Jumanji..original film..won't backup
Chip9399
Post by Chip9399 »
I’m new to this so bear with me and teach me a couple things, I have been backing up my collection for plex, I just purchased the 3 film collection of jumanji, 2 of the films welcome to the jungle and the next1 level backup fine, but the original will not.. any suggestions? Am I to understand that files have to be dumped for each film to backup???
Using a
LG WH16NS60 with 1.02 firmware,
Re: Jumanji..original film..won't backup
full error log
brymer28
Post by brymer28 »
My UHD 4K BD of Jumanji: Welcome to the Jungle (2017) has acted this way for me since I bought it. It will never advance past about 20% or so. It just hangs. You have to cancel the rip to do anything.
Here are the logs from my attempt with a WH16NS60 1.03 (yes, the awesome 1.03) :
Log not included... Add it in between [code][/code] tags
brymer28
Post by brymer28 »
Attachment adding failed, full log is 1703 lines. I'll have to add 300 lines at a time to try to keep character limit for posting character limit:
Debug log started at Wed Apr  3 02:49:34 2024 , written by MakeMKV v1.17.6 linux(x64-release)
001005:0000 MakeMKV v1.17.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/bmerkley/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.81.0/OpenSSL/3.0.2/1.43.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at 1x16b4G!]9Eznq-@H9$38R:29393631
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_M68I9IB5756
001011:0000 Using LibreDrive mode (v06.3 id=4083C4CCDB14)
DEBUG: Code 2147483648 at o&Q#{s+fhI7pb-@J:121265499
DISCID=6EE1CE344775A05083BD10010D2E8B987756A426
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00102.mpls was added as title #1
003025:0000 Title #00604.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00605.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00618.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00619.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00663.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00680.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00687.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00688.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00689.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00690.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00691.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00702.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00703.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00704.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00705.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00706.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00707.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00708.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003309:0000 Title 00711.mpls is equal to title 00102.mpls and was skipped
003025:0000 Title #00720.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00721.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00734.mpls has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00735.mpls has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00780.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00797.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00811.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00812.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00813.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00814.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00815.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00816.mpls has length of 19 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00817.mpls has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00818.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00819.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00820.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00821.mpls has length of 18 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003309:0000 Title 00002.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00822.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00823.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00824.mpls is equal to title 00001.mpls and was skipped
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003307:0000 File 00001.m2ts was added as title #2
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 13 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 56 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00600.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00601.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00602.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00603.m2ts has length of 5 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00604.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00605.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00606.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00607.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00608.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00609.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00610.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00611.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00612.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00613.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00614.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00615.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00616.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00617.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00618.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00619.m2ts has length of 16 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00620.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00621.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00622.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00623.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00624.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00625.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00626.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00627.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00628.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00629.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00630.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00631.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00632.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00633.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00634.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00635.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00636.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00637.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00638.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00639.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00640.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00641.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00642.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00643.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00644.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00645.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00646.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00647.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00648.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00649.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00650.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00651.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00652.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00653.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00654.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00655.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00656.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00657.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00658.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00659.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00660.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00661.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00662.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00663.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00664.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00665.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00666.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00667.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00668.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00669.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00670.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00671.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00672.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00673.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00674.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00675.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00676.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00677.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00678.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00679.m2ts has length of 7 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00680.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00681.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00682.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00683.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00684.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00685.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00686.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00687.m2ts has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00692.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00693.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00694.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00695.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00696.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00697.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00698.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00699.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00700.m2ts has length of 6 seconds which is less than minimum title length of 90 seconds and was therefore skipped
003025:0000 Title #00701.m2ts has length of 10 seconds which is less than minimum title length of 90 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file:///dead/xcode/mmcdump/sr2
AV sync issues in /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
AV sync in 3 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 4 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 5 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 8 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 9 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 10 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 11 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 12 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 3,4,5,8,9,10,11,12 at 0:00:00 (8ms) : encountered overlapping frame, audio skew is +8ms
001003:0020 DEBUG: Code 1073741829 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100864261 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100864261 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941314 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941314 at N]DAZnR|jdbq4LVk:213130559
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '12378568704'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/sr2' at offset '12378568704'
DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:213131502
DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:213131502
brymer28
Post by brymer28 »
log comment #2
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:29395471
001003:0020 DEBUG: Code 0 at YMHf%Za'~Mb\_rf1oL*7:29394068
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:213131157
001003:0020 DEBUG: Code 0 at g'i_,^1hF`lAj6ygl'kr:121262647
001003:0020 DEBUG: Code 6044223 at g'i_,^1hF`lAj6ygl'kr:121261773
001003:0020 DEBUG: Code 0 at Ay!VnHJ"DVdF^7&`C4jH*:213137068
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29394022
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29404878
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29405384
001003:0020 DEBUG: Code 0 at =b>x}Kg}]"4,X)(^C/RD:29403383
001003:0020 DEBUG: Code 0 at dJ#xjuAP^)lYNI+7YCfc:213141208
001003:0020 DEBUG: Code 0 at V4AKLu\uJj.\i2uw:213132537
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:29396207
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:121264257
001003:0020 DEBUG: Code 0 at Gqp4iA(j)9B.`LPDC:213130490
---- Failed /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
ch_0        1684187505000 0
ch_1        1685133450000 0
ch_2        1686079395000 0
ch_3        1687340655000 0
ch_4        1688286600000 0
ch_5        1689232545000 0
ch_6        1690448760000 0
ch_7        1691394705000 0
mt=0x76bbb59e08b0 n=71
s=0 n=1 o=12378568704
    0 992932 000001  1691394705000       45045000 EAD51881 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=1 o=12358785024
    1    490 000001  1691394300000         900000 E73006F1 20F593D8602D607B60A060EF4BC7DDCE35D156985F6521735F484ADD46A01743DC1AAF22CB4E538893DDE71A64B7A077A2B10FCCB2AA1BF5A90AE24D08A0B3F8906E236B237C6D572D206B392F49518CB484F856B3F8E48EE07C78CAB0BA5EBBDB9B3B203F80407195FF8738E17C490D7F8FD2F5472E5D70F465EFE15741CE98
s=2 n=1 o=12370206720
    2   2560 000001  1691400960000       34560000 CD764D7C 0B7789DE2440E1FFCCC03FE7955E1861860EFE153DEAA9BB495E9D18A6D835DEADCC37CF9DA0B895F2B7CADCDA7EF6BA5B0E6156AD5B5C67D5D3A17CFA9429E99D2649C1329B0F2BBDA74DD8DA656CD77DB2BE2E3543B03908C74FA8DAB8962431CF972576969443FBBA397AF76437CA6BBED74A9434CDA6D354AD4D324E2C3E
s=3 n=1 o=12358637568
    3   2560 000001  1691400960000       34560000 21E45A2F 0B77B4ED2440E1FFCCC03FE7955E1861860D72153AD0133B495F56B76CF11FE2D9E5C74F9F4EA682DAB7321AC2A892BA9B70E72A7CF6DBEA5A9FAB4AFAB434CD9EE771D1F26A546BBA7D5DF917E9ACBE7DAA9E54DF6B543292EA8492D44133CBF535AB3E84ED2C2550D4D817597C7A35DED884FA9BA7D1E139AD0ABAAAEB9D3C
s=4 n=1 o=12370182144
    4   2560 000001  1691400960000       34560000 5159C9A9 0B7712152440E1FFCCC03FE7955E1861860D72153AD0133B495F56B76CF11FE2D9E5C74F9F4EA682DAB7321AC2A892BA9B70E72A7CF6DBEA5A9FAB4AFAB434CD9EE771D1F26A546BBA7D5DF917E9ACBE7DAA9E54DF6B543292EA8492D44133CBF535AB3E84ED2C2550D4D817597C7A35DED884FA9BA7D1E139AD0ABAAAEB9D3C
s=5 n=1 o=12370575360
    5   2560 000001  1691400960000       34560000 41B9A2BB 0B773CEC2440E1FFC0C03FE3955E1861860EADF3FAD0DFBB514E9575E8F0B9D6AE6AF7D4934DBA2212B7371CC29DADF8D7D0DEC4415AC2D7EE6BAA864693F6CA73BE4D4A0D37E92A217EF9F267696F3E7DBA7B0E6BAA7CF5F438482CA87CF613E52EAA21AD09F41D30E41FD845FBE7BC52CDB50DFBD83B12BEA5C1242AF0B5BA
s=6 n=1 o=12360585216
    6   3904 000001  1691400960000       11520000 FA070C3A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000024200002200000000000000240000001541A53BD5922C016358B5114E0F739CD6B58D6B18C5AD6B520E6188410CE2F7356A52949424A528C4208421084210CE2F6B54A5292941CC62946210421084210CE
