#5401 Post by RESET_9999 » Fri Aug 27, 2021 3:22 pm
higher wrote:
Fri Aug 27, 2021 2:26 pm
RESET_9999 wrote:
Fri Aug 27, 2021 2:07 pm
the C8 supports all the DV profiles.
The ts file you tried must be dual-layer which the c8 won't trigger DV in this container (or it will even say ''corrupted'').
so you have to demux and remux with the mp4muxer using profile 7
I was trying with a Hulu DoVi mkv file floating on the web which is Profile 8 but remuxing it to ts didn't trigger Dolby Vision, only regular HDR.
that's strange... I dont think I ever had a p8 file that my C8 didnt play in DV.
I will try tonight. which web-dl did you try?
higher
#5402 Post by higher » Fri Aug 27, 2021 3:33 pm
I was trying it with an episode of Nine Perfect Strangers. Will be home soon and I'm going to give tsMuxer yet another try because I used 2.6.12 not the nightly build you linked. Will also try mp4muxer with P5.
#5403 Post by RESET_9999 » Fri Aug 27, 2021 3:54 pm
hulu web-dl are not in profile 5 but you can use the mp4muxer and remux to profile 8.
nightly tsmuxer should work though
higher
#5404 Post by higher » Fri Aug 27, 2021 6:21 pm
Got home and tried the nightly tsMuxer build you posted earlier and it works, ts is now triggering DV on the TV. Thank you for the link! :)
cannibalist2
#5405 Post by cannibalist2 » Sun Aug 29, 2021 11:44 am
Guys thanks for all the information you shared so far. I started to reading all of the pages for making dolby vision rips properly. But I need to ask you some questions before that. I have LG G1 and I'm gonna use native plex app. (I don't have shield or apple tv)
1. Does this tv support only mp4/m2ts/ts and single layer dolby vision?
2. My pc doesn't have a strong cpu. Does making dolby vision rips take too much time?
3. I want to get best picture as possible. Is plex app enough or do I need shield pro?
staknhalo
#5406 Post by staknhalo » Sun Aug 29, 2021 1:34 pm
galarond wrote:
Sun Aug 29, 2021 12:28 pm
How can i see if a mt2s or mkv have hdr10plus metadata'?
Trying to find a Alien 1979 hdr10plus disk backup version...
It should be apparent in mediainfo
thetoad
#5407 Post by thetoad » Mon Aug 30, 2021 5:58 am
are hdrplus10 and dovi rpu (i.e. not enhancement layers) metadata effectively similar information? could one conceptually convert one to the other? (i.e. assuming one has an hdr10 base, could one convert hdr10plus to give a dolby vision only tv dynamic metadata and vice versa for an hdr10plus tv).
or are they totally different (or different enough) that this isn't possible. just wondering if anyone has thought about this?
quietvoid
#5408 Post by quietvoid » Mon Aug 30, 2021 11:56 am
Going from HDR10+ to Dolby Vision can be done partially, since both include the image analysis info (min/max/avg luminance). The rest of the info is incompatible without heavy calculations.
Going from Dolby Vision to HDR10+ isn't really possible because HDR10+ requires some information (luminance percentiles per shot) that's not present in Dolby Vision, and would require analyzing the image and more calculations..
Not to mention most of the steps for calculations are proprietary.
fortnate90
#5409 Post by fortnate90 » Mon Aug 30, 2021 2:04 pm
RESET_9999 wrote:
Thu Aug 26, 2021 11:43 pm
hulu recently added dv and hdr10plus support and it looks like they are all in profile 8 DV
Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Seems hulu has no extra HDR encoding so would it be possible to demux the HDR part from the hevc stream?
I found out that this dovi_tool has a demux option and now i got 2 files BL.hevc and EL.hevc. The BL.hevc seems to be the HDR part, is that right? Or is there another way to force HDR playback instead of DV?
MastaG
#5410 Post by MastaG » Mon Aug 30, 2021 4:44 pm
EDIT:
I really hope somebody can answer this.
Does the Plex app for Shield support DV from MKV containers?
If yes, which profiles?
And what about the LG WebOS Plex app?
I believe it only supports DV profile 5 (MEL) from MKV containers right?
What about .TS containers?
I'm looking to store my videos in a container which can also carry lossless audio, but is capable of triggering DV on both LG TVs and the Shield using Plex.
I know LG only supports AC3, but that's no problem because I can just store the TrueHD track as the second one.
quietvoid
#5411 Post by quietvoid » Mon Aug 30, 2021 5:56 pm
Yes, the BL.hevc file does not contain any Dolby Vision data, but it does still fallback to HDR10+.
uhdiznotenough4mee
#5412 Post by uhdiznotenough4mee » Mon Aug 30, 2021 10:08 pm
Hi! I am newbee here so please bear with me. I've experimented with dovi_tool a little bit but failed every time. Obviously I am doing something wrong so I would appreciate your help. Thank you.
