ASUS BW-12B1ST
muels7
ASUS BW-12B1ST
So I have been using makemkv for a while now. Today I bought my first UHD disc and decided to look into ripping it with makemkv. I found that my drive(ASUS BW-12B1ST) is on the UHD friendly list. However I can't get it to recognize that the UHD disc is in the drive. I am at firmware 1.03 if that make a difference. I can't find any posts about this drive except that it is in the friendly list. Does anyone know if the firmware is the issue with this drive and what version I should be at?
st4evr
Re: ASUS BW-12B1ST
It has been previously confirmed that your drive is NOT friendly after all. Listed as friendly incorrectly in a few places. I believe including this forum on a few lists here.
Read this:
https://club.myce.com/t/the-ultimate-ul ... /399725/15
You need the newer model of the drive which is:
Asus BC-12D2HT
With the CORRECT CLEAN firmware. NOT any version that has been patched up by Asus. For this drive I believe it's 3.00.
The Asus Firmware with the loophole is version 3. (e.g. 3.00 , 3.01, 3.02, etc). Depending on the drive model and manufactured date newer revisions of 3.02 have been patched and 3.03 is completely patched.
Asus drives with Firmware version 1 (e.g. 1.00 , 1.01, etc) are too OLD and pre-loophole. They do not have the hardware to do this.
EDIT: People have been having a hard time finding BC-12D2HT with the proper firmware. You are better off buying one of the other more popular models that are UHD Friendly. There are forum members who are assisting with flashing/purchases of these drives in clearly marked posts which could also assist you in this.
Read this:
Asus BC-12D2HT
muels7
Re: ASUS BW-12B1ST
Well that is disappointing. I have had this drive for about 6 years, maybe more, so its no big deal. I just saw on one of the other UHD posts that my drive was listed. Guess not. Will have to see if I can find one of the models that is affordable.
jcwillia1
Re: ASUS BW-12B1ST
I'm not sure I believe this - the BW has a close cousin the BC that has at least one confirmed use out in the wild and another that I've seen and has since been deleted.
https://www.reddit.com/r/hometheater/co ... t/dz02nfl/
I am going to try and flash my BC drive this weekend and see what happens.
Best case I have a UHD drive
Worst case I have to buy a new drive which if this doesn't work I was going to have to do anyways.
corruption
Re: ASUS BW-12B1ST
I must have some one of a kind Voodoo drive, as I've ripped 21 of my UHD discs without issue with the OEM version of this drive ("C" instead of "W"). Only thing is I can't seem to make disc backups--just rip titles to MKVs, so maybe it's "sort of friendly"?
ASUS BC-12B1ST
b3.00
ASUS BC-12B1ST
b3.00
jonghotti
Re: ASUS BC-12B1ST
The BC-12B1ST is a good little drive. As pointed out it can be flashed with the BW-16D1HT friendly firmware. If you should need one of these I'm happy to supply one.
1mmfruh1
Re: ASUS BW-12B1ST
jonghotti - could you point me to the firmware version for the ASUS BW-12B1ST that will let it access UHD discs? Thank you!
Re: ASUS BW-12B1ST
BW-16D1HT 3.02 is here: viewtopic.php?f=16&t=18873 2nd and 3rd posts or here: viewtopic.php?f=16&t=189331mmfruh1 wrote: Thu Feb 21, 2019 4:04 pm jonghotti - could you point me to the firmware version for the ASUS BW-12B1ST that will let it access UHD discs? Thank you!
Wolfnut88
Re: ASUS BC-12B1ST
So i'm looking into updating pic related, i've found firmware 3.11 for it but i'm curious about what you posted. Do i just use the ASUS ODD FW Changer to flash DE-ASUS BW-16D1HT or will i need the official FW? Do i lose any functionalities like disc writing? Thanks.jonghotti wrote: Tue Jan 29, 2019 6:54 pm The BC-12B1ST is a good little drive. As pointed out it can be flashed with the BW-16D1HT friendly firmware. If you should need one of these I'm happy to supply one.
deerewright
Re: ASUS BC-12B1ST
I have the same question. I have tried to flash my ASUS BW-12B1ST with both the ASUS flasher and the SDTool. Neither one seems to work. They both just hang and/or do nothing. What am I missing?Wolfnut88 wrote: Sun Mar 15, 2020 10:27 pmSo i'm looking into updating pic related, i've found firmware 3.11 for it but i'm curious about what you posted. Do i just use the ASUS ODD FW Changer to flash DE-ASUS BW-16D1HT or will i need the official FW? Do i lose any functionalities like disc writing? Thanks.jonghotti wrote: Tue Jan 29, 2019 6:54 pm The BC-12B1ST is a good little drive. As pointed out it can be flashed with the BW-16D1HT friendly firmware. If you should need one of these I'm happy to supply one.
corruption
Re: ASUS BC-12B1ST
Just looked up what I used sucessfully:deerewright wrote: Wed Sep 01, 2021 5:05 pmI have the same question. I have tried to flash my ASUS BW-12B1ST with both the ASUS flasher and the SDTool. Neither one seems to work. They both just hang and/or do nothing. What am I missing?Wolfnut88 wrote: Sun Mar 15, 2020 10:27 pmSo i'm looking into updating pic related, i've found firmware 3.11 for it but i'm curious about what you posted. Do i just use the ASUS ODD FW Changer to flash DE-ASUS BW-16D1HT or will i need the official FW? Do i lose any functionalities like disc writing? Thanks.jonghotti wrote: Tue Jan 29, 2019 6:54 pm The BC-12B1ST is a good little drive. As pointed out it can be flashed with the BW-16D1HT friendly firmware. If you should need one of these I'm happy to supply one.
(Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack (14.02.2020).zip
deerewright
Re: ASUS BC-12B1ST
I cannot even get it to flash to a uhd friendly firmware. Is there anything else I need to do before I try to flash with the ASUS flasher? Right now when I try to flash, it opens the tray, then just seems to hang. Nothing else happens, no progress, nothing. If I exit out of the flasher, the drive still shows the original firmware (1.03), and drive works fine. So, I havent corrupted the drive. Am I missing a step?corruption wrote: Wed Sep 01, 2021 5:38 pm
Re: ASUS BW-12B1ST
DO NOT FLASH a drive that has 1.03. This drive is too old and you will brick it!
corruption
Re: ASUS BC-12B1ST
Maybe we don't have the same drive. Here's my info:deerewright wrote: Wed Sep 01, 2021 8:44 pmI cannot even get it to flash to a uhd friendly firmware. Is there anything else I need to do before I try to flash with the ASUS flasher? Right now when I try to flash, it opens the tray, then just seems to hang. Nothing else happens, no progress, nothing. If I exit out of the flasher, the drive still shows the original firmware (1.03), and drive works fine. So, I havent corrupted the drive. Am I missing a step?corruption wrote: Wed Sep 01, 2021 5:38 pm
Product: BD-RE BH12LS38
Revision: 1.00
Serial number: XXXXXXXXXXXX
Firmware date: 2011-11-02 12:34:56
Bus encryption flags: 1F
Highest AACS version: 76
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.00-D3
deerewright
Re: ASUS BC-12B1ST
corruption wrote: Fri Sep 03, 2021 9:03 pm
Revision: 1.00
I'm assuming my drive is just too old. I was able to speed things up, however, with setting MakeMKV's speed control.
OS device name: E:
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.03
Serial number: CBD0CL008255
Bus encryption flags: 1E
Highest AACS version: 68