s=7 n=1 o=12360585216
    7   2012 000001  1691400960000       11520000 65867ED3 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000024200002200000000000000240000001541A53BD5922C016358B5114E0F739CD6B58D6B18C5AD6B520E6188410CE2F7356A52949424A528C4208421084210CE2F6B54A5292941CC62946210421084210CE
s=8 n=1 o=12370575360
    8   2560 000001  1691400960000       34560000 8742621D 0B77C5952440E1FFD8C22FEB9D5E1861860DBEDBF869D33B495E15776CE4B9D6AD4C376E5DA8B89698E9B712D74D0620CB6FDD2E7B5AC2A4CA6BBA8E492BF734ABBA53ADCD6AF46BA74CFA8D42496ED77DD0D24967D24C4A942769B5297C9E953953BF5D014AC4C9DE44735D351C0EABA655005EC6C96B56B4FDF3F4B4AB575E
s=9 n=1 o=12370575360
    9   2560 000001  1691400960000       34560000 DCB11CB7 0B7731342440E1FFC8C03FE6955E1861860DBF75954AA01271012EB76CE4BAA639CC6AF0953CC43298E74AD2D27EE9F2A84FA9AE835A22A4CF9ED78E492C3730ABBA7549CE6AF46BA67EF9F8CB096F3E7DBEC86F61A65CF28BF4B00FD384FD1267D45EC3553953E755A16C490EB5754FABA6A4F755784F9D3AA64932654FA1BA
s=10 n=1 o=12370575360
   10   2560 000001  1691400960000       34560000 88622C1D 0B7750222440E1FFBCC03FDF955E1861860DBEDBFACADFBB48FB63E4EDEEA0E0EDCC6A6F9F3CC42EDA7736DD6A7D5D539B059F2A74A61C022E6B42B8492C371B14D34D49D26AD46196A6AC90CB096ED77DBA07F110D74CF9F44889600C790EBAA256A1AB1096E164AB92BFA5514A0B0F9DC17D49FA97D097257EFD1257D6293D
s=11 n=1 o=12370575360
   11   2560 000001  1691400960000       34560000 0A7276C0 0B77381E2440E1FFC0C03FE19D5E1861860BD2B3F854E1C067AEB6B807E44DD8EA92A7EF933CC0E94B07311056B0D61A588594C34B0A1C2A54D4BEAEEA8D77509F534B4DCBEAEE612774FB3527E9AE5C7DC971C4F3534B0DED7AF0DCEFB71153FB33445361EAC550123F76E5DBCC2E6BBA8549F58215D5A5A4AA156AD7DD4373
s=12 n=1 o=12358643712
   12   2560 000001  1691400960000       34560000 1D94C436 0B77691E2440E1FFDCC03FEE9D5E1861860EADF3FAD015A2514DF6B4E8F120B6EDC58A4F9D3D888692B4CC0E5656FA18D7CFE8C4495AC2D7EF6BAB530D25C4C96B42A5ADD8D7E92D52AF4E8EA86FB6707DB97890C75A7AFE6C3A566943AEE6457C73AEA70E12C4CAAD2B7BAD3B890E782674FDABE7D49F53534D53E7D56BC448
s=13 n=1 o=12378568704
   13     30 000011  1692115425000       22522500 2BFB68AC 16000B0780043810038D0000000017000A0100023F02FF02FE0097800000
s=14 n=0 o=12378568704
s=15 n=1 o=12378568704
   15     30 000011  1692115425000       22522500 FD271B5A 16000B0780043810030F0000000017000A0100023F02FF02FE0097800000
s=16 n=0 o=12378568704
s=17 n=1 o=12378568704
   17     30 000011  1692115425000       22522500 2BFB68AC 16000B0780043810038D0000000017000A0100023F02FF02FE0097800000
s=18 n=0 o=12378568704
s=19 n=1 o=12378568704
   19     30 000011  1692115425000       22522500 4DDBD597 16000B078004381003110000000017000A0100023F02FF02FE0097800000
s=20 n=0 o=12378568704
s=21 n=1 o=12378568704
   21     30 000011  1692115425000       22522500 1935AEE0 16000B078004381003150000000017000A0100029F035002440046800000
s=22 n=0 o=12378568704
s=23 n=1 o=12378568704
   23     30 000011  1691980290000       22522500 02D85433 16000B078004381003110000000017000A0100027E02FE02850099800000
s=24 n=0 o=12378568704
s=25 n=1 o=12378568704
   25     30 000011  1692070380000       22522500 922EEB48 16000B0780043810031D0000000017000A0100022D034403250044800000
s=26 n=0 o=12378568704
s=27 n=1 o=12378568704
   27     30 000011  1692115425000       22522500 55D0F3DF 16000B078004381003310000000017000A010001EB034503AA0042800000
s=28 n=0 o=12378568704
s=29 n=1 o=12378568704
   29     30 000011  1692070380000       22522500 1BC3C789 16000B078004381003130000000017000A01000290034402610044800000
s=30 n=0 o=12378568704
s=31 n=1 o=12378568704
   31     30 000011  1691980290000       22522500 7E1ED71E 16000B078004381003130000000017000A0100021F0359034A003D800000
s=32 n=0 o=12378568704
s=33 n=1 o=12378568704
   33     30 000011  1692070380000       22522500 9C26A2A4 16000B0780043810030D0000000017000A010001DD035903BF003E800000
s=34 n=0 o=12378568704
s=35 n=1 o=12361482240
   35     30 000011  1692115425000       22522500 008C4F3D 16000B078004381002B50000000017000A0100027902FF02880097800000
s=36 n=0 o=12378568704
s=37 n=1 o=12378568704
   37     30 000011  1692115425000       22522500 47C0C7F7 16000B078004381003010000000017000A0100020902FF036D0097800000
s=38 n=0 o=12378568704
s=39 n=1 o=12378568704
   39     30 000011  1692115425000       22522500 1A1BE24F 16000B078004381003210000000017000A01000226035203310041800000
s=40 n=0 o=12378568704
s=41 n=1 o=12378568704
   41     30 000011  1692115425000       22522500 0E430B4C 16000B0780043810032B0000000017000A010001BA03580407003F800000
s=42 n=0 o=12378568704
s=43 n=1 o=12358041600
   43     30 000011  1691980290000       22522500 50272E6C 16000B078004381002F10000000017000A010001EE02FF03A80097800000
s=44 n=0 o=12378568704
s=45 n=1 o=12378568704
   45     30 000011  1691980290000       22522500 18333DE1 16000B078004381003090000000017000A0100023403590314003D800000
s=46 n=0 o=12378568704
s=47 n=1 o=12378568704
   47     30 000011  1692115425000       22522500 CFA27D9D 16000B078004381003210000000017000A010002D702EB01E2009E800000
s=48 n=0 o=12378568704
s=49 n=1 o=12378568704
   49     30 000011  1692115425000       22522500 D14371EC 16000B078004381003250000000017000A0100022203590338003D800000
s=50 n=0 o=12378568704
s=51 n=1 o=12378568704
   51     30 000011  1692115425000       22522500 06BA23E7 16000B078004381003290000000017000A010001CE034E03DB0049800000
s=52 n=0 o=12378568704
s=53 n=1 o=12378568704
   53     30 000011  1692115425000       22522500 0BE6A42D 16000B0780043810032D0000000017000A0100025002FF02DC0097800000
s=54 n=0 o=12378568704
s=55 n=1 o=12378568704
   55     30 000011  1692115425000       22522500 B913F79C 16000B078004381003210000000017000A010001E2035903B8003D800000
s=56 n=0 o=12378568704
s=57 n=1 o=12378568704
   57     30 000011  1691980290000       22522500 0283CB90 16000B078004381003170000000017000A010002B002FF02220097800000
s=58 n=0 o=12378568704
s=59 n=1 o=12378568704
   59     30 000011  1692025335000       22522500 B06A7B02 16000B0780043810031D0000000017000A010002360358030D003F800000
s=60 n=0 o=12378568704
s=61 n=1 o=12378568704
   61     30 000011  1691980290000       22522500 DC24E9DF 16000B0780043810027F0000000017000A0100020F02FE035C0098800000
s=62 n=0 o=12378568704
s=63 n=1 o=12378568704
   63     30 000011  1691980290000       22522500 178A3DBC 16000B0780043810031B0000000017000A010002AA02FE022C0098800000
s=64 n=0 o=12378568704
s=65 n=1 o=12378568704
   65     30 000011  1692115425000       22522500 F68740E0 16000B078004381003310000000017000A010002A7035C022E003A800000
s=66 n=0 o=12378568704
s=67 n=1 o=12378568704
   67     30 000011  1692115425000       22522500 53E43287 16000B0780043810032D0000000017000A0100023602FE03150098800000
s=68 n=0 o=12378568704
s=69 n=1 o=12378568704
   69     30 000011  1692115425000       22522500 6CAE763D 16000B078004381003210000000017000A0100027C02F4028B00A3800000
s=70 n=0 o=12378568704
mt=0x76bbb5905f80 n=71
s=0 n=19 o=12378568704
    0 271617 000008  1691304615000       45045000 B2058E8B 00000003460150000000094401C172438D63B240000000084E01010304004080000000151001E0051677085621308E800000030000030003260000B84B1001478400A2CEE10AC426D01FD0AA2A40B5C0DD991B951FB9B5610CC4E22F09F96049294B408683D173E59973AD69981F000A0B6A0B646D11DFC12EB67BDE7F0763AC
    0 271545 000008  1691349660000       45045000 17AD9846 00000003460150000000094401C172438D63B240000000084E01010304104080000000161001E005224BCEE10AC4268E800000030000030003260000B5F01001478400A44979DC215884C0BED3ABD019442F06D4CF148649275FE2E10D3FF42E6C71E47C382B0BECD8722622CD2FE143207FC83CFEA84C47C56F6C81191120DE
    0 594627 000000  1691529840000       45045000 03CC0E35 00000003460130000000094401C172438D63B240000000084E0101030421C080000000200201D0016CFE43310980A74000000300000300000300000300000300000302420001767302014782002D9FC86621307B00AD83E6F153AF6AE69D217E3935248B13745F00CB03EE95AF059825FD309AF881E43344F675D8DCA7A78A86
    0 274198 000008  1691439750000       45045000 EDA97E1C 00000003460150000000094401C172438D63B240000000084E01010304304080000000150001E0057677085621308E800000030000030003260000B7B50001478400AECEE10AC426BE5F9EB4EB616B1148B5474F251714DFE4B740A78D3A3D387C819F241245169AFDBB7C12B5B3C00D2E72E26198E3609BA2A3FA50ABF176B9
    0 271274 000008  1691484795000       45045000 172741B7 00000003460150000000094401C172438D63B240000000084E01010304404080000000160001E005824BCEE10AC4268E800000030000030003260000B8950001478400B04979DC215884C0CA97441E985B7E218A9C71F65C4C38D3593E80F51511B343D42764E558F803D527347ECA6CD274416D2176FB5FF3A2A1E76EE73B9A
brymer28
Post by brymer28 »
log comment #3
    0 590028 000000  1691664975000       45045000 BE8720F7 00000003460130000000094401C172438D63B240000000084E0101030451C080000000200201D00184FE43310980A7400000030000030000030000030000030000030242000174660201478200309FC866213067DF061DD5A5AF2AAE818BFEB6CD02001D3BB93513BCF1EFDE53B330F730A42DCCFFFD434CEED1D6BBB22BBD38
    0 272165 000008  1691574885000       45045000 CCFCA948 00000003460150000000094401C172438D63B240000000084E01010304604080000000150001E005D677085621308E800000030000030003260000BA5D0001478400BACEE10AC426CF37C32F0EFC27C8D205AC3B0145D898A60AA4822C1A00199832418F2F29FB0DF5EBAE9BF9A16D7DEB575710FE97783A985D835B23938587
    0 271278 000008  1691619930000       45045000 E88594A9 00000003460150000000094401C172438D63B240000000084E01010304704080000000160001E005E24BCEE10AC4268E800000030000030003260000BB4C0001478400BC4979DC215884C0D01FBC86FCF8376C2D7058DC080A152E06B995A9E205E5A0933A7EE0D362E55751C5D0C57935087FD527BE8291C54B5438494A8C97
    0 570925 000000  1691800110000       45045000 40590C3A 00000003460130000000094401C172438D63B240000000084E0101030481C080000000200201D0019CFE43310980A74000000300000300000300000300000300000302420001651F0201478200339FC86621306F231B07DB738E9582E9F1B4D808ED9A713EF557FDDBD641C8B684C8D44857F39CCFF82F2B8C223827ABFEF4DD
    0 267494 000008  1691710020000       45045000 0D6CE464 00000003460150000000094401C172438D63B240000000084E01010304904080000000150001E0063677085621308E800000030000030003260000B6F90001478400C6CEE10AC426D01FCFA2DFDDBF10CF2AEBBD981A7FD8C68B8668B3F85A9CF6920CA3480FD1D5C732FCBE3EE71644E60B2398B819E5DA49D32B8CEC06AB9A
    0 263368 000008  1691755065000       45045000 D3665C22 00000003460150000000094401C172438D63B240000000084E01010304A04080000000160001E006424BCEE10AC4268E800000030000030003260000B3FF0001478400C84979DC215884C0D01E948A902D7110739680D603F9CA202786AC2C86D83EA7BCD3290A2B92FE6ED85A58BA4B8489F5187FCBA83B5B491AE63A63C8B6
    0 567379 000000  1691935245000       45045000 A3A6246B 00000003460130000000094401C172438D63B240000000084E01010304B1C080000000200201D001B4FE43310980A7400000030000030000030000030000030000030242000164350201478200369FC8662130C26C1302BCCF7661F5A60ED502A718555B853976F269FBCF8D9B519162853B176CBE2B8F7C5EB224CA46EAFFEB
    0 260559 000008  1691845155000       45045000 771ADE25 00000003460150000000094401C172438D63B240000000084E01010304C04080000000150001E0069677085621308E800000030000030003260000AB3E0001478400D2CEE10AC426BEECC0CA222A3E0B9920EBD19F7E6778D62535C44255A7FB272B921A24E92A465427762BB39D6C08B9AE48E58AA9A562ED41761717E396D0
    0 259072 000008  1691890200000       45045000 4C54E32B 00000003460150000000094401C172438D63B240000000084E01010304D04080000000160001E006A24BCEE10AC4268E800000030000030003260000AC570001478400D44979DC215884C0BC21B616D7FFAF86F755236A9CC16200DB975E2BC1FC52F236FB7D1023DA494664444736211DCF6C93F0CE141805BD84D08F768CD7
    0 552259 000000  1692070380000       45045000 279FA4A3 00000003460130000000094401C172438D63B240000000084E01010304E1C080000000200201D001CCFE43310980A74000000300000300000300000300000300000302420001608C0201478200399FC866213067E2B6071ED6B80AFBF12C87F43B17EB796377783827F0FF0934E403C3AC45E0CD1EC7842AF0DBF22F6C00D36F
    0 253786 000008  1691980290000       45045000 B58D6169 00000003460150000000094401C172438D63B240000000084E01010304F04080000000150001E006F677085621308E800000030000030003260000AC380001478400DECEE10AC426BC21B616B3A567BDA562C45D3DAF8EACFE26B65CFE631AA010BF46A8FB0B749D443D85511FFF8B30D33D7422923645F82EFA124821C403E2
    0 255548 000008  1692025335000       45045000 603E70DA 00000003460150000000094401C172438D63B240000000084E01010305004080000000160001E007024BCEE10AC4268E800000030000030003260000AF360001478400E04979DC215884C0BEECC0CA219E3D23CB2F61AC62D1CE2C96F9F025D381721F26E4A0047E3172A2F81059E2973214C0E944044B64340091B95787BF18
    0 422008 000000  1692160470000       45045000 65D17861 00000003460130000000094401C172438D63B240000000084E010103051140800000001F0201D001D8ABFC856213E8B000000300000300000300000300000300000A380001145902014782003B157F90AC4260820F5ACF18AB87CFA169B21FF092CC4B8942E3B2E7EB6C0FC53415BE63ECED7F161E51D152ECF07D649E5D8833
    0 305885 000008  1692115425000       45045000 B8FF56E0 00000003460150000000094401C172438D63B240000000084E01010305204080000000180201E007425F3B843310988C0000030000030000030036E00000C8BD0201478400E84BE770866213BD64E951CE80A3524CF7B957CB06F14AA0A72A4CFF02A67208289443B6560DB5B02E962C4BE956A097CB636BEF635373D41553A4
s=1 n=48 o=12358785024
    1    488 000000  1691395200000         900000 115C07E4 C0F49400702C607B609F60EE1B81753DE6797807412038B69F6494FAF9867C5BB49F8DEA3E8A36CD341280451A42FCD5B11134C1A413225249121B8583F3679B61418DD06A2BE9B4886DE1E4FE6673A6E2991E18705408EE23CF9E693603EDC3B7083FD65FDA1860357B384FDDA391807E22803B25B2A183A6834B406D4CCE73
    1    504 000000  1691396100000         900000 165FFC55 70FC94287030608260A760F68111DA8ED0C52CFA1915A52DA7BA8FF7723961C51B2B21F2769030AC7A876FAB6BDFC4913C9C90B1AA17E945F7DE20866D007A57BE3902E0588E0FD0707B69FD95BB3AC624E1DA2A0FE3C56C98CCB2C3E40F71F2B08EB95A969F615E2780EE9C12D6CAEF0EB56B1136EC0DD8FD794B6AE30C55D0
    1    500 000000  1691397000000         900000 D2156DA9 20FA9450702E608060A460F478826727463D644B81F157586BB7CF61A9DEE5CB3D889CFC8EA15A12DDBBB9A3AA74B2F3732EBD371BE318A7F75087699D396CEC6E1D3BA1C0C35DE965A5A4EFF634D872C95957CF29497BD942E65373DFCE5642009D0A0F82D88BFD3684BF7972E419F7B155DBE48B4A382682E52E64F28121F3
    1    506 000000  1691397900000         900000 0863334C C0FD9478602E608260A760F72E95D3FAEB301357F0310C0B637DBE511939F4147013B0EE0E010A2E715A7DCFEFC6D7D065D92837C33D393798E8E2BCA2EF6DF87C3F2B3DA29A5FAE858EF52227BA3BBC598270230ADCF5E3A6A62D3EFABAA6F2FB6AF6BBB4406AE02C70CA45556D0AE62A7BB8B0A7673AD5FE8C0ED14DC0944D
    1    504 000000  1691398800000         900000 898CFCD1 60FC94A06030608260A760F640988CF267852733E5CE0D9BB6A594E05B0B34C0EA94DB2696C1272966BB48946078B1CAC3A1657C661AB3EB772B9A642F9FEDCD3419AC81122C99B22A57EAE3B8E10F2747A52558C0CF0F9C3C44E8BE776A94155189D138B480313FC000380D174F1C632F75B653B70F61A7AE6A928CB72CB1AB
    1    496 000000  1691399700000         900000 425BE1E6 20F894C8702E607D60A360F281099296241113B65A64B496EA6DE07287834224BD4AF8622E5FD5768D77A701F8DB8E4D52A9109039CD885878A226828624C38F3F9BDCC2E72352EAFAF8298158267744F939C003F91B31CDB8BAE03B3B625CFB7E8A1770F6204C3D74EB16ED7086B22B2A90E3FA8CC99FB9DB1B66E73FDB435A
    1    484 000000  1691400600000         900000 99A03F69 70F294F0602D607B609F60EC47AA794EE67DE878AFA580D8753F8D35EFC5A77834447B8318D8DC260C42AAD4079AAE2D781E80EB70E93E9B53EF0A655A7C85FD0ED15CE7AC8093CB03D62D95C2D109FAE2ECC69C9DA0DBDC49706E764849948E9E189A00D8FE50A555C7899DD07859859FA03874175E47E2719299048E8F15BD
