VLC Bluray playback not working
baishen
#1 Post by baishen » Wed Sep 01, 2021 8:39 pm
I installed MakeMKV on a Win10 machine and then installed VLC. Under the integration tab I get System32, SysWOW64, and VLC. I've tried checking just VLC and all three items but VLC keeps telling me that my disc is corrupt. I get this result on multiple discs. MakeMKV rips the disc just fine.
What am I missing? I thought it was supposed to be plug and play on windows. Did I miss a step?
Thanks.
Re: VLC Bluray playback not working
#2 Post by Billycar11 » Wed Sep 01, 2021 9:55 pm
baishen
#3 Post by baishen » Wed Sep 01, 2021 11:37 pm
Billycar11 wrote: Wed Sep 01, 2021 9:55 pm viewtopic.php?f=1&t=26010#p112243
That's what I did. Open Disc, select Blu Ray. Menu doesn't seem to matter wether it's checked or not.
#4 Post by Billycar11 » Thu Sep 02, 2021 12:14 am
Trial version of makemkv does not work with on the fly playback
Are you using the trial?
baishen
#5 Post by baishen » Thu Sep 02, 2021 10:53 am
Billycar11 wrote: Thu Sep 02, 2021 12:14 am Trial version of makemkv does not work with on the fly playback
Indeed I was as I didn't bother loading my license just to test it on another machine. Once I did that everything worked.
However, it would have been nice if it told me that was the issue instead of insisting that my disc was corrupted.
maldoror
#6 Post by maldoror » Thu Dec 16, 2021 12:51 am
baishen wrote: Thu Sep 02, 2021 10:53 am
Thank you for this, been puzzling this out for an hour. It would be good if in the integration menu it told you that the feature didn't work unless the product was registered. I am planning to buy a license, but I figured as I still had 70 days left on evaluation I would wait until closer to the time.
