that's strange... I dont think I ever had a p8 file that my C8 didnt play in DV.higher wrote: Fri Aug 27, 2021 2:26 pmI was trying with a Hulu DoVi mkv file floating on the web which is Profile 8 but remuxing it to ts didn't trigger Dolby Vision, only regular HDR.RESET_9999 wrote: Fri Aug 27, 2021 2:07 pm the C8 supports all the DV profiles.
The ts file you tried must be dual-layer which the c8 won't trigger DV in this container (or it will even say ''corrupted'').
so you have to demux and remux with the mp4muxer using profile 7
I will try tonight. which web-dl did you try?