    1    488 000000  1691401500000         900000 5F3B6EC1 80F49518602C607A60A060EE14B5DB3EE6AD1CE8C88BFFBC984AC7DF76B3AF33B48B551C90CCE8B772341DA55E52A0B3019E3A4BF89C18ACAB6E85B67A698C668140CC7BBAF97F57122BAFAF4ED1E794641E8507135B69AE9CC39A856F301486D9109FC41E8A70829DBF1B1FDFAFE212A1421A68D30674F8B0CDCDD59EEFA614
    1    494 000000  1691402400000         900000 B051852D 40F79540702D607A609F60F1154CACE71517DD5356A9EF2C71C7DEEF6022EF2B8BE3D8BE892DD4CD25FAEC3C6756141D0200A720EDFD40A73A17C19B3626C3DE2C4968F0469D93FC93A7B8F3829B4258CC66FE8635057F02FFD96509961A6D9A27ED496CF2C848DE6987C487F19CC3858CD962C1C7F93E78E98B375AEB3969D3
    1    494 000000  1691403300000         900000 376CAEB8 40F79568702E607D60A260F1475CC61176E1CB608CC8F701FA63AD9980FE1F490500CA0A49DC933DC52103A93BDC2B20EA483F3905CA25A6F88C960F8B8BA9AC6C0E23E93680E367D6D031DB3DC676AD3432EAAE410F01E39F8987AEFA6E6918C0EC6D348000A5851F4AECC7119BC80B9A6B2F0F80D064A642CB3982A9491A75
    1    502 000000  1691404200000         900000 EA1420F5 F0FB9590702E607E60A560F52479CAA230130E17C2AD0262F49ED9ED0A2C437FEF32876A7FA220B0D915F17A69F5D969B930F6BC33F65884F07B16B1C8FC9C1A502E2112046941FBD410250EC2BFA636BF49535DAC1CB3C1DB6146309A7CCC220D292B49D582C82124989154DC4C576ED0548105CA8A5690C467330F3851FC5D
    1    570 000000  1691405100000         900000 33FF402B 111D95B86030608260A760F78111CC79C67683ACD592C4AD23F85816985A922B3F5056B6604E683F7AE08A9EE979AB6A6F29C76056A9B07F1D9D67D416DF9505D69479E72CB675E0B54BF4692448B86298969786CA3992F6E0B30834F5F02BE3D8490E33E1C346FB22007C513367679E78A49C8D491DDF0BE578B9297C4C3AF6
    1    500 000000  1691406000000         900000 B5500589 80FA95E0602E607E60A460F47E91A3F2A55AFE554ADFDCD2D91BC8097CDC5CBF1E2627647368C13231C9C9E94D2ECDF6DEE4B924E2622CBA093452049B23BA9744CC50356A6D319B60B579D4095898BECF4C37932432D95D8D75A949E2BD9ED9444950F80DA036215625CD4D63099672F703690AF2F01EFF77D65FB5D6C0A0D9
    1    496 000000  1691406900000         900000 EC295111 D0F89608702E607D60A260F28109857F3E363D179A3BCC9DBB405E6126FF365A92F4A1430ACAAE367154C16E699C09285EE8CCD3520D1BA434A6D3D62490C5EB04156E813831B3D09942941C910C7AF73B74563DC4BA007D73C671981B0F04013D0340582B808E678084C178849284CE0CBE8F6FC9BCB3272C769FA891F67BE9
    1    484 000000  1691407800000         900000 BE8C2137 80F29630702C6078609D60EC67EBC8B8C6CDD59779D097C9283ACD961B911A2CEC5D2518ED738560DE1DE6A446754536B026755812CBB4CEC67E66C2F3594E6ECF4951CEE6243536FFE62EF531A31A59B367B8905721E546F9573F62B6B7E19AD90014B38044771F74CDE85DB159BB31AC46847169BF399E5B69CE46F16E044E
    1    484 000000  1691408700000         900000 352A54FD 70F29658602C6078609D60EC515B19622519D1DE7BFAF56E8DE33C97D6E4DB6AE86F9E5C3ED9CC465871322BCEBB76BB5CC8773220E303F2C10E38B94B978C0E0A99F8A44AA2679495A5757ED519B8CCA7ED5BCB8D0A872E358DB32C04B5959EAC00768B56952BB78F0C244EA4ED7B5D63998EF155D47FED8F1F1CEDB9AEFFAC
    1    494 000000  1691409600000         900000 5118BD43 30F79680702E607C60A160F11661ADFB398C4CF6CC8E159113D4BFA475CDF9A171C0C4D6947D6AAA1343D0AC35CE4445649663E19CB20D2C1806F1EBA57318E9DDD0DEEA440FF96A43303E0C8DE0F6FBBCACC61C8DA58CB578D958E4B2B270582E76DBDE80008E940DE6FCF6B2241B1E10CEA2AD0788CCE94B4E5D91A3B2BCB9
    1    492 000000  1691410500000         900000 9DE5FE3C D0F696A8702D607B60A160F00C02A0E36A4728F92AA7E047980872EFF8F25BB76A875E30D5999FA0259DC2F0037C93C8DC78483B65F637EACF406ACD9F6B172FAC113F2B85186D9114E16C4F07A1B23C121E579C083CE536359485135E453C8F8C7E880009EA5B94F81039917035BBCC570249FF8C0F2AF4C0455BA055452A0D
    1    492 000000  1691411400000         900000 4F456A32 40F696D0602E607C60A260F02E4F5A33AAA9387383D987AF7E2D88E86581B06095B395C7C920F0BB20A2552E99F3F59766CA5E32C83C8AE97C0570FD0A3ACEC56A40F5196E9A0712E214C0B63FEC4FEC761B2B642399BF88A332EC824F5F112B3995211BC000D8E17A4352C7B3A61E90B7FE1932E1C23E39C363E0C34138B903
    1    524 000000  1691412300000         900000 C91A435E 610696F87031608960AF61008111C238C95E517752F7A13072E27AE9275EC5DADC500D66E5E8945D22B13B4142EDBC621823568D452F56393E169AFE66203FC53159C0AC18A965A2D34E913EF8984D2A664C5CD165BA78BCAC7E4A8FBC0A1B7C69FECD0156DFC34E06AD397409AC8084F12015CA70AB12A459A87DFF381446E5
    1    508 000000  1691413200000         900000 9CBC5DF6 C0FE9720602F608160A760F84D4F8982F0EB3B2D0FD3AD14229539668D06985E709DCAED26CAC913490A642E3EED3320C5DD5861BB58B549E6B98FBA966A14313938C423125B62825E8A538E6834AABCCD824F6B596E5D0E6B99B2ED80D9708D43AC6E792C8A6000E17415D62F5DAB79D13414EB28844D5EC0F752841D488191
    1    502 000000  1691414100000         900000 A2A821E0 A0FB9748602F608160A760F5810993BB046B80F86156CCB3AF1B16CD63D0EA5C190AC1636E47A45138074FA1C86A26CAADC4125A65910BB1CD23505F1C6485074FF7917019B8D2358BDC317A3926765E9ED184368EBB586A18052CE0DA2097FC7430489502CC28004B32804471DBAF5CA37BBC14D0C56C42A26A70B3036C452D
    1    488 000000  1691415000000         900000 BF42DE94 40F49770702C607B60A060EE02F9B09E53433CFB2CF47B0945F72AC6B647A36F17B470B9DCB5CB29B0F27618CFBA03D10DD67DC9E7EDAA4BA83B0678392F748E0622ECE912ABD0943E586D8BD8CDFFA2AB0E6751B87F2F443BD856AE8641C8C74546769C8084C039913C4747821441D7306C56CB15B7CDE7B31BECB44D83A527
    1    484 000000  1691415900000         900000 4992C0F3 A0F29798602C6078609D60EC6EB2530E22DE777E1E8A3CE59BCB07995F299D3FB4C17164255E2D3E38E722BEFCFC23AAA74E52F0CEA3D14B6FC64B2298A6C6DE622D68589F73BE92C8F6EDD7526B94D4F35A1437294C76C6A425AAA6CDF2E27AF3A4F26278256DFAF351FC612ED98DA8322A4B547A490F7E18D7B39505C56921
    1    480 000000  1691416800000         900000 2D3FF11B D0F097C0702C6077609D60EA66715B5DB337D476F31C25A5C31ABA31E0D0B65ABC6B97A67B0B53AC769610735ECF9328C6365AE097EE1BA09BC6E4ACFF86C07A92EBDC286A9510EAADF0DEC374D249A1BB60D1E6D958E3D7165FB754FD2A169AE0002F6372ABF5B925CD19175E6DC2DC6191DDA7B871378337F7BDA17A25DF20
    1    490 000000  1691417700000         900000 ACC04BFF 50F597E8702C607A60A160EF03B720DC3E8FA5360B430EC0C33A39E8CA70261EDB1A6F18014685688AB9C2FBA0CD30612ADA65BCF9A66BC197D279D1A24360528A09552B4E1D4A78D389DE9221E0D06A15A0CCE00CB3E205988A35427CDEBCAC980058AA0CB4D01EF0EE4A82BB8BF0E5F32A2EDC712B259447A7E173A9760CB9
    1    492 000000  1691418600000         900000 A00922AA 40F69810602C607C60A260F003F77C7C083EAC16F67D131E7BC921E2E2C1E25337BD00571A2D84BC9ADC483CDA1A22155F2E76A6DAAAD0D59CE91AACEFED38D4A6CE737FC4539B17AB2E687B4BF89F83B06E94FE3F9718B16DD6A378D77FFEF18A00E4768088E184BC435728FF56FB4616C5BFEB2F676A82F8F31EFA78EF684C
    1    514 000000  1691419500000         900000 E2F7CEFF C10198387030608660AB60FB8111CB03FBCC9AA8072A350755D5A8E0AE2C703D70050C8FC4CF62D8EFDCD7F14DEA29577B3B9B0DF8D4C61EA9DE1693B77AE22C5FD086593D38D8D094CD30C1961C983156929948AD55CB42B558656991A99C976F2B5121521A751F2000E2BE8044837826996D7709E539FB87578166A6DCDEE6
    1    498 000000  1691420400000         900000 B19AC039 F0F99860702E607E60A360F31C7CBF86DA05AB24C6954B7D093E8C7BF066FDF6534CD10BBA483291E535A2B9D941241E6BF72BF83CDD729261969A307C13161BCBCDB07B5CA80A634A33DCFC9EB5D3DD1DB8D91B0B3E43141AD514017E61B7D99359DA36C0007055804270C4F4470784EBE5F1CA66455845CB4D534192B34FC1
    1    498 000000  1691421300000         900000 689C18E7 90F99888702E607E60A360F31E271568C5ACA9A3692F04B23AAD5818C406516E4E98608FAFEE18350CA8D7165AC22A0C8DA3741ECB388628947F8B21F17DF5E4AEF86CFA5701B928B8363F4D06507967FF0470B81E47DEC5947196794A595766C5BD600DA000408458DF1A931DF14C93ADF4A877AFA5191CAA6A2457D9EA1B41
    1    486 000000  1691422200000         900000 04EBFAFB 20F398B0702D607B60A060ED2D2B67F8D48B308091DC602BD611F3258EBC44191BC5079C18058830E23A73E08474D7C80AF7902FE42CE57B51AB01232EA9868DE2F7A9437767E6C46AD6337568372B8218CA7E63E95877C572421E668C3FF3C085A1D9009B1028413BF9648F590714AB581FD36DF520F7FB644F5503514C4F36
    1    500 000000  1691423100000         900000 55783BE1 E0FA98D8602E607E60A460F436F75200DDA090CADBC511E997FDECEE56E89647D47BE9F692A7DD2541C610F9A9D69ABEE345329ABDE408AD587708F4572A64FF59BEDE4B578BFC91EB256C1302063C9B5FB150BBBD3D8827DE8870FF8831F8B71C7018BF94E018AC39C7C7D64C207DA7DFDD07E7EEE443B9DD2CF7276BCED2ED
    1    502 000000  1691424000000         900000 832257EE B0FB9900702E607E60A460F52D67BA9F0BF8A0948424821F9E1F5BAD6B0B05EA75432F5E547618C12E0CF5B05C5F0EC76156DDAC7C5AA7EC0CE369653B5ED501499876D4591301D461C4B5EC35F75D9EEFD534AFC09E89120962E9D6D8E8D0A6A5C848715400CB9F27D132A9FA53A9B1306C46482A1A69082251461A07A4D7FD
    1    502 000000  1691424900000         900000 DE2BDECE 30FB9928702E608160A660F53531410708F632659FE90ADAD7C9067B15C1A06C2A0BC961A743B0CA3BB115929C6EB58584DD3CC03A42795928DFB79464A1378E4141B5B181F81043FBA7D9FAD1B6D9666F07D84B8F15893E04A1ECD18DD4F2C47A8C9E9DA318F4AB1EACA84602B91360F287BA5001117F8472A995AA2457E977
    1    494 000000  1691425800000         900000 82704FBB 30F79950602E607C60A260F115A4BA551C5F0BB9F0D41A39F484D8D55E74335CB3BB0FFCACFE7B4671E2326212DB9BD3E689A6FA6DF7594375C6A2B0FF3E48A96AC652D7C1CFFDB0AD2648D58EED22D479A566946C5EFFF066ECAC9DEA63330ED603EC4AFC00A7F70A978072EE6D0DEAC331B4535345EA3C3F257DBAE4F1C9E2
    1    522 000000  1691426700000         900000 CEC12DBE 210599787031608960AE60FF7718F64DFBB337FD12C5A22ABAAA5CE30567E8D8D86C548B25E3ED40AC4DB28A6C848A5D22753F232625CCF4DD5D2313B85D1334A294AE47D40FE84B245C85CB56DFE3546B5DF45DBB19541F042495690294B1E5F3A874065466A1321B89240040E9804483065AB43B2E7B334B324A329ABA2795
    1    502 000000  1691427600000         900000 E14EA101 30FB99A0702F608160A760F56078B742ECEDDD7E7D1EB7BD9FDFBD77577AD7E426706E61CBAFD662086E6F86A05387EE4F6FB8E0B3AEADEAF1CE4EECB884A301F26D4D4C95B382A6530EA0E4832709F176B1ADDD4D5E75B56F0666D28C7A3AAD09D9CDCABF9D9200C0A640ED348D610E26409A43B58F7A634D6D727BCEAC889D
    1    502 000000  1691428500000         900000 30CC1F8C D0FB99C8702F608060A660F52712DB652C7A960640F6852A80B755CFBCA570709B878118E32EAEACCF6CF735547ABECB48B561EB9858116DA49D8844026719155C71A2982987211C13F77930D816411A1A9C474D433DA33FF1D09A1F4ECC2A3CC77181DCF432E14000D12AE089529BB31061406325C0A247925B91B897720CD7
    1    490 000000  1691429400000         900000 80D2E640 00F599F0602D607B60A260EF810990DB3362CC276DA198C45A3EEE8365285FCFAAB25EB90D34455656F489B6BD3FA34113DB95D8EF971830EC76312FBAFB347C932F35AE5306ACEEBF13019F445AD350F9ACA90C3CE5E7674786C4B30F87EF32EB9D530014BC8109A1344752DBA7CACF71CDFB16F63FEDA65E4252FE37C5544A
    1    480 000000  1691430300000         900000 CF17203D 40F09A18602C6077609D60EA1E464A4B8C972A16176722666921E97BF90E5DEFCB04257B1EDAE3FB64070A89CF4CA35F977F4FEF578EF2FF0CA5A72AF455B45C96C78AD906348CAC4CD5B7913D484D86DAADD9A7D6DFD5FC073A9C1B3CA707254D92BBB4702AF329D6AB14BFCE1D9FA43137BE840E1F95CDEE2975CCA1738756
    1    486 000000  1691431200000         900000 B17EF146 30F39A40602D607A609F60ED65CEE824BB2816C50828075464885AC38DFBD34C30F19CEB3D4D3E048B71461617E9FA2926C6582ADD7D284ECAC15F309B4C376EF25E21CF81067671E4A46B28BF96DD563F390972AEE3E1DCFCA0496D178618FCD4A22800998031237E38A7F29296119555454F14DA35A823EA18D4992E39BB3F
    1    484 000000  1691432100000         900000 87699538 B0F29A68702C6079609E60EC174A25160402227501108878C205891C422B055FF3309C58EE1F65B7D247C7170B8F13F52D6DA9378A69619C2ACD6026148B833800B994753CBA532F97164F4DE9BEECD53A2786016DD0CE4424A7F9AA1106F1C616CC98C80C7F824F5F7198109AC827E2C2F04907DE745A0C296C7C40F49F463E
    1    488 000000  1691433000000         900000 52FB6514 90F49A90602D6079609F60EE5D5519B3980B14FCD25CFB7DB0B72A8FE67FC107137348739F68231278965221E223A90541355C481524A4C2D95D3EB0C8E479AD0B77B82DC34A6EF66799013E4AE4BF5B07C5B9D3B825D05FC7068827574BEE0A30E6664785D75E83EB63DF3DCA186080E47FB5B0A68499E92B57983ADE6C139C
    1    490 000000  1691433900000         900000 7257EF90 90F59AB8602D607D60A260EF69C95AE2D585A331624B3925A89E37515332A31F7C1C742226DA68B8A85834E74FF499D518C8ACEBF2BFBE38D10F564CFE31DDAE3D686AB22FDFD59B3D02DDDC61DBEDD17283161A5183A619428BE3D254BB3D164501FC9628204274F4D3149EC09451892C853B1CE970F26937F16D2268B20888
    1    496 000000  1691434800000         900000 6C48403C 30F89AE0602D607D60A460F25AF929CA1C5ABA80D2FFC370F806011A16192F4CE903F1FC695C1207EA3EDA62E565B58D1DF3AC25973CD982C53AF3513BA48D3C9A090D7AD344CE99E5F9E2CEE943AFC6E6175EB9C44A6C735B2B12BCA089D336DE081060914F7BBC979A4B05F4477F55B6692EEA772898135764B4D1D3830208
    1    488 000000  1691435700000         900000 FCB4D1ED 60F49B08602D607B60A160EE5D6973BD3778D1F6EF0B806E2B00FA3576DFB6A75F96105C21AE2985DB643CE51F9986E4E77F3F9C4F0F0531CE1B6E92A6A2A8BE4178EC51C0DA4FEB0C37CEE2C4016865671D28F8E9CDFD632AEDB7139CC384B71D076C00B11D0BB66A152D9015325476CD1856DC26395F3C2028A05103A801FD
    1    484 000000  1691436600000         900000 99E2EB14 70F29B30602C6078609E60EC5EDBA9FF7CED838C33B672B70F53AC9D8872FD4DF4229CFB180DF527F7A418957C155C1B13F2656E743F636DF9A82B8FB57B44CC2A4BA605107F96580EF9FF71E90DAE38556247B65B0DFAFACA661509F9FB888CC9009EAF0A2C79C5935770A60ED7DD6BF043607E41D870EABBA96795EC5432DF
    1    484 000000  1691437500000         900000 B33A39B0 B0F29B58602D607A609F60EC72975393F05AB2B9A96ACB99125C6B7BD1AE724884B9A0314FEAA8D222A52835E97F94070E1DDF5566D2B6CF8466AF658645F9346C9E7F51E066FCB4AA68B6D734EDAFEB55171F4A9A5334BE89E884B3B1FAFD4864EB68808E837B72AE269D5C1F207F41EC3EE9F418DCAE6F98C5E7FE785E58EE
s=2 n=25 o=12370206720
    2   2560 002001  1691435520000       34560000 1FA1B319 0B774A712440E1FFCCC03FE7955E1861861056DC07B0DFBB514E7574E8F0CE869D1DD4B69F567E82BC39B7465AAF0A12A855B53FA4F75C2CE96DC1AF5DCC67EF946B7D5DF3A7D4A1537CF9F3B42FE2577DAA4EF4ADC1AEA54C3DA952D94A869574D5AB217B4E13E54BB5BA52FD5267D4A943855D53E7D1E13E4CA61BEAEA68EB
    2   2560 002001  1691470080000       34560000 F14A79F0 0B777B0E2440E1FFCCC03FE7955E1861860EBDFA1EA99D27795DCF11C7E4D1DF0E8B06D092C286D2B43851105D42F6C1D8511A577CF9FA986FA8D77CFD4C37CAD03A4371FA97D69F3F7C96C25ACFA2D77DAA6BAE5FBFBA32B25E292C8D18FB5704CFD2C1850DEBD7D0EDA080AD0BE6CA2BEFD6F6DBB2AFB55444A69AA7CF9FA9
    2   2560 002001  1691504640000       34560000 6B0DF300 0B77B1572440E1FFCCC03FE7955E1861860EBE3B5EC95D18476DD7422F30B5E089CDBA549FA15CE953B71D53425546C1CB521D3E7D0A152AEA76264AFABA974D762A550A13A7CF9FA9A6A9F434B4E2577DB25889A2587CFAB255E96C395E82B6F7EFD3252B4ABA57F4A1214D0B5D2A3B1F3E7E95FA64CE9EEFA54DF3E835DF56
    2   2560 002001  1691539200000       34560000 5200FAA6 0B7709A32440E1FFCCC03FE7955E1861860D82BCEB89C90DA301C7025438B9E04A8EF6CE92AA8746B2FAD2486C24E5D22A4FDB3EAEA61A986ACABF7CE5F95A30AE3E7365052A4FA13F7E92152AEAE2BE7DB2A4D55F6356568B6856D2D87CA9F544CE6B3DA501C3D88994D67BC1F524CE9DBA53B0858535D3A97CBD2D6A8B613F
    2   2560 002001  1691573760000       34560000 166F8ECF 0B7765262440E1FFCCC03FE7955E1861860F21526AEA95AAA185C6F7F33AB6B69B32B734952E7CAA92B7B1F3437B9D2BE88417584309DBA4D09D5816FA3BD61322396B5152A196DF258F0D4AA75470F6ABBB975ADEABE15A10E7EB9CC49D4A1BE730E1BA4AFD25820AD7A5796AE6B495A3D6E70A1428EA695D22F9ED8435DB3E
    2   2560 002001  1691608320000       34560000 63260A76 0B77ADFD2440E1FFCCC03FE79A5E1861860F1E13FD74C73EA34DF584AE24BAACBE9277B0D2BEA8829404B0DB524CE9EC384AD33A54E75AA7D5A9575546C8C7D096EF7695F3F7CE9EC0733302AA4BECD77DBBDE9078BEA50E13F42A70428CFDA527B621A6AD714BEA4FABBE8E9D343804BD6F015AB850A9D44CA6C3986F976B7C
    2   2560 002001  1691642880000       34560000 7D3D349C 0B7703A32440E1FFCCC03FE7955E1861860F0E9585695FA6A2FABEF54E24B5E09A74017BDFA8C0E6B437D5A9BDAAFDF2AB8F9CC35549F3EAE99D2B514DF427D5A9583522C24A8E5F529B11CBE7EFAEC37DCAA7E9693D7B0DED27D9A93EA695F567CE9D42A561F2A4B2152DA4A6D584B5A9BB6AF9F3F74E9F5753612BEB70A143
