MKV failing on a specific PC (that used to work)
ddeconin@gmail.com
#1 Post by ddeconin@gmail.com » Tue Aug 17, 2021 9:58 am
I've got a very strange issue with my main PC.
I've been using Makemkv on my main pc for quite a while without issues copying my 4K UHD disc collection from an external drive.
Some months ago , makemkv started failing on all disk with a similar error and I have not been able to get it to fully copy a disk since...
At some point during the read the drive light stops flashing, Output Size remains constant (so nothing is read anymore) and the remaining time starts creeping up.
Then a bit later, makemkv reports :
s=9 n=0 o=48372307968
s=10 n=0 o=48372307968
005003:0000 Failed to save title 4 to file C:/Users/I063836/Videos/2001- A Space Odyssey/2001- A Space Odyssey_t04.mkv
Encountered 32 unclassified errors
error=0xC000000E count=11 name=OS error - A device which does not exist was specified
error=0xC000009D count=21 name=OS error - STATUS_DEVICE_NOT_CONNECTED
and windows reports 'USB device you connected to this computer malfunctioned'.
However, I have been able to use makemkv with these same disks & the same external drive on a few other PC's and a mac and there the copy works fine each time.
So its just this specific PC where it stopped working for all discs suddenly but no clue what goes wrong...
Re: MKV failing on a specific PC (that used to work)
#2 Post by Billycar11 » Tue Aug 17, 2021 10:23 am
Drive is turning off because of not enough power use both connectors if it has a y cable
ddeconin@gmail.com
#3 Post by ddeconin@gmail.com » Wed Aug 18, 2021 6:35 pm
Billycar11 wrote: Tue Aug 17, 2021 10:23 am Drive is turning off because of not enough power use both connectors if it has a y cable
Im using a drive in an external enclosure with an external power brick.
The weird part is:
- The drive used to work fine with the pc until a little while ago
- The drive still works with another pc laptop and a mac
Since it still looks to be power related replacing the power brick of the enclosure is next on my list...
#4 Post by Billycar11 » Wed Aug 18, 2021 8:11 pm
ddeconin@gmail.com wrote: Wed Aug 18, 2021 6:35 pm
The weird part is:
I see thought this was a USB powered drive what I would try next is make a bootable clean os and see if it happens to rule out a messed up os install
ddeconin@gmail.com
#5 Post by ddeconin@gmail.com » Mon Aug 30, 2021 10:19 am
Billycar11 wrote: Wed Aug 18, 2021 8:11 pm
The weird part is:
Corporate pc, so not easy to do. However, after fiddling with lots of usb driver settings etc I got things more stable by setting
0=99;U1=-;U2=-;U3=-;B1=-;B2=-; in the registry for the speed settings.
