Player app for win10 & LG BU40N with blu-ray?
HittiittitiH
Post by HittiittitiH »
Player app for win10 & LG BU40N with blu-ray movie?
I double clicked the drive with a movie in it and vlc popped up giving playback errors and it dont play the movie.
Whar windows 10 player app do you guys use?
Thanks in advance.
HittiittitiH
Re: Player app for win10 & LG BU40N with blu-ray?
Your input can't be opened:
VLC is unable to open theYour input can't be opened:
VLC is unable to open the MRL 'dvd:///G:\'. Check the log for details.
HittiittitiH
I found a good p[layer called Leawo Blu-ray Player.
If the drive is on a USB port, there is a chance that VLC can't talk to it because of Windows ransomware protection. You have to authorize "unapproved" programs to access removable devices if you're not running as an administrator. A google search for "windows ransomware exception" will find a lot of information about that.
Is this the same Leawo that was selling pirated copies of MakeMKV as their own product in the past?
HittiittitiH
i have no idea, should i unimstall it?
HittiittitiH
i uninstalled it.
Post by d00zah »
HittiittitiH wrote:
Tue Aug 31, 2021 1:15 am
Thanks in advance.
Have you checked both options on the MakeMKV Preferences > Integration tab (Run as Administrator)?
Direct Blu-ray playback with VLC
HittiittitiH
enabling vlc in preferences, vlc still doesn't work, spits out errors. I am on window 10.
HittiittitiH
VLC crashes trying to play 4k ghost in the shell. after i have selected all options to check for the intergration.
HittiittitiH
HittiittitiH
mvp crashes as well. omg.k'lojipmnSDVZ'kl;jocxzdv
vlc open disc
open bluray
disable menus if you don't have java
this is all after you enable integration in makemkv for vlc
HittiittitiH
Billycar11 wrote:
Tue Aug 31, 2021 3:15 am
vlc open disc
open bluray
its working now for some reason. cool. thanks!
HittiittitiH
:D