    2   2560 002001  1691677440000       34560000 10691169 0B772E212440E1FFCCC03FE8955E1861860D71F57870ABAB5309D5755497B9D8B0843434CB2986D37A7A6FC8574911F53734D33E7CA9FA5A54AD4054869A584A61BF3FC2156809693A4AFE93EAD5E2D77DC537E8558C5E8293F42F9D427CF9CD37B0AB542696DA67B5E48C7299E5BAD612EB74E9F4374B9F3E86A95A5AD5A9BE
    2   2560 002001  1691712000000       34560000 280D0F78 0B773CD12440E1FFD0C03FE8955E1861860F5EBBAB89A927495DD5776F304EAE99CEC4B5D0C2854F72EA4FD2C4195D525A6F9F3F534A8F0A35E9575499ED774EDD3A417522A7709ED6550C6C3A6965577DC584AF66CEA695553530DE577EF9F397CFA0D787252A576AD72574A5F3E7CEA13FAE969AE7D49F56A8A69577B4DF3F
    2   2560 002001  1691746560000       34560000 C7D17064 0B7735BE2440E1FFD0C03FE8995E18618612A61BAB749FA2831E76B76DF0BA869A92EA69952988D61267CF5F47AEF69BE7EF6BAA850D2BE7CAAB56AF09FAA7CFD25771B10CE4CAE73EACA75A6B55E2D77DCB9A111742855A1A572FBABEB8E1F3DD7716D72EFD33E75010BEAD0DF3E56FFDD2861A6AEAD591ACFA1574F46226A3
    2   2560 002001  1691781120000       34560000 B96D31EE 0B77D8592440E1FFD0C03FE8995E18618610AAD3EC0F95AA84AA7437EF24A67C996DD18FA13E80961274AA955776835BE86E9ED77D0DCBF4AFD5267D0DCBDB0992D77AF9FA087ADF3E730DF267D5EE707DC183971FAE7CF9FBE734ADBB730DF39AEED12AA4BD73F4B615517D5DED85367CF292E8CE70E1AB733A7BE7EF2EB9A6
    2   2560 002001  1691815680000       34560000 89ADC68C 0B77439B2440E1FFD0C03FE8955E186186114ADA2B6FA0264911AD756E304DDEADEDC52F95BE5496D584B4D4D754A9F8CD8E9F3E7D59FA5AE9952AA4FA9574AFD53E735D53F2495F3F5349F3F72FE2D77DB258519DD8A6F64A5AE869C34E81F5B4E954BE86EA8BE88F5F518CFAC3E24E5FA9855DF4D870DF40495DF2984EDF3E
    2   2560 002001  1691850240000       34560000 F47C1FFB 0B77A8392440E1FFD0C03FE8955E18618611079D6EA99F3F52FA96E813183A8EADCBF535DF29803692B74ACEC2550A1A58709D3B4C99D39B095E6BAEFA13F54A94C2A4F975354F9FA5A6E6956AEE6F577DB2AA3462498891CC2B09933EAF075C2DF5D1D6EA894DAA70953A735CB24ACFE8D7AEA5552AEFDF91B75A14286AA0C2
    2   2560 002001  1691884800000       34560000 0470A11D 0B77A81D2440E1FFD0C03FE9955E18618610FAB3FB6BD32B70FE9BE7EF61BAE045DA5550953986A953F7D5DFBD74F9FA17EAA8D84C992BE8EA6BAA7CF9D3DAECF0AD79D61AA4BCE9915ED5C44AEFA2D77DB3F7C3137686FA98FD8E5FBA86AC642B70B5C27CFD339B6A61BE7C929A9AF0DF3E490EC205EF6C21D5617AA54894BB
    2   2560 002001  1691919360000       34560000 0D7BADFC 0B778D432440E1FFD0C03FE9955E1861860FAE943904933B7AFAB5B55497B9B8E7357A36DF3EAEAA72ACD0DFA886E9F2A7CFDFA64AAA93F7B0DD3EA6E5DBD8681FD741753255CF9FA3B90D1E0AEFAED77DC1582F9CDDB8F6DB9B75A9BB4AFD2A5A74E1BDA835F365685D3E7CF9F3956E938D535DF3F7D0A6BB5BAEBBE7D59FA5
    2   2560 002001  1691953920000       34560000 C84E4A39 0B7725622440E1FFD0C03FE9955E18618610BA957B6AABAA8361DA94ECF0B9E095F477D49F3E7B5EB3EB231F5754FDCAA7B250C772FD2AAAEA9F3EAEE5CEBA6969B9A54AB42556DF4C555DF2BAF015D77DC29A691EE25EF94C39085F5354E70214AEA1C1B709F52851ABD5A6FD042B0A5EBF731E3BAA4A5FC34B1DCDC41C1539
    2   2560 002001  1691988480000       34560000 E82DE1A6 0B7790DF2440E1FFD0C03FE9995E1861861096C3A90455407AE9DDA76CE539AE8933E7549ED68099EAB851DF2986E6DAAA5144A97CBAB42B6A9F3EAE952F054E9CEA9D5DF0D5EFAB2A516E9A6AEFB0D77DC911AAF5C94CA97B4A6E96EC4CA5FD27B508DB7EAC9527CB9EC36D80DE156FFD4EFA3D2E89C8D87B4DED822F97B983
    2   2560 002001  1692023040000       34560000 A55D2C97 0B7733032440E1FFD0C03FE9995E1861860F0E1BDF0F9F486F829701C9244E7CFD3297D5ABBA54FA6C0450DD3D90D5F3E855D2D822EA190B7089A65485D437CE9ED6AEF92D24BC158E17C1FD6AD60BF07DC3E6CFA1A5B9C214DAD126D286E57304EA35D2D7397A4AF6DCD273AF357B10F8CEFAE3AB51092B4E4295B7E92C2673
    2   2560 002001  1692057600000       34560000 CF6EE7C7 0B77A1BD2440E1FFD0C03FE99D5E1861860F5AE26C0992C47AA9F6F4E92439B895D41D75D541A55AD447D0DCD852FA93AA6A9CD3588216AB6F6BBAAE9739588333A67296E3A4D09539A32539184FAED77DC3F6903B22434A7BA7EFE1A9C0F68C995439B8EA1A71B628477D5B629869DD387D4762A7D09B2B54AA9D286E9F3E7E
    2   2560 002001  1692092160000       34560000 6BFCC102 0B773D232440E1FFD4C03FE9975E18618610FA1B9EA492C852F75D8267EDD3D6E92C1A6FA1D24B61F21AD727517F0A9527EF95524D5D4BE84EABBF4A461D2AE6BAA6730DE5B3086B5B4971F526B02C707DCA590EA2126A99F39A55E1A64E81F43749533E7D5DF52A4F9F527D5D6BE7EA9D4673612D7AEF9DA55E95F90E10959A
    2   2560 002001  1692126720000       34560000 7ED7BEDF 0B77C8D72440E1FFD4C03FEA955E18618610F6E89B69DEBFA496E431CDFD358EE5CEF754A1BE730A1BEAD5DFBF4B47625AD514BE86A94BF7B114BEAEE9F3EAEE5752CB5EAC84B5ABA5554DCD2AF3A4707DC2B86FAB4374FA1397EFCB218E99F288EF953A854A1A9AE9934E5499F5354E6BA654A9FAA7CA9F29AF5DF4354F5FBF
    2   2560 002001  1692161280000       34560000 C33A5C88 0B77F6FD2440E1FFD4C03FEA95DE1861860F4DFA1BA3932B794ABDB5CF6425B6F9D3D7EFD32E7B5ABA6AD612C27D0AA117D0DD2986A933F4AA95434C99542A6E6157795EB42A50B5BE83614C27EF64757DC4F4E9693F7EFAC1B7EA9FA57E97556A35D73EAEF96D7A699F2586F92D37CE69C29E9A92A7EAA1A653110BE8509F43
    2   2560 002001  1692195840000       34560000 B05670E3 0B77B4252440E1FFD4C03FEA955E1861860EAEBBAB69B5BF72F9F6F7EDF0BB7485D29CEF9F567CFABBAAD5DF4354E94D7ACFDD3E5CA954DB6AA156851DEEB84AD4D6A54A1BE4CF9D5283ADF53534B8F07DC4454E77AB7EAA8B8B95A95688968D67CFD2C28EFAB567CFAD56ADAD54372FA9536B612BEAD612BE7D0ABBF52F9F56
    2   2560 002001  1692230400000       34560000 E22F2DD6 0B7757612440E1FFD4C03FEB955E1861860EBEC25B6A9FAB515E9BE587D8B58695EC34CFDCC27B5E1AAB51E9C186FA33AAD012BD870A13F5486C25A549ED7CB5E20FDF0D4BF5509FD17EA61A64AFA4757DC43A896D2B8CFABB48EFDF2E5BADF2652E6BD3735DFA9854D33DAEF9F4353997474EB5F56AEFD4C2A71ABAE4D36B48
    2   2560 002001  1692264960000       34560000 144C803C 0B778A0C2440E1FFD4C03FEB955E1861860D72BA7D36158EA30DCEF7EE2E3AAE960C37CAAC24B6997537C99FAA7CF6BBA7EE9D3E7B9E9BA7D0A8D77EB9CD37CFA008735DFAA535DCD3735DF3E4CE7BBE7DCAF7C877BEA8E9ED354E9EC27EA9F3EB6BC924A659F2A86E5ED74CA9F4DAEF9552A6F9F434CF75BDAD6EBC373AE93E
s=3 n=0 o=12358637568
s=4 n=25 o=12370182144
    4   2560 002001  1691435520000       34560000 104A3559 0B7745472440E1FFCCC03FE7955E1861860EBE13AE8ADD27710AB71447E4CEACADCC4730D4C28E82BAEAEAD2C2B095F267EA6B437D097B9850DF427D4DCC354FC45155C21B64CE9F2AA546E25A4FA2707DAA5C4F92DBE2992B5E2A155C4296B575EB958BACAABB574BE1A4AF106527CFD73EA55D53E86A6BBF431C8C37B5D4D6
    4   2560 002001  1691470080000       34560000 8ABBB5AB 0B7767252440E1FFCCC03FE7955E1861860EAEE08E14DD13790DD6C4B430B9E8ADC44434D13A5499CBB79C8447569619CDEFDED6AEFA166B54B5544B4A94356433A24B4E13A7CBDCD684FE12A7CFB6D77DABE90FA259544A0B97EE6E8C4CFA1465EF9FA5434DEBE4B7339F870E155D74D5A27359F3E7D0E8D7835EBBE5699526
    4   2560 002001  1691504640000       34560000 DCFA2C99 0B779C3F2440E1FFCCC03FE7955E1861860EBB8A18EFDF13729DD9126DFAA5E03A8C44CA922AD8820D97D0D5424E92BA1AEAD3267D0ABA9AEE9F3EA6A692A6AEE9427D6DF5352FD33A4CF6BC35B0AED77DB258746261AF0D28C8096BD1AEF6C2B22F9F907D4ABA0A74DD394EEA73F20FAE3A86960DC4D097B97EAA73A7D0D2D7
    4   2560 002001  1691539200000       34560000 150E5CC6 0B771A2D2440E1FFCCC03FE7955E1861860EBE1B9E0ACB9182BE75A807FD1CD84AB2F3900EBD8F395437B114D6AEF9EBF850DD2A4BBABD2AD5A9BE7D5A9BE70FE142A5ADED77CF9FA574FD5A154FE0577DBA47F5C8BFE0FA8BA870D32A7EFA14754F9F3E7D0DCA672AE93D7D4DF3F795E143CCFD3257D5A1BF4B1A356AF1D339
    4   2560 002001  1691573760000       34560000 57E1A595 0B77FF142440E1FFCCC03FE8955E1861860F116D3AEFC953795E9D276CE4CED68A92B52F9F3E7E85F2B76A932A72FA12B7CE91427CF95BA4B5E8DF74A30A0A8E60EE7D61EC1A6FA73DB79A72D86FACE183BBE574AB4D7FAD56AC0F932B7AFE6E5B8E9B2C0581F4283112BEA492BD748BD0AF7F4AB5374A6C41B8968EF80354C2
    4   2560 002001  1691608320000       34560000 0256E46A 0B77A7C62440E1FFCCC03FE8955E18618610BD2D3D898926A2FE96044CF135AEEA12C3F6D5A586ED244731A9BE5101CAAB0A6943A4F9D5286E61BF7A9D4BE7CFABB9712613B24E5F3E730E92B4CBAC707DBD87D4D4BD7CF9F39A891F427D49FCD9CF9EDBA5829267B7EE25510DD268549FAEA4F9FBA737E943A4FA13F5D49FAA
    4   2560 002001  1691642880000       34560000 82F7FBF8 0B77C9052440E1FFCCC03FE8955E1861860EBE158ACF9FBE7B5B3754CCE4B9DEFEB57434976A6082B3B870D2BE7151D26A50D4D7A4F9FA9AEA363EA496E298CE61D1D4FEBBE4CF9F4D7D11CC374AAE707DC3F86821BD74A9CBE74F9ED7ACF9CEB82FA943804A9A0A6EABBE78FD45BAEFA1577AFABD2A6E9F3EA6F9D437CE9DA9
    4   2560 002001  1691677440000       34560000 78CAA29E 0B77BA472440E1FFD0C03FE8955E1861860F0EB53E09A126AD49D568746EA0E0AC8BF4B5D329B032DA77AFA1D17EA6C0E6AF9FCE835DCC44AFA9577B5DF8D7E961BA6911EAA56FA1299D4DB3EA55B8F07DCAA84E68D684F62257D4C8AE7D0763D735DED77F0E13A7B6F82574955527CA9F57A4EA94774FD2C37CBDCC37E835A6
    4   2560 002001  1691712000000       34560000 4A8EB6BF 0B77524A2440E1FFD0C03FE8955E18618610FABBA90E9D0E8311AD376F57BDE89A8C86B5D0D2AEA77AA7D09CDB855D525B0E6196536A95BA4E763DAD612BE7E8695751BE93DAD2273E1CA69B986FA5577DCAF1B4C5AA869C925D30DEEB754DF2552FA93F5572B564CFE13D9CB952A9B61257B0469BE733D5AA7C561D2ACFA9BE
    4   2560 002001  1691746560000       34560000 7BEFA209 0B77EF6D2440E1FFD0C03FE8955E1861860F5EDBAB838922AB5E95756D243AD6A9F2B72F9FB988D5F26A4F5FBF56433BE7EFD4AA854D32A4AFADB9AEFDD288FAD2DB7B0A139B0BA991A1C213B7BAEC707DCD423306C8BF46DD6A6E9D3E7CAA1BD9EDEB95551613E7D4D54DD6953A0AF4962490321AB6CA9FA5750ABD3554A753
    4   2560 002001  1691781120000       34560000 1E9658CD 0B7776782440E1FFD0C03FE99D5E1861861296D3B8EFD3177111CEEB26E43B72ADF2F530A1A9B072BAB72B9F3F7CE6BA65699ED774FD325855A2124C95F3F7B4D54253ADCD2870A15342F9F2754A65577DB96EF39FAA495DF3E86FEDC7AE89EBFBD43DBA83C274CADCBF73BD3BD86F783E6CAD2AA87061D283014D354EA73E85
    4   2560 002001  1691815680000       34560000 CB74ACD1 0B7737562440E1FFD0C03FE9995E18618611ADED390993574ABAB734D9584DE0AE64452FCB3D7EEAAD4CCFD0BD86FA1A58D5DF2B4C95F46AEED2BE7CFD73E4B0A13F74994D77CF9F3EA54D4BF4AFEE707DB299DD92F14D0D4DC70ADF52A4E5FD1A8F6942DB09F4E850DFA6A4F9FAA5503D30E6E8CE0AD32684FAB6F874304F7E
    4   2560 002001  1691850240000       34560000 EACC9229 0B77B5972440E1FFD0C03FE9955E18618610FAB5486A953F49AB63EA6F5838E29693F4B4D2BDA736225D71DD564CFD4BE86F9D3E7D0D32587392D84AE9D3E7D4D4D2A3C12C286F9F3DBA312597CEA2707DB3FA2E1FF288992A4B79A9A6D51DCC3874A93E7646142AE961CE5498652A56E9BD4CFD2C1B13A13E7EAA03D8D49FB9
    4   2560 002001  1691884800000       34560000 E4E106A3 0B77C0252440E1FFD0C03FE99D5E18618610AA13FB84892B710E9D24EA9539C0ADC4849AABC1B8A9ED3A381F52555A9267D5DF3EA50A142AD4D3A65499256BEDEEAA1F8622488F9D292698FC4AF4D8577DBB4F696DD98311F289F0D641532381DC6C29BA96DA77CFDEAAAF5C9248F4E944215DF3E8E86A217CE6BC37D095A554
    4   2560 002001  1691919360000       34560000 29B099BD 0B7760C42440E1FFD0C03FE9955E18618610BAB3FBEB10BAA35EBD2767EEBA84FA74849BDFA57B61EBBA54DD3E84F9F2AACC12C37AAD0D754E9F3F5CA52E853475D771C1F3E56A5D9E92E94C47D0EC577DBD37C31CDDD8F9F26AD5D5427CFA9B8AEFA1E5AEF9FA5A4FE7527E95F915CF9D3E4EFA13EA4F57D4215DF43735DF51
    4   2560 002001  1691953920000       34560000 929E7698 0B77DEA52440E1FFD0C03FE9995E1861860F0DF3FAEA9530A2D6BEF76CEEBEAE9694374F9F2E7D4ABA285006D17D0EB3E84B08604C972C45C99FA5AE9912654F9ED2A54E8A5A8ADCBD5361E97AEFAED77DC911AB3358550E1A07F3A0EC4CE60F07B4705822E6E3DAF0DEBB7519EC82EC3B4F0AE26850092F52AA1D57F36224E9
    4   2560 002001  1691988480000       34560000 A263423C 0B7715AD2440E1FFD0C03FE99D5E1861860F5A43DC0FC8C8795E97044E244DE0361AA4B0AE207EF755775B1CD6AF36DC353610BE4CED2BF7AF86C3B031ED89CFA92A7549CBE4B61F51851B5D85CFD3DC7DC42E29A420875DED6E2B6C264D0E989C73BE90EA33F56AE92673BDFA8B8A693F7CF6BD686A925C84FAB6C74FC8D6B0
    4   2560 002001  1692023040000       34560000 AD81EA7C 0B772A302440E1FFD0C03FEA9D5E1861860F4E1BAB8988DC510E95F5EDFABA7E95FA5755A225734A9447D0A220AEF9F3AA50D33A56994BF7B09543ACE6BBE855A92A7B0AC2486FA93F40FEBD353C21F07DC5274AFCAD8F643D7A8F2CBB530754995439C13A1AB23114484CFC924874DCEA7D497BA8D0A72A7EAD33F52FA9437C
    4   2560 002001  1692057600000       34560000 1D8CD705 0B771CC32440E1FFD4C03FEA955E18618610FA1BE9098AC852F9F584CF57BA8EA90BE555AA1085ADF927B6293E7692C257F3C6D3436A742889573EA486BC27E1B9117311290A8FD7297BD48D337864D77DC3E7F0A2277A22238CF010D27EF37BB794D35374961C1D56DF2A7AFDF3A851D5922AFA33F71D539272BD59487A973F
    4   2560 002001  1692092160000       34560000 9DEDD29F 0B7770E72440E1FFD4C03FEA955E18618610F6E89B69DCC09C42E4256DFABDE895F4254FAB567CEDFA1D50E9AA55478224B0E93ECEE94C28835F3F749383A5AD3B34A3BE941B909FA54E4933DA3C2C707DC4386F6E271AEA1B87D5E93F7AFDF517CF972A873A8C37C99FA4AEA6BD34E45F2986F77D37D4DCBEA899ED286A9534
    4   2560 002001  1692126720000       34560000 666FAF4D 0B77C9402440E1FFD4C03FEA956E1861860F0AE21F0AD2C3ACF38575682E3DAEF953E569C656AD5AC2284FA152A6E6B43A559FBE54994D84AFCB3D8D5E1534CA63A6795F5AA86937C2CEA9D2A5ED22F07DC2A8EFB5A68561EB98D5D5A586E9ED674F61C28EA61BA7E421BDAEFDEAB4B3DED37CAADBE7D0A1A5CD61EC77B0ABC3
    4   2560 002001  1692161280000       34560000 1DBC9277 0B7706AE2440E1FFD4C03FEBB55E186186129A4927F5ADC2D0BA20CD8BB73E855F1F15DFA65CB125BACE37DC7CA61BFA481F42ACF9FAA7E95F3EAD4A024A8988BE4EF695384BA9BE74F9F4422F9F3EAD108D6A699D2674F5FBE869613EA69A2DC7DBC2B8978274D0A8C37D5EBA490E9F257D19F3E8045F2684FE8D7AEFC8C35C
    4   2560 002001  1692195840000       34560000 C3203FAD 0B77D7DB2440E1FFD4C03FEB955E1861860EBE226849ABAB51AEB6F86E22CD8695F3A735DF527D4ABA6AD6DF3F5685FA67B0B3BDB0B5FAE72BA96C42FD111535E13E83BE9A65CFA1B95549FA954FD8C37DBF0869AAC552FD4B8BA994D74EE9CA66AE9F42A74953E9CFD2BEA6F9F3F4AEA93B4B5DFA5AD4E9A4AF5E9AB214D4E7
    4   2560 002001  1692230400000       34560000 4E33F138 0B77751A2440E1FFD4C03FEB9D5E1861860D72DBF84AD53F795DF577E9184EACE9D527D0A953734E73F7BB173D7EFD320B909D3E550DD3A749A0C78EF6B537D4A3427B9E13A5DAD53D855DD3F19AAF577DC7086FDD2DD74AC2590AA23EAE9762295C29BA39EC454FA8D7AD608D382FE8D2AEE5F3EAD6E139BF4B5D7855D55685
    4   2560 002001  1692264960000       34560000 E106D242 0B77162D2440E1FFD4C03FEC955E1861860F5EBA6B6AD33BA34A9D65EE2E51B8990BEA351D42530D7917362156B095F39A8A622574FD4D77CFD2BF2499EC38695721A4FB7BE7CFD2D75509FA1731F0707DC447C9ADA556FE1258846129A6F953E86A9D3DAE56BA9AF4D2567EAA142AE92C3DA5614BF7CF9F3DAEFA1C2850E6D6
s=5 n=26 o=12370575360
    5   2560 002001  1691435520000       34560000 AD9CD532 0B77655B2440E1FFC0C03FE3955E1861860EAEB278EAA009A2B1AEB1CDF13A7CB10306B59F69C092BAA8581D25AEF6DA6AB71F26535DF3E7EE6BC67CFD2D67D4A93E255D7567EE61BA7C96FBAA4FA2D77DBDC8686BBF70EA9AA7C96BBE7CE214416FABBA7D0DABE72975D1DEFABBD86FABA588860D7A4FAB2B74A92BEAD5ABBB
    5   2560 002001  1691470080000       34560000 125FF98F 0B7726032440E1FFC0C03FE3955E1861860D1F7A6C0FD50EA4F9CF04CF2EB9E701BF476A5F3DB8D68D87B6D3528736BA656A9D3F215EBA9AF4D1257EE55A5AD1AB3B430EB527D4A14374A95A9551E2577DCAA7D0A1BE68FE15754F616AA496BA97AFDD3F74A29C6A2AA9527B1173EAE5953DAD0EBA5AEE92537AFDCC2B0F92C2
    5   2560 002001  1691504640000       34560000 3DAEB73E 0B77D4932440E1FFC0C03FE3955E1861860D61ED8B8A5D936F6F5EA7EE2EA1DEEDF2F4B59DA4B08292BAEB9F6B74F6DA1AEB06BF44A5EEBAEA9F3E854A342533E7BE7B5DF3DAF4DF3F4AF953E869D5707DB2AAF0E96A7B62139B6F97424AF9F367CD21DAB8F9D2A4AFDF3E82BB351B8BDB3487008D422352BF730C6AE8F06BE9
    5   2560 002001  1691539200000       34560000 BA871677 0B77C06A2440E1FFC0C03FE4955E1861860D6F5BFAEA9FA74AAA967268FAB8EA9A8C34B4D4BB4CE9FAA9CBA1437CF9F8D7B6EB56AF59ED6B8AD325A4FD4BFA2F6C2A6B5E13E854ABA64AAABA9B096CD77DB8D57AE8BFB095F3DEAE535BB4D9FA62B593437C936267B0DF28ACFADBE7BB12BEA6BDEAF4B0D4BDA71066BA4F9CD2