Here are my exact steps (using Windows 10 Pro 64bit and everything like source files and dovi_tool.exe/ffmpeg.exe are inside main folder):
01, ffmpeg -i DV_WEB-DL.mp4 -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool -m 3 extract-rpu -
02, ffmpeg -i HDR.mkv -c:v copy hdr.hevc
03, dovi_tool inject-rpu -i hdr.hevc --rpu-in RPU.bin -o output.hevc
04, final output.hevc is muxed in latest MKVToolnix with sound and subtitles from HDR.mkv
There is a difference between DV web-dl and remux HDR10 file in frames but if I understood correctly, dovi_tool should adjust it automatically for metadata. Am I right? Using the latest 0.5 version.
I do not have any errors either in ffmpeg or dovi_tool. All is going smooth. Except when I try to play the final file in either mpv or mpc-hc I see glitches - for example in the beginning when the the logo appears, the picture will freeze for a couple of seconds and the sound is continuing. At that time the glitch in small rectangle in left upper corner will appear. Here are examples:
Here is MediaInfo (some info reducted):
Format                         : Matroska
Format version                 : Version 4
File size                      : 51.0 GiB
Duration                       : 2 h 13 min
Overall bit rate mode          : Variable
Overall bit rate               : 54.5 Mb/s
Movie name                     : MOVIE
Encoded date                   : UTC 2021-08-30 21:24:30
Writing application            : mkvmerge v61.0.0 ('So') 64-bit
Writing library                : libebml v1.4.2 + libmatroska v1.6.4
Video
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main 10@L5.1@High
HDR format                     : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                       : V_MPEGH/ISO/HEVC
Bit rate                       : 48.9 Mb/s
Width                          : 3 840 pixels
Height                         : 2 160 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0 (Type 2)
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.246
Stream size                    : 45.7 GiB (90%)
Writing library                : ATEME Titan File 3.9.6 (4.9.6.2)
Language                       : English
Default                        : Yes
Forced                         : No
Color range                    : Limited
Color primaries                : BT.2020
Transfer characteristics       : PQ
Matrix coefficients            : BT.2020 non-constant
Mastering display color primar : Display P3
Mastering display luminance    : min: 0.0000 cd/m2, max: 1000 cd/m2
Audio #1
Format                         : MLP FBA 16-ch
Format/Info                    : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name                : Dolby TrueHD with Dolby Atmos
Codec ID                       : A_TRUEHD
Bit rate mode                  : Variable
Bit rate                       : 4 651 kb/s
Maximum bit rate               : 6 930 kb/s
Channel(s)                     : 8 channels
Channel layout                 : L R C LFE Ls Rs Lb Rb
Sampling rate                  : 48.0 kHz
Frame rate                     : 1 200.000 FPS (40 SPF)
Compression mode               : Lossless
Stream size                    : 4.35 GiB (9%)
Title                          : TrueHD Atmos 7.1
Language                       : English
Default                        : Yes
Forced                         : No
Number of dynamic objects      : 13
Bed channel count              : 1 channel
Bed channel configuration      : LFE
Audio #2
Format                         : AC-3
Format/Info                    : Audio Coding 3
Commercial name                : Dolby Digital
Codec ID                       : A_AC3
Bit rate mode                  : Constant
Bit rate                       : 640 kb/s
Channel(s)                     : 6 channels
Frame rate                     : 31.250 FPS (1536 SPF)
Compression mode               : Lossy
Stream size                    : 613 MiB (1%)
Title                          : Compatibility Track
Language                       : English
Service kind                   : Complete Main
Default                        : No
Forced                         : No
Text #1
Format                         : PGS
Codec ID                       : S_HDMV/PGS
Codec ID/Info                  : Picture based subtitle format used on BDs/HD-DVDs
Duration                       : 2 h 11 min
Bit rate                       : 34.8 kb/s
Count of elements              : 3804
Stream size                    : 32.8 MiB (0%)
Title                          : SDH
Language                       : English
Default                        : No
Forced                         : No
Thanks for your inputs.
#5413 Post by RESET_9999 » Mon Aug 30, 2021 11:10 pm
Just got a Zidoo z9x player.. works great for any file I played but tv-led has the wrong bt2020 flag as well SMH :(
https://slow.pics/c/8zWhGixS
The x700, the Shield, the appleTV, the firestick, Chromecast, Ugoos:
colors are mostly accurate, still have to check DV but at least there is no red push on Doctor Sleep. if they fix the bt2020 flag, it is a better device than the Shield IMO
HDR10 422 12bit
zidoo vs source vs htpc: https://slow.pics/c/sjhJStHn
SDR 422 12bit (444 8bit is the same accuracy):
zidoo vs source vs htpc: https://slow.pics/c/MZyuVwBq
#5414 Post by shawnc22 » Tue Aug 31, 2021 1:15 am
HDR10 422 12bit
damn with all the players you've bought recently, you should've just bit the bullet and gotten one of the oppo clones :lol:
#5415 Post by RESET_9999 » Tue Aug 31, 2021 1:24 am
:lol:
yeah but just like the x700, the oppo cant play cropped DV properly. with all the appletv and amazon(hdr10+ to DV) content , it was a problem.
And now I can watch all the mel DV content via my network and only use my hdd /x700 for FEL. It's much more practical now. plus I get to reduce the amount of TS files in my library ( i prefer all MKV)
zidoo works surprisingly well, literally played every single file I tried.
