be wrong, but I believe the process of converting FEL to MEL just discards the FEL video data but leaves the RPU untouched. So when converting to profile 8.1 I don't think you have to do anything special if you have a FEL source because you'll be discarding the whole EL and replacing it with the converted RPU either way.
The EL is not discarded, and I don't recommend that either.
If someone wants to discard the EL, they're better off converting to profile 8.1.
The examples only use ffmpeg for piping HEVC data. There's no problem with the metadata extraction in this case.
Maybe demux/convert are affected, but it's not possible to pipe with mkvextract.
And for injecting, there's no mention of ffmpeg to correct.
As always, it's up to the user to verify the files.
mmm Netflix moved from profile 5 to profile 8 ? or are these scene groups just injected DV metadata into hdr10 with quietvoid tool?
Crown Season 1-4 webdl :
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.07, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 1 min
Bit rate : 14.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.072
Stream size : 6.44 GiB (94%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1062 cd/m2
Maximum Frame-Average Light Level : 140 cd/m2
https://forum.blu-ray.com/showthread.php?t=276448
I'm pretty sure that's the caseRESET_9999 wrote: ↑Sun Sep 05, 2021 1:41 pmor are these scene groups just injected DV metadata into hdr10 with quietvoid tool?
That's a nice idea. That way I could keep all the tracks separate and only mux the file once at the end of the process. I'll try it next time I rip a disc. Thanks!RESET_9999 wrote: ↑Sun Sep 05, 2021 1:27 pmi dont know why you guys dont use Tsmuxer for extracting. It works very well and it allows you to extract hevc from seemless branching disc without merging the parts together first.
Ah, I see. I think the person I was replying to was intending to go from FEL to profile 8.1 so it's good to know that they can definitely do that in one step without having to go through MEL first.quietvoid wrote: ↑Sun Sep 05, 2021 1:31 pmConverting to MEL only changes some fields in the RPU (as documented by Dolby) for the players to recognize as MEL.
Oh that's a good point. I hope I didn't sound critical. I'm absolutely delighted with the tool and having a way to add DV to discs that lack it. Thank you very much for the tool, and thank you very much to RESET_9999 for all the helpful posts spelling out how to use it and documenting your experiments!quietvoid wrote: ↑Sun Sep 05, 2021 1:31 pmThe examples only use ffmpeg for piping HEVC data. There's no problem with the metadata extraction in this case.
I wish @Grencola was still around. I'm sure he could make us a ''simple'' GUI like this:FubbAyH wrote: ↑Sun Sep 05, 2021 3:18 pmOh that's a good point. I hope I didn't sound critical. I'm absolutely delighted with the tool and having a way to add DV to discs that lack it. Thank you very much for the tool, and thank you very much to RESET_9999 for all the helpful posts spelling out how to use it and documenting your experiments!
no, the shield support tv-led and player-led (lldv)
no it just ignores the el and use RPU metadata
yes
yes
The shield has colors issue (red push) with profile 4, 8, 7 ... profile 5 is accurate