    5   2560 002001  1691573760000       34560000 CAB0A9E3 0B7702E92440E1FFC0C03FE49D5E1861860EBE8D7DF0D3A77A99F675CE30CEDCADEC37CA63BDE089D267CAD2D35B5DCBF5C989A64AF95A57EAD0577E322208799F397D5DF3D885553D8EFC64354FB6769DBAFEAAA9BA7CED2BF4D5D2BEB4FABAF953C2E2461442CF9ED8435D3A4E14AD974911566534D7A17B512D77B6E946AE
    5   2560 002001  1691608320000       34560000 764271C2 0B770EF02440E1FFC4C03FE4955E1861860F0DF2C7D3C926730ABEC247BD9CE09D45C73AD4BDE0A6B3F7D0DD3D74FA113A559F441B59F65D8AD2AA7CE9F3EA6E93466722BCE7D0ABA59CF9F52A6AA53E7DBA2515D4F186A6BBE73745D67CAA1D4419DF42AD1066B6C85FA9A8954A57F4E13A74AD6C24B0CB39875F33DA34DFBC
    5   2560 002001  1691642880000       34560000 7CB7136F 0B77967B2440E1FFC4C03FE49D5E1861860D71F439039D2A7B510EB4E7E4B9E0ADCD74369741C0E6B2BA55DCBE7CBABB68EE9EC3754D2BE8696B545482BBE868FA3E996F7D7269613E42BEB56859ACF07DB8BF6ED14284ED245525936B4D5B7A694BBF8096B2C2636AD871C13BD5CFEC0D7B71CEA5DAA2357C9DCE74CF69577B
    5   2560 002001  1691677440000       34560000 EA2A8B2C 0B77DA3C2440E1FFC4C03FE4955E1861860D65CBFB6FDD127CAA9BD888249CDF1A1BF71C12C29032BA77455FBE74A6C1154FAB43A4A9ED6B6BDCBF74F61537CE6BD7390E19554FDD514CFC8D844FA2707DBBF869AAECB0B9E57A709D3E7B4A1D352FD129855A011AD0D3264B0933E8559F4257496D7536E9B9A6A224186FD521
    5   2560 002001  1691712000000       34560000 A3CCDF21 0B77B5FE2440E1FFC4C03FE5955E1861860F5EB52E95A98E8645D575708BA5D69DC5849812BDB8ED2AA7B5D3577B0DF274B49F96730CB2EA30DF577B512BE7B9B5BA7BB12AA74FD4D31B004A5B6FAEDC7DCBA84FE73FAEE9EAAA759F425CF6BDB7CF6DBDA6E6C265495FA17E99D25CCFD33A76E86BB26821444CA9F427D09552
    5   2560 002001  1691746560000       34560000 F2A63683 0B77A1632440E1FFC4C22FE59D5E1861861246BA68EF95A6AB5DD481CDF125864733FA4FD3258EE6DA742B62A3DA82BBE569A93D7EFD324DD114C34E45D3E7D0D2D69D4D31156A75BE84AA1427D5E2D77DC5954AD52C434A716A6BAB5C2AFA9AA55C39C0879ABAF0A93F6B5E01FB8FD2AB9BADF4F54F953E4C9DAC27EA9F3E54
    5   2560 002001  1691781120000       34560000 2329EEE7 0B77C04F2440E1FFC4C03FE5955E1861861256B3AC0A9530711E756B07F0BBA43952F4CE886B86E6D3FA4FA9537CE6BAB74E9EC27D6DFBA7B4A1A9AEF9D2A84EB5AA739D33888FA0BF730D4D288AA2707DB1091C5F567495CA77E461D771C59D354AA0DC4BB4AADA4A6DD8A3AABA5AD09F53530DFBCA53D5517E961BDB6F6156
    5   2560 002001  1691815680000       34560000 661855B2 0B778CD42440E1FFC4C03FE5955E186186114D6BEEAA5FBF52FDADC2531835E701C5C4B49F568882B447CF9D3E7CFD521AE9A93E7559F41B8E954E53BDFA65359F427CFA1A9AF0A953430A93F7AFE05C7DB20BD4EBBEA498FCFD6A6226AB7DC707D1DF53750674E8549FC2ACFA3954E32BAA8549F5772AB2B9B0AA93F4CF9CBF
    5   2560 002001  1691850240000       34560000 D584A8B1 0B7771222440E1FFC4C03FE5955E1861861109F3EB9006BF50FE9591B32439C29C5C77BBE9A490D5F3FAB1E9C2750A1534CB9F91850D2AB7C99F3A5539D3EA4F9F3E7BD12EAAEF9F3D9095C5CCD0A4DC7DB3AE34DFBE56828D77CFDD217CFA6D86045F2F42F95AAAAF6DBF7681FBD754DC6FA5AA3C372F538D85720D3730ABBE
    5   2560 002001  1691884800000       34560000 973AB7D7 0B777D7A2440E1FFC4C03FE59D5E1861860F5E13FB6A95A6A2FE8F37F497B9E099EDC49B08BF530DF2749B13529D09726A50DD2E74AD26B854A9C27CF9D527CCF0426B121A586FDCB89149C47E8FDFF07DBB17D1984284F9EC2AEFE3BF837552295C3D9282FB074FE0BEA6FC8D1914A13F535DF3DAEFA16AA4FDF44495D5527C
    5   2560 002001  1691919360000       34560000 81E16C72 0B7721042440E1FFC4C03FE6955E1861860F6DF479096740514E9C24E8224DC0892C442F9F3E7B5EB3EAD14643A4E9F2A7CBE13E84E73C28699F2B7AF9CE77E94BB99B6133E5EF29508AF5FAB7CFB93E7DBA6BAE6DAC4C41CC87B4A13F86A5EEB4E960DC73AE15F4AED53956AC83F7D469BF795E95B7F335A64B0E13E7B59FBE
    5   2560 002001  1691953920000       34560000 007E0832 0B7725322440E1FFC8C03FE6955E1861860EFADCFB6A952C5296A4254E24BEAE85FAA7695F4F4B5AB2F7D09FBE4D36DAA7B11D3E7CFA6D7AD5A96B84F92DF855AB52A3B1ECCE2F9F2A190EAC4AEFA4D77DC0D894B7AB54A5A447CF6B3FB8A9F3974F6BBA7EF6D5B7B5DFD17D5E6A9BEAD2C37C861BFA4F923F7CEA3B94CE9FD2
    5   2560 002001  1691988480000       34560000 3881ED05 0B771FAE2440E1FFC8C03FE6955E1861860F0B5BEC2E5348790E96C23464A0B095F427D4DF517EF6B43A571D517D9ADBF7B1DEBFA4E6BA74344C117E8865884AA8E9E0F9CBDCBD21BE41C1747AEE987073BA5BAEB7BBA4F85C3B8994BFAF0A9424AF953F7CF953E750AD3F7CF94BE7D5DED7729953F7CAA93A54360397549FA0
    5   2560 002001  1692023040000       34560000 43349377 0B77427C2440E1FFC8C03FE6955E18618610FA9BAB895549170DFD67692EB58685F5275506BDA55DED3B0A933DB085FA17CFA9BF2B9D2BA9F05CF052FD27084FDCBF48FDF3A4D5A0D79922BD774FA4D77DBB9C48AB92A50904376D2B2AE2F9F3976A5D52754DED77CBABB97EF9CD274E95A9A4F1FAAB85AC0C4A9A1C440F94D1
    5   2560 002001  1692057600000       34560000 A739C60D 0B7747E52440E1FFC8C03FE6955E186186113AB43BEAD2C3ACF75D84CE23D2DA252BE4BBEB5AA54E916B7110BDAF47624B8A93A47D5E1B9870A9BCAEA6BD374E61557D0DE55BB377BE7CFDFBA39660577DBD3B0E6E26AC95F267CF68C3EAE2BBE7B49FC34CE383DB6AC8BE755A9525549FBDAEE6658A73A1B5531CB5C50FB5A4
    5   2560 002001  1692092160000       34560000 5F4D41CD 0B774D4C2440E1FFC8C03FE7955E1861860FAB7BAE6FE12C794E1C1B0E2EA4E2252C24B61339A50AE0DAD71D3D90E2BA6A51D53E4E95F427CFD3A58446BD28670B53735DF2DA74D55249229AA6F738F07DD15869783A4CAA14D7EF9F3EAEFA9397CA6BAA855A2257E829BDAEA9F3F2B5A1527F495B9D50E1427D4ABB9BF0DF34
    5   2560 002001  1692126720000       34560000 B3259302 0B7793272440E1FFC8C03FE7955E1861860F0E93AB8AC8BF849623A4EDFB38B7492D288961527D1DFA1870A141B896B43A6E5FBE4B0B5AA84FA35779BEB584ABA9A9AD5AA288746236530D2C354F64DC7DC5B869A127515DD4EA55A1CDB0992CE7B59F5B7D5AB4354A954DAD61ED284FC93DACA9FBE7CBABA9A4FA1D686F6B52
    5   2560 002001  1692161280000       34560000 C9B6836F 0B77CF2C2440E1FFC8C03FE7955E1861860DBF8268EAD73B5296BD74E8F0A68021ED6A5714D284FADA6AEF9F3F4B9A0F04CB6E397EA6BAA7D3955286A9F567CFD2BE7D3A9A64AFA1574CF9F427EA70757DCAE56977442A823C2AEFD32A7ABD53F22F9F265EF6BB98E9A13EA6955574AA9F5418B6E25854A1528696B477CF6BCE
    5   2560 002001  1692195840000       34560000 D47CB7C1 0B773DBF2440E1FFC8C03FE7955E1861860D252D3B69AC0E715E96C7396442A685329855ABC27CFABBEA55EBA986F6DBE850D32A54F64294CFAC218CE9351AEE9F42ACFD4D8733A0DBA50D5119D4AC757DC4386D9EBEA4EA356A54D74DE0B5FA74AE9ED37E994D34E468D6DEFD0A5AD0DED852B9DB9A8E69264AB6A41CD6E9A4
    5   2560 002001  1692230400000       34560000 68C462F5 0B77422D2440E1FFC8C03FE8955E1861860D72B3FDEB9FA77A99F6AA8E183AD69925B7CEDF3986D6BAA855133D7EF77BAA696952AF59FB9AD0DF527D4D6D77CFA9529BAE8AF4CFD2BDD89615AA7071437DC437E8A1955299F5BA506D56AF0DC585CF7557AEF9F2AACF6B5286E693E54A9557A50ADAA7CF9EC2A2FABC355AB428
    5   2560 002001  1692264960000       34560000 E9A74589 0B77A4E52440E1FFCCC03FE8955E1861860F0D73FB6A9FCF7C9696F86E2E39D8990AA7B0E1427E99F3E7D6DF52AEF9F3A8706A257655F484A99F3E5E9C646AEF92D6CD11D42749954274FCABF42EA2D77DC967CEABC17C39F3EAD112AA8509DA9AF712A4B74DED39AFD2AEA3AD5399B650AFAB6D53B7C99F274A92A25AD5DF3E
    5   2560 002001  1692299520000       34560000 3E33E26F 0B77F8682440E1FFCCC03FE8955E18618610AA1448C5A1C79C99EDF755704CEAE553DCF5E1564B5B7AAA6FDD298939CBAAEBD2575659F90AEEA0117CF95A4AF09ED6AF5A1BDA6F9D3E5CFDEC2D50183E7DBD8AE96BBD7C373AA9CAE13E7D0D4C78091FA5754D53E84988587445D3E4B5D52B7CAA9B97D0D2BE7B4DF527EA9E74
s=6 n=12 o=12360585216
    6   3876 002001  1691412480000       11520000 04066AB5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000024000000000000030000000220000002C5BA59B65AD2769A74E0F6B5AD6358C6316C5AD6B524E7288410CE2F7354B5254A49CE52904210421084210CE307356A5252949CC63146310821084210CE0F6B56
    6   3892 002001  1691424000000       11520000 50CD009C 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40100000002000000200000003600000022000000445502B68373DA9A069821921A54E0F735AC5B18C6318C62D6B5A8E830C410D22F7356B52929418E42086108421084210CE2F7356B4A9293A0C7298A318C2108421
    6   3892 002001  1691435520000       11520000 FDBC03DC 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF420000000230000002000000032000000140000005846A0EB8AD8B6C3747171834C2204CA0F735AD639AD631AB6318B5A92728C410D20F7316A4A94939CA528C4208421084210CE0F7316A4A52939CA5290621042108
    6   3880 002001  1691447040000       11520000 0F414D9F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002600000000000000300000001200000036BB71983B73C2C4909AE4E307B9AD6B58E6B58D6316B5A527308210CE0F7B16A4A949418E528C4210821084210CE2F6B56A4A54939CC52086208421084210CE2E7
    6   3864 002001  1691458560000       11520000 D769FDD5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000002000000000000003A0000002D0000003702C7BE62D66B9B772C19AFA5DCE30739AD6358D6B58B62D4A524E6184210D22F7B96B5294939CE52904110821084210D22F7356A4A52841CC5288421042108421
    6   3800 002001  1691470080000       11520000 EEF88EFB 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42100000026000000000000003E100000290000004383F9A369BE265ADC7180F62111B65BF980AC52565231739AC6358C6318C5A94949CA4104210CE307B56B5294A424E630C4210821084210CE2F7356B4A529398A5
    6   3816 002001  1691481600000       11520000 3C1B1829 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF451000000300000000200000020000000020000005E0DAF445A6CD28B83AC0EAC52517358C6316C6318B5AD4A498C3104210D22F7356A5292949CE528C6310421084210D22F7356A4A54941CC528C4208421084210D2
    6   3808 002001  1691493120000       11520000 1267F494 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44100000036100000220000000C0000000300000033145B26CC629BBEA14492A61B92A72111B706ED231839AC6358D6B18C5AD4A49CA3104210D20F7B56A4A929421051884208421084210D20F7B14A5292939CA510C
    6   3824 002001  1691504640000       11520000 751E994B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000003200000020000000220200000600000055522E9716B1ABB2CF6A2A729AC6A1563283DAC6BDCE6B58C5AD4A49C85188210D20F7B56B529494A1041904210421084210CE2F7356A4A929398C4208420842108
    6   3860 002001  1691516160000       11520000 8A2C1CFA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4020000002B10000022000000340000000C100000260A20A56EAC0E14D52AD9A32317E23612A4A024B6DA538C1AC6B9AE6B58D62D4B498A420C210D2106B56A4A94839CE520C4220821084210CE2F7354A4A927398C3
    6   3892 002001  1691527680000       11520000 1DCA2084 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44040000002120000200000003600000041000000556F236B9C872C7B61263FE5B6FEAFF182D8D2328BDAD6B9CD6B1AE6B14A4A0C6210620D2307356A5254939CC518C4110421084210CE0F7316A4A529318C518C210
    6   3876 002001  1691539200000       11520000 612E2525 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4580000000604000000000000200000004680000034997535A9A09B89D92290CC1AC6A09E75610841AC6358C6318E6B16B51CC5108410D22F7314B4AD49394C528C4210421084210CE306B54A4A92931CC5208610842
s=7 n=15 o=12360585216
    7   2012 002001  1691412480000       11520000 395BC220 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000024000000000000030000000220000002C5BA59B65AD2769A74E0F6B5AD6358C6316C5AD6B524E7288410CE2F7354B5254A49CE52904210421084210CE307356A5252949CC63146310821084210CE0F6B56
    7   2012 002001  1691424000000       11520000 21917C34 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40100000002000000200000003600000022000000445502B68373DA9A069821921A54E0F735AC5B18C6318C62D6B5A8E830C410D22F7356B52929418E42086108421084210CE2F7356B4A9293A0C7298A318C2108421
    7   2012 002001  1691435520000       11520000 D86B6C53 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF420000000230000002000000032000000140000005846A0EB8AD8B6C3747171834C2204CA0F735AD639AD631AB6318B5A92728C410D20F7316A4A94939CA528C4208421084210CE0F7316A4A52939CA5290621042108
    7   2012 002001  1691447040000       11520000 1B8B0667 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002600000000000000300000001200000036BB71983B73C2C4909AE4E307B9AD6B58E6B58D6316B5A527308210CE0F7B16A4A949418E528C4210821084210CE2F6B56A4A54939CC52086208421084210CE2E7
    7   2012 002001  1691458560000       11520000 564FA55D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000002000000000000003A0000002D0000003702C7BE62D66B9B772C19AFA5DCE30739AD6358D6B58B62D4A524E6184210D22F7B96B5294939CE52904110821084210D22F7356A4A52841CC5288421042108421
    7   2012 002001  1691470080000       11520000 5173E745 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42100000026000000000000003E100000290000004383F9A369BE265ADC7180F62111B65BF980AC52565231739AC6358C6318C5A94949CA4104210CE307B56B5294A424E630C4210821084210CE2F7356B4A529398A5
    7   2012 002001  1691481600000       11520000 0040F4A6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF451000000300000000200000020000000020000005E0DAF445A6CD28B83AC0EAC52517358C6316C6318B5AD4A498C3104210D22F7356A5292949CE528C6310421084210D22F7356A4A54941CC528C4208421084210D2
    7   2012 002001  1691493120000       11520000 6DD5807E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44100000036100000220000000C0000000300000033145B26CC629BBEA14492A61B92A72111B706ED231839AC6358D6B18C5AD4A49CA3104210D20F7B56A4A929421051884208421084210D20F7B14A5292939CA510C
    7   2012 002001  1691504640000       11520000 ABA074D9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000003200000020000000220200000600000055522E9716B1ABB2CF6A2A729AC6A1563283DAC6BDCE6B58C5AD4A49C85188210D20F7B56B529494A1041904210421084210CE2F7356A4A929398C4208420842108
    7   2012 002001  1691516160000       11520000 2A24CE6D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4020000002B10000022000000340000000C100000260A20A56EAC0E14D52AD9A32317E23612A4A024B6DA538C1AC6B9AE6B58D62D4B498A420C210D2106B56A4A94839CE520C4220821084210CE2F7354A4A927398C3
    7   2012 002001  1691527680000       11520000 48EA8703 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44040000002120000200000003600000041000000556F236B9C872C7B61263FE5B6FEAFF182D8D2328BDAD6B9CD6B1AE6B14A4A0C6210620D2307356A5254939CC518C4110421084210CE0F7316A4A529318C518C210
    7   2012 002001  1691539200000       11520000 EB5C0A25 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4580000000604000000000000200000004680000034997535A9A09B89D92290CC1AC6A09E75610841AC6358C6318E6B16B51CC5108410D22F7314B4AD49394C528C4210421084210CE306B54A4A92931CC5208610842
    7   2012 002001  1691550720000       11520000 C520232B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000040000000000000026800000370000007FDA06B711A49ADC0924DF089A026E245CE307B5AC5B16B62D6B5AD4A4A4C3108210D2307B18B5AD4949D052904210821084210D2307356A4A94939CC718C610842
    7   2012 002001  1691562240000       11520000 33216210 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000020000000000000022000000140000004B96AEB6BEAD80EAADD22F7B58C6316B5AD6B5A92941883108210D2507B58A5294A4A0E730C4218821084210CE517356B529493A0C730C4108421084210CE2F7316
    7   2012 002001  1691573760000       11520000 9CC667C1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460000000020000000000000020000000330000007E626FEADB7422EFE69BF2BC522F7B58C6316B5AD6A52529414A3104210D2507B56B529494A1073146110821084210D2507B58A4A929418C82906210421084210D2
s=8 n=26 o=12370575360
brymer28
Re: Jumanji..original film..won't backup
Post by brymer28 »
log comment #4
    8   2560 002001  1691435520000       34560000 DEF6E095 0B77EA482440E1FFD8C03FEB955E1861860D6F753BF112BBA16F3D724DF0D2DE9DC607509F2A84E78127B71D25A8961227CFDF3A54F9FA1ACFDFB985477EA7CFD2BA23AE3D6854A952A6AA13DAF0A2707DC2C4E2362A7AADEEC430D7427A9A95A56F5F3A750D1267CF9EBF84FA0D784BD2BB410EE257EAD03F7CBA9BE54A5FBD
