Player app for win10 & LG BU40N with blu-ray?
HittiittitiH
Player app for win10 & LG BU40N with blu-ray movie?
I double clicked the drive with a movie in it and vlc popped up giving playback errors and it dont play the movie.
Whar windows 10 player app do you guys use?
Thanks in advance.
Thanks in advance.
HittiittitiH
Re: Player app for win10 & LG BU40N with blu-ray?
Your input can't be opened:
VLC is unable to open theYour input can't be opened:
VLC is unable to open the MRL 'dvd:///G:\'. Check the log for details.
HittiittitiH
I found a good p[layer called Leawo Blu-ray Player.
If the drive is on a USB port, there is a chance that VLC can't talk to it because of Windows ransomware protection. You have to authorize "unapproved" programs to access removable devices if you're not running as an administrator. A google search for "windows ransomware exception" will find a lot of information about that.
Is this the same Leawo that was selling pirated copies of MakeMKV as their own product in the past?
HittiittitiH
i have no idea, should i unimstall it?
HittiittitiH
i uninstalled it.
Have you checked both options on the MakeMKV Preferences > Integration tab (Run as Administrator)?HittiittitiH wrote: ↑Tue Aug 31, 2021 1:15 amPlayer app for win10 & LG BU40N with blu-ray movie?
Thanks in advance.
Direct Blu-ray playback with VLC
HittiittitiH
enabling vlc in preferences, vlc still doesn't work, spits out errors. I am on window 10.
HittiittitiH
VLC crashes trying to play 4k ghost in the shell. after i have selected all options to check for the intergration.
HittiittitiH
HittiittitiH
mvp crashes as well. omg.k'lojipmnSDVZ'kl;jocxzdv
vlc open disc
open bluray
disable menus if you don't have java
this is all after you enable integration in makemkv for vlc
open bluray
HittiittitiH
Billycar11 wrote: ↑Tue Aug 31, 2021 3:15 amvlc open disc
open bluray
its working now for some reason. cool. thanks!
HittiittitiH