    8   2560 002001  1691470080000       34560000 3BE8FDA1 0B771FB62440E1FFD8C03FEC955E1861860D13527AEFA1927B5DCF04E7F0A6B55DEC8436C8B9BA81F3AADC08707D375A1AEFD529AD61D8C856DF3E7D4A14F4CF6BA9A4FE1A554FD4C286A95A57D0B0D77DB90A8BD5A9A681526B0F9DBE4B0DF426B512BA74E6BA684FDAADAF5D32B44F9F8B90A9F124C86BAF84FDEB97C990D5
    8   2560 002001  1691504640000       34560000 12B8841E 0B77C7442440E1FFD8C03FEC9D5E1861860EBDF42E8FD3137101CD74E7F0A0E09E6DC43594D68736B92AD6133E74FA321B6ED4C87309EEBAEE9D3DD709FA57C8B3439CF9F52A4FA3BB52F61AB7AFE2577DB4FD5239BA1B6E4297CBB838B6E9354C6BBF569AD2C4C9D4BEA54A29FC0E783F6921DA5530A1BE49627577CED315A5
    8   2560 002001  1691539200000       34560000 1EF9BC4E 0B77845F2440E1FFD8C03FEC9D5E1861860EBEAD486AD3267B5E8F41D33AB67CFE0DB4C994BF4EE60DC73112D775A9F27430A9A986F935286F6BCF7AF9F537483825A55E8ED1AA5FA5AB252B9AEF79577DC08A5B77EAA51E9BE7E4AB6AA496BD8C6BBE90FA32C449AAC3A55D638873E1127BC46BE4AF9F534911F4374FA9527D
    8   2560 002001  1691573760000       34560000 4E691F74 0B77332B2440E1FFD8C03FEC9D5E1861860D75458DEA93A772FA0EFA87E521D4FE8C7A546C257E95F437CFD2D774F92C2AEA6947A4F6C3A531125784A3A905D5DD4176FAB3E2CFC852B749EE6A8D6A7683C2C7162E2D7EF9F29B96122A80A1FD8C7BBF86FD5174CAD2AB435DF55B95B73ED58293D84FAE224AB063F7B5DFA9A4
    8   2560 002001  1691608320000       34560000 775C6227 0B776EB52440E1FFD8C03FEC995E1861860F0D4DC8749DA748FDFBE5867D35C099ED8735D4C1B896B927B7133DAB5DF26B75D2C044F69B9850DF2AA635F957E96BD63F22224AEFA13F19714BE854E2D77DBB4C306BD7A5746C286E9F5772E9FAA190A1C27F0E0DB8895ED742961C47363B2F4E154A30153AA30E9567F5783AAC
    8   2560 002001  1691642880000       34560000 CC81DE9E 0B773AC92440E1FFD8C03FEC995E1861861056BC38EFA3AA535DD5824CE4B5BEAE143435C8C1B896D3B7D1DCD67CFA3B9B235ED384FA7A5A6A6B437C975BF4C7216AA4BE0247EE9FA47CFEB3F4AFD8707DC0CBB45D404D4AB568891FE6AB5E0DB72ADEEF869E12BA899F104B05FAEB567DCF0D7BEB4ADDAAAD4AB6B4D49839D8
    8   2560 002001  1691677440000       34560000 54810946 0B77639E2440E1FFD8C03FEC955E1861860F0E13EC0FD7165B5E96A7EF97B8E90DF2B4B5D321886F7C3A36132A4E856C28EA9F967D49CEB554DCD6CEF61BB4B095BE377553555512B97B5D756AF5E25C7DBC482AAC917B32BA75EE693EDF5D5437AF5FBA4AFA1A7A6D35A9D75A3A57B5AC263F66D6B2C955D28D075D2AD0DCAA
    8   2560 002001  1691712000000       34560000 B9A4956A 0B7714B12440E1FFD8C03FEC955E18618610FA33EEA992A783ADDD276F974DE099EEC6B6D2D1B8E6BA67B606BF72FA9B9D70954040FA1BB4AF9FAA535DF527CEAB3EA35E93A5B7525744A9339B6FB0F07DC3FA55A1A548E5F535699552809553E2355FBA74FAB9674F9F3EAF069BE53395437D0A3BE4CF9D51DD09F53730A3A7
    8   2560 002001  1691746560000       34560000 D49AC57B 0B778B282440E1FFD8C03FEC955E1861860FB20D390455A27CA6BEC1CCFB25A6892C0430065288D2BA674AC9298749D3E4CFDF3E4B6DFA17CAABB9AD9DF3E7D4D4D7715E93988F6BA9CD0AB43A6FD5DC7DCBE7DADD1082F6B3EE0961BEA83172E5696A0874F9FBE53ADF434D0A93D54921C4834DFAA4CA6B53534D2427EF9F57
    8   2560 002001  1691781120000       34560000 EFC8D529 0B7726372440E1FFD8C03FEDA55E186186114A2A15F4B3AB7CAB7BE56F972E8F0623E754A22156921C75349D5B7B5A1C9E1C57753D73A36F2DC8A4EA9BD87092EEA54A1A64C961CE554DF3A7D46B4420EA9606B0DF41D6F9F5778F9F3EA56D5A97D5DF3EB55A1428E99FBA4D4696C57E63CF4AE21E84D32B72FA9C22EE61CDE0
    8   2560 002001  1691815680000       34560000 5905325D 0B772FC62440E1FFD8C03FED995E18618612B693EEA9953E7B6E75B587A4B6AE9E6C34B4A156A6F6B58736105754F9FB654E9CD773BDF3E8EAA72A750AB5676E69B97CFD2D77CFA33E9CFD2AB4C970F07DC6B88DD12C42FE7397CF75BEAF99FA680969434D0DCBEACBD33B24A5FB98713B50F6C88BEBE1A6A4FA96F7EF2E3AD6
    8   2560 002001  1691850240000       34560000 49D50763 0B7796182440E1FFD8C03FED955E18618610FA13FB6FD327495B63B4E817CEA8966EB755D2BDD892D487B713527D4ABB5AD1DF3E7D49F3EACFB6155695ED7AE45F52A3CDF42D6F9F3D8895E4573579707DC838B0AC265532658755DF2A850EB5C74E949242F9CD6CD5DF484AA9CD84D09F3F4B49F3E86F9338BAF86A5AEA9D2F
    8   2560 002001  1691884800000       34560000 F44AA989 0B7749FA2440E1FFDCC03FED9F5E18618610BA13EC09C6D4794EAF44E92E39BF4DCC4716D5A584FDD26750DEEAA759F267D0DF3E7C9A1B9AD4A95774B9D4274DEC5651661BA2EE9D247D5D1DDA6BACD77DC187B6E3D7530A1BE7D4E92EBF0704F95C2FB9217AC410EDD37EF644379791F063CAA729B0171CBDE57AD709B3C277
    8   2560 002001  1691919360000       34560000 14CF3200 0B77DD432440E1FFDCC03FED955E18618610AA13FB6F97A778FE9D31B324B9B895F57737DF3E735E13EA69A143A54A92B52B12BDAEAD06B85012BBA30CEBFAAF6C2A4911CD688F54BD2F4D2C4A50ACD77DC42928612AAEB9E3F5EA9AD774FD0BDAEFAB56AD5DD26A4F9F427CFA95686F6BBFA4E9CD62359FA67EE92437CFDF51
    8   2560 002001  1691953920000       34560000 964F2FAA 0B773A1C2440E1FFDCC03FED955E1861860F5ABBEE8AD12B82D9FC25532EBA8E86BA67509529D8F68D87CF9F5686E6BAA7321D3E82FE6D77D4E73E86E5343535A152751DEBE4EEDEBD7B112ABB6BA2707DCC2888A8AB4D0DE577B0E942AEF9F39A35B7EAAEF9D427D4A1568696BBE54A9F3E7D0A3BEA4FAB5754F9F534CE94D7
    8   2560 002001  1691988480000       34560000 EA0155F6 0B7793D62440E1FFDCC03FEE955E1861860F4ADD3B2348DC715B6571CE2426AE469A97D5DFA3B8A9F2F53BE9BE4D46BBF51B1EC77CA9F91ACE57537E352DD22F9F41A895CBA450DF5271BEBDB86A6CDC7DCBE569AD27850DCB9A749FBB2AF9FA54AF9F3F86992D686A9CD3A4E9F527D59F53535DD3F7C961D15D5132173B173D
    8   2560 002001  1692023040000       34560000 A333AF3C 0B77DE292440E1FFDCC03FEE995E1861861106FBEC441D483F6F5DB56E2E39B0E5F3E750D33E74B9F2688A953DA6F6E2183114C35EE68C04CA912E7CE932E854A93E7B4ABB9870AB3B3F52BD7550AC707DD8956A6BBA7D5E8C1D5C1F42AEF9FB98559FC27D5AC267B5DF3E254944986AFB70E3057ACB08C452B75DB4D49F4384
    8   2560 002001  1692057600000       34560000 F0AD13C6 0B779BB32440E1FFDCC03FEE955E18618610F77D3DEA9F487AEA15824A2425E0D890D7D0A16B4B0ABBA870D53E56D61A0DA829BF12FA1BD8F077D256353568482DD27D0E6BE26F6E2F172215279E6ED77DD11A8E69AAA496BB8D70E1427EA69A57B49FBA7CFAA10D6A9F3F4AF9F4E7D5DD3F2ABA13F79752C37CFD2BE86E9320
    8   2560 002001  1692092160000       34560000 C6A12340 0B77CD512440E1FFDCC03FEE9D5E18618610A6E21B6B12AC7AA75D756DFABDE085DA5736E15674FD52AA5AE95755463BAAD0DF3DB6A9FA5A6A6BBE7E737D7841BB28CDC1325889573E43213299CBBB577DCC4567761C8EFABBEA52172E2D4E0DC63BBFACFB9AB7CBEB3E7F4960BB8FA92DA361ABEAEFD23FD55DF5454F954285
    8   2560 002001  1692126720000       34560000 090E9247 0B77CDEC2440E1FFDCC03FEE995E1861860EFE13AC0AD0C0A14ABD68092E267EF5CBE7F4ABBD550E126CEADCBE84FA93F7CFA9AA834DD3DB6A95C24B4D3A57CF9FA5A4FD53DAD4AFBEAD4D52986F3BC37DCD75CFE13A7CEE1357BAEBADAD114BF4CA61D35E89F3E7EFAB577CFAA215523B6EFADBF8CADF52AEE9D4354F9D3F7C
    8   2560 002001  1692161280000       34560000 B31CCDA4 0B7758262440E1FFDCC03FEF955E186186104ABB9C05A9BEAC96A3E581AECDAEF9F2673AB7BF7496210E0E9EEC6B49F3F54BA1B8B8A9F3DAD0ABBE86A955683612D67D0DEBF4AF9F56851073D855D85C7DC578032FAB4E95EE5B90DEBF535DF21737DDA186F6C24851094DAD09D574AFDD3A9CA9F3F7D59DB9AD0E93F735AB57
    8   2560 002001  1692195840000       34560000 31AA31CA 0B77941E2440E1FFDCC03FEF955E1861860D1F7D7B69A9AB534DDA986DF8BE869213F4B5E9BDA35EBBE7D6E15356957915699DA4AD5D7A97CFD52B4AA94D77CF75D2A695F5686AAB3E7CE9F924C96CDC7DBDD7E8612B7D4A98FB0FD2D754A69A5834A1589CF9ED7754DCD28559FBAACED1214CFA1A57F49F4022B9FB5AEA94EF
    8   2560 002001  1692230400000       34560000 B2628709 0B773D022440E1FFDCC03FEF9D7E1861860EC16BFD6AD33EAB4DF6B5EE183AAE95D5274FA13E7E969BAAD0DFA58095F26A6992D75D09F3F749D2D67D0DEC37B4E9A64B4A125875A9574CF953B4AAA4D77DC5D54AC8AEAEFAB4076961D790937D4C5BBF7EAAB2B7EFD2AA7EEC9367C99CC2ACFD2AB54F9525B747658234ABBDB0
    8   2560 002001  1692264960000       34560000 67A85172 0B77F8812440E1FFE0C03FEF955E1861860F1ABBFB6A9FBB535A1D24EE2C4DD895F2F6AFA1434B0D53F435DD4286A9F39B8F94D754FDCD77AFE13E60354BEB6F9CEB735E95848FAB6B74A6D544AAAED77DBDD848A1474CFAB539D4A0257D36B577645D3A7C961A674F9ED67D4A9C2735DED81C99D3B52FA1574D09F537B710D2
    8   2560 002001  1692299520000       34560000 48200CA4 0B7711422440E1FFE0C03FEF965E1861860F1DF43B511D2F7CE36564D470B5AE955A17B752C2235EB3EB571B3D88F6B918709D26569A8BF7506E25856D73DAEF6DD24D0DEBE884613DAEFD339D4FE2577DCAAB0861BE86994DB7D5C9A4856DF29AF0DF257D45FBE7CED10CAD6DD3E7CA9FA57D4ABD187608AB4C59CD784B9F3E
s=9 n=26 o=12370575360
    9   2560 002001  1691435520000       34560000 7C0D6415 0B772ECF2440E1FFC8C03FE7955E1861860D72AD3F0AD313710E6F02CDF0D2DEAE65D496D73E5CE780E7B8132986F6DA6A54DF3A5CF97B97E96C2652F77D5D79A73D7F11329A54A952AD0D54E7CFA2D77DC2C52EA3C27AE5DA172FD25754F95A57CF9D2A734A13F4CF9EC3AD4DEEF86A9D3F74F9EEB535E1A57B5D6D77D0DF2A
    9   2560 002001  1691470080000       34560000 C931EA1E 0B77582A2440E1FFC8C03FE79D5E1861860D12B26E8ED30EA30DD6B4E8F0A7A4ADC444BA9FA4B8E613F7B710C35695F35D6FD329A759F537695F3A7D4A14E7D5AB3F4B0E1527CFA142AEA953F24AD3D77DC5946AC8B99B6132F5F4ED3A7D6D2D394B57AF4ED3EB2468C47539DA4B8EDEBF7B71AC28546DC3796533E4B5DFB8D8
    9   2560 002001  1691504640000       34560000 3DCB238F 0B7792CC2440E1FFC8C03FE79D5E1861860EBE0D8B8992A7A30E9BF1C7F0A1B839EC87309EBE88D2B937B6DFAA4CF6E08B6FD4C77D49F3AAD4DFA57D09FA59CD75D422F9F427EE61BB515ABBF4AFE2577DC5C734D25C48BA22E836E039AE49F42953BEB09B52F7E99FA0D7AA29FC28362F490DFBA52FA1BE7161D58695DFB9A4
    9   2560 002001  1691539200000       34560000 6FF662FE 0B77EC752440E1FFC8C03FE7955E1861860EBE0D886AD326830E8F02533D1DAE49EC83F6E95280E5F4447829A986FA18E4AFABA97EF9D3A804C6A252FA1537AF6DC2751E8ED1AE5F3E84ADF90DEFACD77DC1188EE18D7431F444D06BA9A6F9FA57BB13A07D99D3A4B5DEBEA6AA95373095D67EA2BD77B4AB5AB6FD72A4B4E0BA
    9   2560 002001  1691573760000       34560000 4ACC1179 0B77A9542440E1FFC8C03FE7955E1861860D754BF86A95BE830E0F04E7E521ACB1A584AB9FA4B6A9FAA73512C352FDCC2850A95BA4FD0BF9B61A6C4A93A90870CA6F4B61EC24CFC852D895D262D070F67DB29A962BAA47AB7D2B94B3AA8D4A1BD875D2BDB0812C022AA7208562143B546BBF7496DD34CAC85352970B4AEA953E
    9   2560 002001  1691608320000       34560000 1DCD2AD3 0B7781F62440E1FFC8C03FE7995E1861860F0D6D8AEFC926A2FABDC2667D39BA39C4449ADF41B896B927D0DF3E4AF9F27854D2BF554DD397E99D91A635DA5A699D3E1712E24870AB3F41D12BECEBACC37DBA4F4AAE11A6FD2C37AFDD0D4B4F9C3415153E86B9FBF676DF2A879B6224B03D4F4E1BF7C5D32B490E956A707826AE
    9   2560 002001  1691642880000       34560000 98F0094C 0B777BDA2440E1FFCCC03FE89D5E1861861056BC4530132682FE6F12CCE4B5DF0126B750CAC1B232D3B7D5DCD284AA3BA8699ED4430953A855ABAE54975BF74523BDCD0EB567F3D3247CFF5427D0E2707DBA1EAC2BD24CF75BD7DB21AB430ECAA813BE90FA32B56EAB9273AD3525EFABA67B71D3E534A153A49A9A6735DF4255
    9   2560 002001  1691677440000       34560000 D51F9F5E 0B7719A72440E1FFCCC03FE8995E1861860F0E13FBEADD2284FA9BD80957B8E90DCD86B4D2D1B8D362B4AFDCD6AEF9725A50DF967CF9529AEBA9AA9CF953A7CF6229730E92A5D4DF39A4B9DBF4B5E25C7DB277F82AC4555D342B5055C372FADC1A375F3EA6D5D3F7361C494C9DC437EAFB50A643F5AB112B72A9F581CF2E3DDF
    9   2560 002001  1691712000000       34560000 FB10935F 0B77DBA62440E1FFCCC03FE8955E18618610FA3A68F49F8E7CA9D6B76F9552B699D957D5A93D90E9F2A7CA95437B0DF36A50A153530D3427CA9FBE7BADF527CF6C39CB712A98561ED324A9ACEB70AF437DB2B589E1A74B1DA2A855E1D656E362E4B5AFE5714EDBAA69D45286FA9527CE1F70A74953D80F694374F6CA57AEA796
    9   2560 002001  1691746560000       34560000 F837E095 0B779BBA2440E1FFCCC03FE8995E1861860FB20D3AE9D31347727581C7FB25A6473AA7CFD32588D2BA654F9552889553A54FDF3E4B612D1AD5DF42B739F3E7B61D299CFD2A8BAF6BA9CEA9F3E85616577DC16B960A4474AD126549614375092D384FDF5753AE953735E1BA44F613EAF67A7282E88DEAEBBE8CFA8F076F2E3EAE
    9   2560 002001  1691781120000       34560000 FF5BAAC8 0B77F8FB2440E1FFCCC03FE89D5E186186114ABA28EAC73B711DD6F56CFB24DEADEC84B99EEAB73ABAA7CF9F5786821A74B612574BADFB9B6A61AA7CF96C37CFD6D7735DD397D5DF43415DCAF7D4A5577DD2AAF4B5D772F9F42AEFEE3E7ED9CBEC7BD2BA239AC4E892C0696CBB986EB54019612CE8D0D53E5B4DFBA7CF6A257C
    9   2560 002001  1691815680000       34560000 5F9F539C 0B777C412440E1FFCCC03FE9955E18618612A6B3EE2969BF4AADCEF56E1839DF0E8DC4B5D4D286F6BAB7B5D33DAF49FB65685CD77509F3EAEE96D37D5AB529E9952583AE9437D0AD3EA509F3ED68A2707DD4E54EDFA5854DCBF7CFCB397B0ADD854A5CDBA36DF95A559F2AA4FD2D2A50A9B98096B3EA5212C27EFD30D54FA021
    9   2560 002001  1691850240000       34560000 142EA91A 0B77FE5A2440E1FFCCC03FE99D5E186186110A13FB6ACB2AA34B63E80817B9E0EDCAE9CFD2BDB092D58AB5E9BDA8E6BA57EB953DAEF9F4286F9F3DB095ED7A50A13F430CABEAEF9F3D909525CB68A4D77DD3E9E455579EAD53A56D222683BDF7395C3DB0EA32B870D4BA7BC1DB98CFB83F72FD4C354E5FB9AD014D6A6F9FBE73
    9   2560 002001  1691884800000       34560000 81587DAA 0B77DD672440E1FFCCC03FE9955E18618610BA13EC0AC6C3834E96F4EA223DB899CDC42F9FAA54E9525D710925550A1267D0DF3E7CF9F428696B57A4B9D3E747EEA63971FBD7F4DD24556D43153B2BF07DB11895F82E40AB851550D2D758829491AA5043D2F762A550DF9F7CFC9BF493A1D35499EBF7D0A1267D608B9D76D2BE
    9   2560 002001  1691919360000       34560000 097DDFA6 0B778BF52440E1FFCCC03FE9955E18618610AA140864912771026EC21964CCE0F9F444AF9F42750A13E851463F535DF2A84B12CDD699D3F4B1ABBAAD5CEBEAE95DB973612D756F54BD2F5CAC07CFE4BE7DB0CB35EC257C8E1DF56E5F587AFADD384E5F29B50ABA62B49F57495E1C4535A1A94B6E93E850EBA5A5CDD565D0D26C
    9   2560 002001  1691953920000       34560000 18ACEB39 0B7790EA2440E1FFCCC03FE9955E1861860EFABBFDEEC8C07C22BDF5532EBEACEA9577BAD4D6B0E68D87B5DFD254975AA7321D3EA4E9F2B7B5DF3E84F934354A96C2A3B1EB980EDEBD731E127AF9AED77DB0CE1B6C124AA5E5B7D0E0257B6E2257CF5EEC4B35F3E7D49FAA4B61CC3869D4B9B24863EAF4CB56A495DC1A4A90D4
    9   2560 002001  1691988480000       34560000 868B1A40 0B7756042440E1FFCCC03FE9955E1861860F5B7D2EAA90DBAB5B4431CE243A8695F574AFD7A3B0A9CC47509FD17F39F2C214DEC384E9F8E4E2D3544C852EC7CF9F29AEEA7207D11F517BCEBC78D9DFF17DAA9ECEA42BA50DC3E80E5FBA54A6B5840F9CD786FC8577CFB3BD850D52A8631F42B7612BEAE86C244D4D3397D0DEBE
    9   2560 002001  1692023040000       34560000 642262FA 0B77375A2440E1FFD0C03FE9955E1861861106DD2C2E92BF7B0DF5F7EDFD348885F3EA3B133E74B9F2A875D34E8546BA6ACAD4C756F613A56F86DB54E5FAF4AFA93A7C56BB98F1AB3A9962C3DA5B53C37DABDEC9A4927B0DEBA7D0DEBF7BAD7427B5DE58A6E92BB52F622954FA36B7D0623E535DD5354A9F3E86A9F3E74A9E57
    9   2560 002001  1692057600000       34560000 6190B462 0B7745AA2440E1FFD0C03FEA955E18618612937D3B69C8C472E9F582492C22B031CEAADBE1BE4B0ADA6D70065756861A57E969D339613298835F3E5675352AC98727177523D80F6E2F18C0B2639224707DABB7EFF8BA7CE9EB8AF5DD2A54FB5577535FBDB55A13E733A0264B0EB3E7EF9D3EA699546A696BBF7CE61BD7B5A143
    9   2560 002001  1692092160000       34560000 1A357FED 0B7718222440E1FFD0C03FEA955E18618610A7821E84A93148E6DDB56DFAB9D882BBE535E9BE42FD52AAD71CC2B746BBAAD5DF51A6ED4C34AF9FBEA6735D7547B0CF6961F25874973E4AFE9536FC6CD77DAB9BAFBA5D1AA61257D5D5A88511FB97C98AD2D8E5510A4FDF5AADB14CF2B4E93E5D5ABD2AD0E93B4AFA1A57CD2DC2
    9   2560 002001  1692126720000       34560000 DD010509 0B77DC3A2440E1FFD0C03FEA956E1861860EFB80DC0AC8BFAE321D6A8E362685995A4870A1BD7D0DF26A6B9FA986E6B437D0B34372FABAA8549FE6230D33E7E9613F734D54E7CE6DBEAD5A9BD86E96707DB258902DAA7E9923E7EE95399D5EBB98546BC28F495A0735D35A875B5A654E6BBEA6A9F57535DFA0ACBA2217B4D2D3
    9   2560 002001  1692161280000       34560000 C5832862 0B7744932440E1FFD0C03FEA955E186186104AB3FB69A1AB7A99D428A1E23AA499D29AF4A1B9AEE6C0DAEAA7474CE613F7CBA1B9AEA9F3B4AE6B6FA6A9EDB7CA9F3F4B3A1A97E95F56850ABD276E965C7DABDB976BA74109243AEBDF3F490E1BDAEA9A537EF943FAB5DC5C5E96E3DAD4ABA69CFDECDAEED2614CE61577CEA9D2
    9   2560 002001  1692195840000       34560000 B8AF302A 0B77761E2440E1FFD0C03FEA995E1861860D1EDD7B6AA9C03F61CD786E223F52E92C67D6AA3DA35EBBE7D514BEAF46E0D5E99DA0855DF527CAD53A5CA9ED77CFA13F5B0DED74E96B3E74F9F3EA6898707DABEF30D0D3AEFD4D74CD1FD280313C35D0CFDD7B61FA95D5C92690AA63F4F63AAD6215784B13A57CA955774F6239D4
    9   2560 002001  1692230400000       34560000 3B029C44 0B77012B2440E1FFD0C03FEA957E1861860D2233FB6AD38EA14E15756E183AB695F3E7B5EB3E56969BA856ABD326D5FA1A6992BE88961B986AA756A699EC37CFAB52A4FD2428FADCD74CED0C2735AF577DB266975F518A59CBF5D6DCBAAF21EC02484EA54BAAC0D86F9F574CFC8B97D0DD3F7CF9ED77D0DF3E72F763EA6A6C29
    9   2560 002001  1692264960000       34560000 1EFA8A76 0B771C3D2440E1FFD0C03FEA955E1861860F0DF2BB04932B7AF9F6B76E2E39D8890BF710E1AA530A1BB4B0DF55B8E61A686F94D34CFD2DB834E9427EE92C35CA94BF54AA95B4B0ABE6730E13E74EA53E7DBA5AF5EE0E7EF9FA749ADF20B94AC2154E9529749A8C3AEE9EBE835E1BDAD0AB584AFDCD3A695FBD854D52AA35E15A
    9   2560 002001  1692299520000       34560000 A4312839 0B773ACD2440E1FFD0C03FEA955E1861860F1DF44AC9D53F7C96A3D4D47AB5B021F3E7B7EBC24B5EB42AF4D2C28A9882686A9D3A74BAB6AADAE142AD6D725AEFA13EA4FDCBEB0494BD8EFD5917B515D77DBBEB2EADAA7EAD2C771713A55509F3D870A1B57CF973EA4E9F3A4E892C1E03600C7D4DF4E4EF9ED79CBD4BF7CA9DA5
s=10 n=26 o=12370575360
   10   2560 002001  1691435520000       34560000 5CA4D080 0B770B0D2440E1FFBCC03FDF9D5E1861860D6EDBABEFE1A76F628F044E24BB795265D69ADED785375AB7B21B3A7D39F2684AE725A89613DB099F3F2306DBE7EE92BA23AE3DA7D4ABA5855D54E7CFA2707DB96B174E6BA35AC2F4B335BF8F46E2B633BE86EADAC5499F43739DB5590EAB277D106BE72FABB9A6AA8EBAEF61BDA5
   10   2560 002001  1691470080000       34560000 208CF437 0B77C0BA2440E1FFC0C03FDF995E1861860D0F80DE0AA12754A9D577D33120E04A6C449C1324C0D5F3B7BB08C37CE6BA27D0A9BA736E93F9E95F3E8546DD286F6BA9A54E93E7D0D2D2850D4D824ED3D77DC1790B97A97F392E6A549F4340FDD397D21DC22499F3F4CE9526749A95BD713D4D5EC21BEADFA6A31EB4356E30A1A4
   10   2560 002001  1691504640000       34560000 40029188 0B7715C42440E1FFC0C03FE0955E1861860EBE008C29C893515B5D65F430A28639EC44359CBE8EE612C737153E5CE9F21B8993427D59FA1D54DF3E7E461A5548A9479CF9F527CFABBE7B5ABBF4AFDFF07DB44B286BAC42594C280429AB4296D57859B556AD5DF267CFC924A6BA6C021608BE7CFD2C35695FB9AF09F52D6E92D8
   10   2560 002001  1691539200000       34560000 B9C46EBA 0B7743E32440E1FFC0C03FE09D5E186186105AB3F869AB3F79727571CE2F0CC036B434B0DCD6A8E2DC3731153E55595267CFE8BF4E95D3E8045F3A84FD2BF9C83839A3B28D84AF9FA64C49F29DEFACD77DB182D1A45F6BAA042AD0DED78EBAB5262BAABA46345129A0D79D4D5CCE8EADA68035B2A49612C01712943750AB5322
   10   2560 002001  1691573760000       34560000 632F68DE 0B77B9462440E1FFC0C03FE0995E1861860F71EBFB69C93F70FDF577CCFBA1D4EB32F74F95B89096B5373712C3734A12E84F957022F953F4B610584C221BA2B5DD3D7EEAB525B5E128E255D8D2D070FB6DB08F4CE258435E4A27CE5EC872FABBEAD5B5BA729A2524CA6142B09892E7B1780EFE1BE8CC1392511E6F04EA57BEBE
   10   2560 002001  1691608320000       34560000 5BE07BF1 0B77155A2440E1FFC0C03FE0955E1861860F0D6F086F93A27AFB3D77E7E4B9B0D9CC84B5D4C2608212C4B0D3257B4E126B0AC64286FDD39A50DD90AE99F3F54969C23F22BC1AEFD5119BCE93F9CBAC707DB20ED11EBE75599F67E81FAA495EEA0555E8EA7B6153EAEA92BE7CB9F95889693E79BF839AEFDCBE7EFDAAB4CF6356
   10   2560 002001  1691642880000       34560000 C9A3DF00 0B77366F2440E1FFC0C03FE0995E1861861049F4386A6C2A7CA9D5B7E7BD4DB7010C3436972DB8E6B3B850DCDAA35E1A1B099ED79CFD2D27D0DF2F4296BAB547216AA4ADFA980455A54AFEBA97E96CF07DBA6BA9337240F622F5345F44194DF2A7CA6BC2A5012C374FDF401A36935E2BFD4EFA425BEADF9284F9D6B4D56C36AE
   10   2560 002001  1691677440000       34560000 18D52D12 0B7774962440E1FFC0C03FE0955E18618610AA13F86ADF2A7D3D2D28882EA1AD0DCDC6BAD338C086B4472FDD2B2492BA985112BED6A9EC37CBA9AA74F94D44B49F57377218E1C9D2B97655DD34B5E0707DC42B086E251B0EDAAA3712BE54A77575E868D77E32BBE74F92C2D8E6129AF0B625A171F434AFDB2956A63AA76961B9
   10   2560 002001  1691712000000       34560000 8C9E6C7C 0B772BE52440E1FFC0C03FE1955E18618610FA13AC0EDD135AA9D568A7EEA1AE39D2A7D59D3D9096BA67B60729A4FD329AEFA7AA4B0D13EACAD33E73AB6264AEA13EA3AE94E4CBDD3E231103AB70AEDC7DCBD86AA6C3110E9DF74F6DBE195F5447495D3E7489EBF4C9693F4B5ADA676A5F26735E1AA9AFD2D77CE635B7D09F3D
   10   2560 002001  1691746560000       34560000 0D32546C 0B771A2C2440E1FFC0C03FE1995E1861860F61F3AB835D9284F9CEF88CEEBDE09A6C44AFD2BDB2821A7410D5BCE0F9EC4430B5BE74ED2BDA5714BF84E9F3E7D4D4DB715F33A554DF257EB9F3E85515F07DCAA7B3A9F04B061D87C22A3D6D06929ACEADDAB896BBE7351AC37CE9FA62B63B70E6E26B4ADFBF7B4A96B8F461D27C
   10   2560 002001  1691781120000       34560000 B4091EE0 0B77B9122440E1FFC0C03FE1955E186186129638E8E995A76F71F577E7FAB9E6EAB444AF9ED77E96DAB4AADCC37E929AA56F9ED27EA960CAE961AA74F6B57A4FDDA54B6A15590B9F4342A9CAB7D4A5577DC2540FDF2A7CE6ED8B519F3F2B01057A6F9FA57CEAB21B709D3EAE95F3B230A3BDDDBE1CDAEAA1B8BA7153DADADF27
   10   2560 002001  1691815680000       34560000 CB4B11FA 0B7752102440E1FFC4C03FE1955E186186111B3B9EA39D667B61AD74D46439B84D2C2A5AA155B8E7558A3606568A321ADAD0E6D6A8A5F4373508BE7D1A1A584FA93EA835FA98EE5F6A83814C2ACEE2707DBBD7171F2A734EC5CA7461A97EF9CC2AF1EBBE5292C12A4F9F437E51FA9ACADFAA4B5DF42A30E92A5F3924022E9FC1
   10   2560 002001  1691850240000       34560000 F9C47D0A 0B77E86C2440E1FFC4C03FE1955E18618610FA13BB6B08BB4A975D77EE2239EA99A6F9D5D2BDB8960C87B0E1D25CFDF2653110D2A35DED854F9F3E7CF9F2AACF9F52A3BABC286F9FA490E51F58E8A4D77DC2986E94AF7CBAE2A86E92AA7D61524894AB3F4495FCE52B9F57734DF267CF9F3A7509F579B0974386E54DC54F61BF
   10   2560 002001  1691884800000       34560000 800ABABF 0B77BF062440E1FFC4C03FE19D5E1861861245F3EC04D13B511B7752356E3DB6EDCC442FA13F52FDD8D750D53E7D09F267B71F3E7CAD4BF7CE5FBE7E4886B74DEC5A517953A2EE9EC2250943153B2BF07DC314D095577D0C6BE9BC1FA5A70EBB5E5C258A4632C54FDE56E15953DBAE5F434B0ABBDB6A6C3E7ABD54774A61BE7C
   10   2560 002001  1691919360000       34560000 9402C8BE 0B77FD7F2440E1FFC4C03FE2955E1861860F0DF4FB6AC8C3D30B843247F05384E9F58415DF3E754A13E84FE12F4CF6BAB4B0B5BEA685ED84CA9F3EAD49AC47AF6C297B0E95690E52BC89697407CFA4D77DC0B8773A2A869D252AF05D57850A939B096BE5B081CD440FB76A5771F2671AE956AE99552AF0DC52BFAA143736DCC2
   10   2560 002001  1691953920000       34560000 CA771310 0B77302C2440E1FFC4C03FE2955E1861860DAF5BAC09DCB07A973DB76CBD65E039ED77CF933DB0F693B7CADD3D8E99EC38311D3E84E9F3F7CF6BBDDEF9366855A1527371EA58761EBD531EB27AF3AED77DB9F7F8ED2B9CBD238B0F8943A4FE8A684A9F56A535634750294DB8A952086BA9A5AEA9F4384FC647AF45743A4FA0C3
   10   2560 002001  1691988480000       34560000 4E8C700F 0B770A152440E1FFC4C03FE2955E1861860F4B7D2E8ACB2EA30E96F4D438CDDEF9F427D00B0FB0A9D2B4BBDFAA56837BEAD0D2D7534E1A24E2D3544AE94D9234A9557EF92BE6BBEA247CBDF478F39FF17DB9F9DDE3AAD5714A074E5356E0EE13E836DD437ECEC56830106BAEE93427CF61BEA546958A536EA44CFDEBA7D0DF41
   10   2560 002001  1692023040000       34560000 727DFE1F 0B77F4EC2440E1FFC4C03FE2955E1861860F0B025C0AD2DC490DFC722E5839E08533E74FD33E530D726870D53A7682C20AD61F267D5A1398F5C6D754957BE84FA8D37B4ABB9AF4DEAA9ABEC29A5B20437DC0B53ABE2E7BC26BD4CA543F80FDFA48899ED7A4E24B9B6E5F675D0ADBDA55ABBE9E35CD77EB69BF4B5D5A04B0EDBE
   10   2560 002001  1692057600000       34560000 4446EB95 0B7764362440E1FFC4C03FE2956E18618610FABBAB699540510DDBF24E243AAE95329ADBDF574B0B5BA870DD3D8095F3EAD19FBE435E9B98A21FA55CE622984823D27D0E6AD60AD4C36ABD5A639224707DC867B6DDDC7EFAB267CE68BA5562E287F092D37E318267C82D5D73613357D608BE7B5DD3A7CFDEC44A955BA4AED351
   10   2560 002001  1692092160000       34560000 18ABA215 0B779AA32440E1FFC4C03FE2955E1861861136E21DEB12C8994E16B55361E6E2221A57B5E9BE434A211A5AF35686E9F8D7CFDF4274EDCC27CFD352A6235C2AE1B928CDB12BE6095FA4A4FE96B6FC6CD77DC3448ADB43AF5D6C072F88BE871559FA6F9FB9A5439D6AE95FBFA50AC3956D5F3A7B5DF6B730DEF07B45FA4874A1BD
   10   2560 002001  1692126720000       34560000 2738D363 0B779B312440E1FFC4C03FE1955E1861860EFAE0DBEAE143CCE6BD755463D6B0852D67EFABA97D4E12ACEADAAEA4FDD26759A93F76333AA8549DD2230DD3E7CFA9A5A50D33DAD5AC21A6A735686E96707DC0F7AC5EA7535A9721725CAFCD4E8BF9B59FD284F9EAAB6E1F5CD0994BF8CB553EA6997397CFA1BB2E973419D01520
   10   2560 002001  1692161280000       34560000 8BDAFD26 0B77905A2440E1FFC4C03FE1995E186186104A20CB84A011AB6ABEF55430A6A499F3A4D46DE6AEE620CE0E9F427D56C257D5EB3E855DF274AF6B6FA6A9F3E835DF55B059CD2A4F9F42A6A6BBE9EE965C7DC0E7B1A1C8B0992528EAD2D422FA9534CB9FA67355FDB7D5E424A6F9F2EAD13DCD5FA2684ADFAA79D215B5692BBE7E
   10   2560 002001  1692195840000       34560000 4076EE0B 0B7763402440E1FFC4C03FE1995E1861860D0EF0C86962274AAA0F086DF0CEAE35EBE7D6AA257B6E1BE7D714D2809613A7D0D33986B75D2564953A84F6BBE7CF75D27E95F56B50E13E74FA13EA68985C7DBBEAD6EC3FAEE693E754EAD36F75726A50A9BD86EA9D74096C397D626C072FFDAD6155B84B13274AB5FC34CF61D37A
   10   2560 002001  1692230400000       34560000 E636C4BF 0B77CAA22440E1FFC4C03FE2957E1861860D221BAAEF95BAA31B5EF7E8FCD286829C1AD5E13E56A69BAAD0E9437692DA67E992C04AFD5398EAA9567E96B6B7C9A9A6715E9257F5A16A7F39D3E735BB577DB29D901D257E979D85E99F919A9E788DA8466C514DF3EAB0AC3D7F45F8CABC533E7B5DF3F531103F7D49CC92C32A2A
   10   2560 002001  1692264960000       34560000 4F36B477 0B77EC622440E1FFC4C03FE2955E1861860F0A23AB849F277AF76568732451D74D326710E1AA530A1AA755DD5686A9F268855D3E54FA9437CEA994B0E94C37CF9D4E7361CD74B0DD3A7B5E13E7CEA53E7DBDD7E2614354EABA9AF49FBE74E93298D9ABAA52F9FBA74F9ED6853D53E74F9D527D0A9BA8031FA9855E9A5ADC12D6
   10   2560 002001  1692299520000       34560000 FFDA7FF6 0B778CD22440E1FFC4C03FE2955E1861860F0ADDCA2B13437CA94EC1CF6424E8955A5537EBC2430E13E8D71B3D889698D8560A434CFAB42A5ADF4286FCABDB092BD2750AB5286FA1A4875DF29ACFE0577DCAAB086BAA7E99D43435CB39D6E9EC35D0D5257CF9342A4ED10CAEF9D3E7B4DFA57EA7620A8F9ED6AEBA96A8F0A13E
s=11 n=26 o=12370575360
   11   2560 002001  1691435520000       34560000 04D67827 0B77462B2440E1FFC0C03FE1955E1861860B72D538E99FBB795F36C24CE4CF8301C48735D4D68EE61AA7D5DED77D47811AE9A93E84FA3B9A73A220854D4D6AF49EBE55AE1BE5D49ED77D0A1A9A55AE757DB8C5FC1F3E447E9AA8759EDCE6F9F5C174E1BE4AE9FBE7B0E1D2417232ACF5D4BD7B621BE9D5D4D6AD752575549FBA
   11   2560 002001  1691470080000       34560000 2D1F3E8D 0B7774CE2440E1FFC0C03FE19D5E1861860B72B3FAF0AA117B610EB4F330B4DF71C584BCD529BA21CC44B0DB3E8695F8DA70A93E7D5DF527EF6156CEF934DA759F4273A1D3D86AA0D6B84933A4B0EE5C7D3C09B0B8537CEB5EC23115A988A9551F9357AF3E191A899A44A549FBD8EFAE12716275284E6E2252A9FD674FD33A7B
   11   2560 002001  1691504640000       34560000 4C2DDFAD 0B7785C82440E1FFC0C03FE1955E1861860CBEB43B6FDF16CB11D3E76D2439E04D2C34BADCBA8CFA0C4A6A953F4C96B9DAEA9D56ADADF267CFAB537CEA93DCE875C27D0D4D2A55ADD37CE61A9869A2707DBC285C692B7C9699674F9742AE92BD6AF3AB41AEFA94422A5FA17D0E7224B108537B0D33E888553D88961BF52F9F3F
   11   2560 002001  1691539200000       34560000 26DCA5E3 0B778B932440E1FFC4C03FE2955E1861860CBEB53B70DF92715F56F4D46EA0E0FAADB735DD51B0A735872C13297D0D5257D0E93E7E95F537EA9F29D6F6B677CE6FBE7BB1CC442F61BE7B112D27E96CF07DBC3869DCBF8031F5685610AE8CE9F437EE5FBE4AF6BE771B1C5BA746B3F54E952A54FA93F5E46B4EA6F932B4AFC942
   11   2560 002001  1691573760000       34560000 7E8D0222 0B77A2FC2440E1FFC4C03FE2955E1861860D716C3DF09FBF7AFAD6C24D24A5D69AB42A6A933CC0E6D5854AD2BE84F9EC37CB5FD75499D3A9D1D52A72B7028875D2C3234B7572AFD4B9B79A0EAD1376E253C082A96AF1E2F94A47EFA3DC74A9CD67B4EDBD850E1BD7D0ABD571AE251A6995A64AAA9BE7EFDF2D86E735354F6C3B
   11   2560 002001  1691608320000       34560000 1139BC1C 0B77F1C12440E1FFC4C03FE2995E1861860D214D8A50A01272A9FC3266A521B0892D8496D2D1E41F7589B712C24B0A98EAEF9EC7854DDA0BEBA15354E938D7CEB36A4722E3DA50DF2B190D6D77CFD8707DC0B538B5117FD52BC92F2E52A691FD77EA6142DF5E952AF0E8C37AAACB57D03A8D4E3D37CAA1BF715EB5B7EF6425E6
   11   2560 002001  1691642880000       34560000 C370126F 0B772B3B2440E1FFC4C03FE29D5E1861860EAA157B5BEDBF495E9582CCF0D1C09DCD76CF8B2654E9F279D0D066AD0E13E86FA93ECD5D53A536DF3EA6D9ED77C92DD6A31532554FD52974AE93A74ED7F57DC26EAAA1CE55595417F4A46BAB8946C95B575F4B5404E9A8BF73B1350BAE9FAA69B50D654F6E2584C133A433A1AA54
   11   2560 002001  1691677440000       34560000 DB439E5A 0B7721C42440E1FFC4C03FE2955E1861860EBA3BAAD71F925B5ABD724F63B9E0AD27073BD2EABA1F811A50DD527D0AB2A7D01243A6A94C2A55E93E7D5A142A6A624D6921FA124FD4D1A55CADBA6FA460AFB918F11D57AEE68C474F93434CA363E5500841AF5953F7E886B9855DF3D854DF3E7D4DF29AD5EB43A35DF42851A210
   11   2560 002001  1691712000000       34560000 C4C6E717 0B774B6E2440E1FFC4C03FE2955E18618610F6DBAAF4DF36AD0A9D67F56E3DB889CC37B6DCE688E6B3F5309FBE7B61CBAB6E9D427B210C2ACFDD527D01256AD5ABA679B1CD285212D244F933E86AA4F07DBA5929C92B7B00FD854F94EFAF46B52AF4D7397D0D4D37CF9F257EF69C2A4FD525A8951258135D437CF9FB97D5A157
   11   2560 002001  1691746560000       34560000 298F8538 0B7758252440E1FFC4C03FE2955E1861860DC213ABEFD327791E9704CE30B9AE9A8C4535D52990961275309FBD88F61434CFAB434B4D53DACBDF91A509F577B0DF3F48FB5B5870ABA9A35E13F75613757DBA0E31D5927CF69584B0A1D67CFA1A274F9FB8A6B9F52AD59FA986E92D27EE6DAA54E69C37D59FBE54F755B7E99F3B
   11   2560 002001  1691781120000       34560000 68B65335 0B779CA12440E1FFC4C03FE3A55E1861860F5D83990E7626B046156D8A953A86969D6CD59FD1E8A5F43839DD477AF61DDEBBA58A9A14474A9CC34B5A97074D6B2E7739FA97311CAE7D45FBE84F6E264B6AB3EB56E1B9869CB25A6FD2D27CFD2D774FA143995A02675091262B4DD42B3D5FEF4AC21B6B1326A2FE9572D49FB9D8
   11   2560 002001  1691815680000       34560000 98A2EB6A 0B77B2502440E1FFC4C03FE3955E18618611075BDF2995BA530E6EF807BB9BEA39CDB5549F525686B3F851D2BE7EE9F3DAF0A9574509F29AEFA9A64B608BE7695F3A74F9F427D5A342A6ED0A74ABA4DC7DBA0874D049B2952399086068534A13EB2952D67BC1CC37CF5F274B0D53A53512AB4B5A9BF6921CD74D5A940195DFB8
   11   2560 002001  1691850240000       34560000 6EC9CB48 0B771DE62440E1FFC4C03FE3955E18618610A9F3AE0E9DA671AB83F56DF0B8EC366C2A6FD256AEEA72C4111D297EFABA5A55A956D6E9D29BEFAB434B4D4C37CB6BCF67CE1C1D896B5286F9C447B5B9707DB8CB4FD258B95D2398896242D6A9F527CFE12A4B5E1584C454D3A4FA7A674F9CD7736DED77D112C27CAA15276FDEC2
   11   2560 002001  1691884800000       34560000 BA61176A 0B7758C82440E1FFC4C03FE39D5E18618610A94C3AEAD33FAAEDEEF4EE38A654AD0C43AE620D84FB3B67B712D67D5D5125B612C37C99F4284FA95774F912A4C6E2B883155BA2CED30F7F0C7DD8056C707DBA09247CD75559FADADC21C254C1F8994C2188E61407CFEB3A8559FA588969BF1AFAB56850A22D84EA9BE7E45FBD86
   11   2560 002001  1691919360000       34560000 F7D99EE3 0B7747132440E1FFC4C03FE3955E1861860F0D53EAD615277AE9F58234623AAE99D3F735DED67CFB7A77B11257855A9A7410B839CE99CD84B4B352B8450D3AC95FBE797294288A54BD2D5D4C97AFEC707DBA582F6D48915DCA4A50E0437D09D3DA4FABEF4CF93A9AD9E92E554DF26A34DED84C95F534D5A12F431D326735D53E
   11   2560 002001  1691953920000       34560000 819FCE95 0B77A1A32440E1FFC4C03FE3955E1861860D5E1A5DF5DDAB7AE956B5ECFAD37C96DBE854A14356992A6B50DF534C9752F530DF4354E92C37D4D4BF54F92DB7D0A13E7361C3E574DEBD7B71EB08D0A4DC7DC0C8496AD7BCF908CAE9A2BE84F9F2E4AFE1BE4B0DF3F7CE9F8C86F9F2E7D0D5257E99F92534DF3E7EF5FAB233A156
   11   2560 002001  1691988480000       34560000 9BE45A7B 0B77F14C2440E1FFC4C03FE3955E1861860EFADB9B8FC943795B63E5733B1BE8A61BE4CFD5A0750D2587D106EA7EE6953A4B9F3E853D3127B3893F7C9676BA6A6955A8E5F3A43714D69BBE9D7803226155BA4B6A6B3EECF9C3EAEF604484F9EBE5CF9F56AD8133E8509F3E731D32B7AFD4C3556A939870AC2524A61BE7BC5F29
   11   2560 002001  1692023040000       34560000 549DB921 0B779B5A2440E1FFC4C03FE3955E18618610A63BE850E949170E156D945825D69952A735DF4283B12D3855DFB9855A00D72FDFA64D46B3B4CF8AD7A4F9D437CFA6BF7AE9FA0B76EABF494EC5286AA05C7DB90C2F6BEC7B712AA554A9437EF9F21735E6D77D5DCC354AAB527E961A6535A9BDCEA61BF24F61BA86AA952750A152
   11   2560 002001  1692057600000       34560000 B0293E3E 0B7749F42440E1FFC4C03FE3955E1861861096BBF7CAD4C87B4AB577D5A3A6B8886A9ADADFA9754AB3F7EAD2D256E6BB9AD6AC3A430DFA490E6DB9A645FBAAC329BE5311CAA26A6C16211EBD26FEA05C7DBA0E34B5615B0A1A47DB29518719CD37B46C3E74E63BEAE96BAA7D5A990AEFA1437B4DF429D5DF3F73B126786E5FE5
   11   2560 002001  1692092160000       34560000 69051F97 0B771A5B2440E1FFC8C03FE4955E1861861096E08E711EC484975BE58DE4CDC0355A07D5E93E7CFA1B5D70E93EAF369A673612D67D4DEC374F9FBE7C5383F4A7F12599C213D8A854C27321D429B0ECF07DC129089F8E434A9BD754A1AAA6A9F2954992D2D6F75D374A5FA67AFA1BE54EA1A556F61BE84FABAA550DF29B096938
   11   2560 002001  1692126720000       34560000 ECB3DF54 0B7721842440E1FFC8C03FE4995E1861860EAABA2B6AE72C7282E427746439AEF88C256AA141855E00CAF0DF29AF36D447549F3F4AAAB435CA9DA97BAD552AEE9F39AD0DF42AD4AB52DD608BE7D46F5C7DC705CADF25AE9A1A47D5EB527EDA33E76F55BEB0469BA7EA75C75311CD34EAFB6D0E3BB5B0153B7C961477EA932686
   11   2560 002001  1692161280000       34560000 9D86A5CD 0B77BF7E2440E1FFC8C03FE4B95E18618612898177D5EC0E754D3434B82129B0A71F1612B07CD9F3EA5063AAA6961A5CEFD2C374ADCD7851E9BF7CF9CC2D8F9543EFB57BEFA32C555DC4473AF5A58709F3A4B4D2BE90A9CAAAEEA9BE7E961BE7D4D2AF74A6C3976E612AA1C5F2A74F61BEA746156873620E4AF6C217D09FB9BD
   11   2560 002001  1692195840000       34560000 0CC7BEBA 0B7767E02440E1FFC8C03FE4955E1861860D0EBBFACADFAB514E952B08F0BDAE95F3E7D1AA257B5D7AB4AFDF3E7EF6BB9A5112D27CFA1567EADCC2A699CD2AD4A15AB045F56850DF2674969A64CE6F5B87BD87EEA0AC74F952488FD26C2495F3DA6A2BDB84FAB42855DF2A7D49F3F72FA1A9A50D33E850DF42A6F9F3A7E96156
   11   2560 002001  1692230400000       34560000 B91D60AA 0B779AB22440E1FFC8C03FE49D7E1861860D12127AE4D2C2DD5126F56F3052B0829BD7CFE93D8EED4BED6F9FD324E6BB57EF9F3E7EF9FA4AEFABBF215DF2E7D4ABBE535DEBA555DD3F230953F4C96CDC7DBF586AC8A9D6FDF3F58461C0301F56CC7BA686FE1267F0D4BF7D5D5A588252BA7CA9326AD09F3AD8461BEAEEA024B0
   11   2560 002001  1692264960000       34560000 8C48EB43 0B77F2372440E1FFC8C03FE5955E1861860D1E140850A1C0495ABD3768EEB9D739D267161F3E830B691737133DB09613B56A67A64CF9F57515EB532E990BE86A9C6B7D5126C710ABE67CFA15352FAEF07DBDCAE86BAE7D0DF3F735E9BE4CD92BE854A1AA4AF9F5376D5CBE834E1BD7CFA9BE736DFA67CF9FA57D10ABF731D2E6
   11   2560 002001  1692299520000       34560000 7A8B0E2C 0B7785102440E1FFC8C03FE5955E1861860D6E15CACADFAAA4E744243AA424E0A5FB9856E9C19B5F5AAA6E953E60F69368510A3F4CAA1529D5ABBF2B0ABA5A6A6B534B1E0D77EA6BBD854D551B0962707DC2FA835FAA54FD4C37B6DFA5854DEC354BD2BA74E61AA84E92BE7EE94D6AD4A1BE56969BA4EF6156AEFD2BE86A9F91
s=12 n=0 o=12358643712
s=13 n=0 o=12378568704
s=14 n=0 o=12378568704
s=15 n=0 o=12378568704
s=16 n=0 o=12378568704
s=17 n=0 o=12378568704
s=18 n=0 o=12378568704
s=19 n=0 o=12378568704
s=20 n=0 o=12378568704
s=21 n=0 o=12378568704
s=22 n=0 o=12378568704
s=23 n=0 o=12378568704
s=24 n=0 o=12378568704
s=25 n=0 o=12378568704
s=26 n=0 o=12378568704
s=27 n=0 o=12378568704
s=28 n=0 o=12378568704
s=29 n=0 o=12378568704
s=30 n=0 o=12378568704
s=31 n=0 o=12378568704
s=32 n=0 o=12378568704
s=33 n=0 o=12378568704
s=34 n=0 o=12378568704
s=35 n=0 o=12361482240
s=36 n=0 o=12378568704
s=37 n=0 o=12378568704
s=38 n=0 o=12378568704
s=39 n=0 o=12378568704
s=40 n=0 o=12378568704
s=41 n=0 o=12378568704
s=42 n=0 o=12378568704
s=43 n=0 o=12358041600
s=44 n=0 o=12378568704
s=45 n=0 o=12378568704
s=46 n=0 o=12378568704
s=47 n=0 o=12378568704
s=48 n=0 o=12378568704
s=49 n=0 o=12378568704
s=50 n=0 o=12378568704
s=51 n=0 o=12378568704
s=52 n=0 o=12378568704
s=53 n=0 o=12378568704
s=54 n=0 o=12378568704
s=55 n=0 o=12378568704
s=56 n=0 o=12378568704
s=57 n=0 o=12378568704
s=58 n=0 o=12378568704
s=59 n=0 o=12378568704
s=60 n=0 o=12378568704
s=61 n=0 o=12378568704
s=62 n=0 o=12378568704
s=63 n=0 o=12378568704
s=64 n=0 o=12378568704
s=65 n=0 o=12378568704
s=66 n=0 o=12378568704
s=67 n=0 o=12378568704
s=68 n=0 o=12378568704
s=69 n=0 o=12378568704
s=70 n=0 o=12378568704
mt=0x76bbb591d580 n=71
s=0 n=1 o=12378568704
    0 1195573 000001  1692205515000       45045000 9BDD8DFB 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=27 o=12358785024
    1    482 000000  1691437860000         900000 232968B2 40F19B80602C6077609D60EB579539BD90070FFB8611D65F679D70E0D97432BFBD4558F22AF35C98D919F29356312CD96652DCCCF87D21CCB6996223360E24C1EEC271557827D1C0B00F2B6F243D0A4E20978FDAC975AB6AC80DC8019767A526AC00F7436FDE445F0F66D1E7EBF8ADAEE62667BDF4CA7C3A3D0BEFE8CC56FA81
    1    478 000000  1691438760000         900000 4B41E528 F0EF9BA8702C6079609E60E94BAF575B661144C3E0B66227480F3564EE03DA8AA17CF98DE73C7B33B8E50986595D037551405A50278BC2A5D9A7453A09697707C23DF6206F89223FBDAB8DD960FDE9AA56E351E1F4572E306C64DFB3B008E2682CA8764B0D5FB3DF50E178713E4488202BB0F83A22A8A80D0BE1B108A9747862
    1    546 000000  1691439660000         900000 42197DB8 F1119BD0702C6076609C60EB16A936A883C57C55106525FC1B11D49A51543EE5AC3F70B1F86A1DE4D5B7D9992E737B69089437AF5CC0FE7BC9C45D1F840D0D1B9B7F1C1232F755E9D927F0C796DC9159982D7BB3FE4387937FA0A98583431126B5C0351B3031F946983C295EE5F27CC733EB6AE8ABE45E8C1AD27BC36C9F9BA1
    1    482 000000  1691440560000         900000 E488C1B6 70F19BF8702C6079609E60EB2436151AD63FD56D9531FC55AF380E3C46F5316A20B02C4C0C6388148C2C14B8C9636981FE19059A5CCE1C2EFB53815CD8D79F97E33FE7C43C06B3E3C3458D629F6CA8913F5D87DC174B776E766C1B4DBB7E5B6B8D82BEA425406351A49345CDE0D608EBD8E323AA7021A44D1BC9DCCF90302B1B
    1    488 000000  1691441460000         900000 3FE07DBA 60F49C20602C607A609F60EE5307B4B19DC08D4DA2B24E45E184F28F8835F8B2AD546DB949506F8D6FD5E3852282C93C51D690AE3C35265D1131CA3500C70156927D49C9C2BF7167866417E848867E6CB5D8C8CDFC241497CACA397A8A85F94D6EC5EF2019586762B5D994CF4E028AA30A0AD2A4CB7434A003F27169CA40EEDA
    1    494 000000  1691442360000         900000 93306CC5 C0F79C48702D607D60A260F102909AC16879396D6047499608CAE0BBF5D3BA73DC958662CD0E3EDFB955E5F3A6312EB4D080AF48DCBFE244A3521D49DC57266D7E1E276424D6D9AE56A5683211F31BDE8A3503553A402D1486FB41BB3E212E484F75AE507C9D03BA3A052FBB5C602447909AA248FCBDA83080C2BB3A5E7EEA8B
    1    484 000000  1691443260000         900000 34E5B39C E0F29C70E02CE4F06078609E60EB70B9C149B311955ADF5BF99AD733D68E194C58BCA6E3BAF3CD6F69B2D7A5459CEE6D2D1BFADEED9D4ED11C977D311EAA9FE68A5289D60903E508BC4236388362CF4E77C88AA8F5A45375233E97911F6DE2D0BDA3E180FB5B7FF7BE59D5C657F0FC49855D32762CDA8D2F5EE2175E6E12CFFE
    1    482 000000  1691444160000         900000 874D92BF A0F19C98602C6077609D60EB0F900A27BAF1BE61E3A024E0779962A3961225D3DD67D5758C583C180369C8DAF42DF4D25524AE1FE27C96BEC59794D691D71D95767B5B4D44EF484F8B3E1F63A24AFA4D7FE2C3220AA8D1CFE716AB312EC7B383E9BC968504A4B67842FA740BBD571FF1CEF9D05ED68FF7D8B3F9E4CD854888AA
    1    474 000000  1691445060000         900000 2AAD856C 50ED9CC0602B6074609A60E753C73303D6B1916DA6BD7650ABC8D0B44B1FE248A652EACAB35BB79D08FF722A737F6D56BE1917F6B3EF253C95B4AB2E0F450B7F3F34F16228EDEC75886DF878E4BC28FFD288EC8F07D64A96A5B7EBA28F518B4E1F5B41B1878F6F83847D042F8ABDD02EF47F41CEB9E9A40CAECEB2D94BAAD33A
    1    480 000000  1691445960000         900000 95A81D0F C0F09CE8702C6076609C60EA722E5624DF716099367F0D04344EC5622E21B5436D605E593C8E85B2932AD94531FE0AC7674A30689E99F06A529072F415E22EFDFF7175DA3C19128C7879A3744FC747D768B651A66022E1AF990EED2A1C93499EF6D4CF143BF3F4B9B14E101D1FD222A8F48CAE574741C619859CECEA2D3147E0
    1    484 000000  1691446860000         900000 6F3B1D44 30F29D10602C6079609F60EC5A0FB52B18940E2A2831A4E66EC293415F857F507239580DB14DD8B1291B16A8C74AA3EFD839CA3ACFB13C52BE9DADC5DF7D048B32497F396E9BD3593D455F17DEAD0F873D13561BE7DF1C3469EDC097DA38E336234CCA38703638F9AB336AD4FF95A97F18D54FED4D2C14D7499C1AD2E1DB0FAA
    1    476 000000  1691447760000         900000 7724D6D7 C0EE9D38602B6076609B60E81FA2E9A5F49D291D8911B2EC1D0E15FB1539EC0BDAF85CE7F1EC97A77C70BEDAF215983FF949897F071D2DBAC35EC1FF0DAA007D86D9078AF179EC367EF338BDF62FBC8C9CB87A219E6292118DFFBB5D3067F4E06DD07BB8A395983F33348D1F653933FEDB2944618DED87A57272E0BB7BD95DAB
    1    476 000000  1691448660000         900000 A5FF8537 00EE9D60602D6077609D60E831964E654FD92C5FD55C6624ADF2853BB31F07A3FEC9DD2EE0D66C3963582E5FF499A94F13D390F30EAE476329281A96869568572B32C702E2EA5DA85D4B425EF12D523443CE9F857D93C16626D4569D20D4751A7DDBA000E9EC350AF9DEAA88A78AD86D70B743DAD828A2F7FFA5165766E54A95
    1    498 000000  1691449560000         900000 726263FF A0F99D88602E608060A560F349F042F6096F0FC70FE3FEB24AED5D55E95A1FE7E829CDA83D262077B5A7112555F2525ED7FC4945BB0DCF6E3563CB49C40EBEF1A78CD9036B1A63303BF0DB55BB92FE80600DADC7A821235439A57FB38180BAB61FF0B93072C0FB7B8088E7130F9E02BFD8E38C0EAC67A61CC985EE9E8AD35B37
    1    496 000000  1691450460000         900000 DBFEAAF5 20F89DB0602D607E60A460F252EED0AB5C39311BE755F8FE944604B8B7411AF2DA931E315A0DD0908878458F8711EEB3C5A9B2A0CEC371BE3BE0D3CD5BAFAB2243204BC3BC79D30A322D106D5F4C2A0E503735197BFDDD35E7542FD281554FAC86D4E3A48A065AE5C7F75FC0CE6EC6C6DEB69B8BDF779954ED0B0B034BC30D58
    1    488 000000  1691451360000         900000 A86D7CF2 C0F49DD8602D607B60A060EE0E5493EE6446DC45371944F58C68434956649EF2D2381D38517505895B451A769AF396B60592DC82A598866673BC15300657C34140F49788A9F306DECC738FCEA910612DDEB05A47E2C4B8BF9A445AE7E19C780AE92C0A3C84190F3BB8852A89C4F4A3D84BA2D62C3EE2040E8A4C1A6D9F38FFA4
    1    486 000000  1691452260000         900000 9D458B30 70F39E00602CE079F470E09FF47060EB5D689FB2DC06429D33F57A62AED9967ED2606B860F0F7C5E2D53CD97DC9522AF6194C6012C8284B34A03DF9E2DB562C860ACBBDB8B9AAA8E5EBB69A52061483F68E1DD4CE74ED8F64748B97AB0D2F83C758D43E63C806BA58084C0A3BEE76BFB096458EB480405C85641CDD5325C3C13
    1    478 000000  1691453160000         900000 ED01845D 80EF9E28702C6076609B60E911C763E0B24B02EF9699F624EB95DB36B9566428F71C33D658C3342B09A15DBC611FC18767B7AA866AD3C162C4D186C3DC712FE51AC0874A59B560D18A33DF6BC34EB8E659D24D229EF984EFEFC3B73EB0D648DA7880FA49123F441E2BD42935CEB19B68145ACE9BD839FD0C0FB3D4D28DFF42F3
    1    478 000000  1691454060000         900000 39138A79 70EF9E50702C6076609B60E95CCFDBB3E7F51B236B96EE287BC959D588EA8DF60F923D16FE92630D6D20EA2D6061C3E6C14D33D2D11D4060170F47D2327502E8BE3B4CF958F7266E7639DA299B961DC7D2A14DD2B4590DE06337C256BA79AEF880005A2B4FA7DB0EAFC368CBAD158F4BDF04D3E7E7CF2FDE8F7367FA7E0CEF3C
    1    480 000000  1691454960000         900000 00343910 00F09E78602B6077609C60EA64F569996E35AD64F3631A4D3B9E397C9675FFCD3B616D06CFDEAD8F1EB30686F795CD60A5EF82B7D3601D58875421BF9A1B731C368B80246438E0887EF6ADD91169F31FF3C05269828D1D2E4CCC2A93E2F70E182DD73EFAB35C92CAE319EC53EC3BF1727DC3A4D28ADC1CC7C3DDB0C54ED71291
    1    470 000000  1691455860000         900000 722F7F87 10EB9EA0702C6076609A60E5320D6E1171F4225CD4D682B96508DCF21076E15103F97C26B18EA7D356018A2DD5B2D9E98AA22E99DE9A344C9ABB10D6A971EE66EB5AFCCC28D98A37B43571CD92AE91DAEED94F8A35F894E4835F20D3E4832B3D8000F0037E6164C9EF605078275C346F8C43ADC29B6D654E42A8642EF8F1392C
    1    476 000000  1691456760000         900000 D82BB1F0 70EE9EC8602C6076609B60E876786530E8AD6BB46C1A5ACBDA1C4C2CB94E6605C1C149B50EA29DFCB63727D0FD13917B03B59CC04987252BDED9AEDB3810E61F71A6862260630BA913607E2AD3C58AF2B8B727EA2364C391A1BE7EF941C9DF7C800008A74CE99CDFCB3BC9D87254DE9BB195EF265E4F728EA5B3DE49B9BAEF33
    1    484 000000  1691457660000         900000 6A6AE1DB E0F29EF0602C6078609E60EC4BCD4EE2CBCC6EE3252A7E5E75DFC737D5C2841B04F70A3BAC54A58C129A8EE5BEDBDF3D9DF66F99AA0940A618F06F5ACEBE1C2F3AFFBC2C7CFB0FF7C91869A7B1F314D16ECEBB706256949B3F727DDB6E2C54458C00133218D73161332DA3A751F34EBD6B46DD27EED3F78C162174E063BBC96B
    1    494 000000  1691458560000         900000 25A124B0 D0F79F18602E607E60A460F1235BFD5EA5C47C2FDD42DB62F0842924FAF03854892EE27A80D301451F92D67CDC0E5AF90DD46AA62EFA4CFFBE4CCC8D6C630709C62612E9F2D4BFBED0F6374F28587EEFFAB50BC135CFB1F02AC6F507F1C74756116E88EB2800779E21B018520ECA24BC2ACB547932D78E110570614C8A08001B
    1    490 000000  1691459460000         900000 EC75D211 E0F59F40602D607B60A160EF80849A48EA898BD5610437A5FCA437448436469CA7DCBC78AC0ECC951FDB9FAAFC91E6C6908C2D6CF572DCA93FCF37723A37D08DEDBF9296261B16C5789E4BE7AAF0EDA376A165258ED23727257E4032B6CFBE0B8A35A670F5668088E79CE6722CD87A94DA3892687C49509411BED06A1C06FAFF
    1    476 000000  1691460360000         900000 BE019FB5 50EE9F68702C6078609D60E81337C0AC14178D2E87C9646B233EB1E58CB35C090992B88E34E8CD6160DC82F01740F1B4A8F9BDDEDE31BEC3D6F8BB29597F2113D62F6A524A9054FE195E508DE19DE5E6E3B6F8B8D2B94FDF6DA3DC15B686FCB5E0000E374B5FB3C54ED0552437A69DBF7FAB605F5504BEDAF397503B2B536E59
    1    480 000000  1691461260000         900000 8CCA2125 E0F09F8F602C6077609C60EA4781B51398F811C18ED6FDCD4575CA05B39108FB9CD3F7F7B7F0A02E7EA15ED819B8C62C10B4B95B87965681D2158D3B983F7B0A477BAAE49CB5942A9DE4F380AABB71FBD09C142360C77886F1BAA5AD4501E4AED60041284C6EA43D5D35DC99DB4026F43B66EDF133AA33DD8B6C5BC9CF9CC99C
s=2 n=1 o=12370206720
    2   2560 002001  1692299520000       34560000 4301E0BA 0B7725AA2440E1FFD4C03FEB955E1861860F1EB3FE099FB6A49697024E304DB89693F7961ED6A50E12A7B729AA4CA6BA5B0E6954230A1BDAEFA13EAEFA92A84E9539869A753730D539AEAA9A184FE2577DCAEB68A3A64CFABA6564693EA6935BE8759FA4B55DF3DAEF9F41A709F52A50A9BD8899CC384BA94354EDAC354AD0BE
s=3 n=1 o=12358637568
    3   2560 002001  1691426880000       34560000 6EC41641 0B77A8052440E1FFCCC03FE7955E1861860EBE13AE8ADD27710AB71447E4CEACADCC4730D4C28E82BAEAEAD2C2B095F267EA6B437D097B9850DF427D4DCC354FC45155C21B64CE9F2AA546E25A4FA2707DAA5C4F92DBE2992B5E2A155C4296B575EB958BACAABB574BE1A4AF106527CFD73EA55D53E86A6BBF431C8C37B5D4D6
s=4 n=1 o=12370182144
    4   2560 002001  1692290880000       34560000 B1514C76 0B774B4B2440E1FFD4C03FEC995E1861860F0B02BACFD7A67CE696F4F43AB4B885F3E7B7153E2B5EB4285B12EAAEFDCBAAD5D33D86FDD3E4CEAB435D09F3EA6E2BC2755A1577EE553E7D5DF3E7C9A2577DD16809A3B97EB61BAAD49F3DE8F69BD855D7582CFD742ACB12C374E9AD75D13AEF0AE8DB4B1D54515ABEB5536DA6AE
s=5 n=1 o=12370575360
    5   2560 002001  1692325440000       34560000 2DD7D3EB 0B7721002440E1FFCCC03FE8995E186186104A3447CAD3A67AF69DC4D3243A7EE5F527EFA0D2D7477587CFA952A6F73AE7B61D2AACFD2C286F6E3973B1338AEFDF4E9C96156B8FA92E9EA75A64CAA4577DC5B86E8B4756E6DBE750623A697123FACFDFA65B46DD2D6A28C3B0E9FC27DCB6F086421DEAE02B710AB6F7EF6BC2AE
s=6 n=1 o=12360585216
    6   3820 002001  1691550720000       11520000 396A20B9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000040000000000000026800000370000007FDA06B711A49ADC0924DF089A026E245CE307B5AC5B16B62D6B5AD4A4A4C3108210D2307B18B5AD4949D052904210821084210D2307356A4A94939CC718C610842
s=7 n=1 o=12360585216
    7   2012 002001  1691585280000       11520000 4FA63A8F 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43000000002000000220000002C0000002A00000019CCFA26E37EA756BB36B9AD272AA336FD20F7358C5B16C5AD6B5A52941482104210D24F7396B529494A52839CC7318A4188410CE2F7B56A4A54839CC620C410842
s=8 n=1 o=12370575360
    8   2560 002001  1692325440000       34560000 172F0BE9 0B7705C02440E1FFE0C03FEF95DE1861860D71F43B6AD3A2A2F9D6B7EE22BCB6F9FA5870A13AA6B613FACFA9B9AEF776B9B61FA17E96B5686F9FB8A5AEB42A3B2927510ABC27F4D2BEA50A1A58EAD63E7DC484C9AD925839C3EB5BE1C254EABA0AF5A1A5ACA953E7509F3F72A9FA97D5D38D4B5DF5354E9F2E850E93F72A9FBD
s=9 n=1 o=12370575360
    9   2560 002001  1692325440000       34560000 31A2AB15 0B770C302440E1FFD0C03FEA955E1861860D71F4484AD3A6AAA6A567EE22A4AF5DCC34CF9539D0F618E86461568709F429D0DF8DA54A1537B5DFB8ADAEB41DDB5EA69B3D4D77EFD25774FA13F735E2577DBA686EADC4569DA3F7D49FC17E9363E7CF9F3E229A15774A953B49A9F4384F9F3E7CFD2D34CADE43855DFA98CFA1A6
s=10 n=1 o=12370575360
   10   2560 002001  1692325440000       34560000 A4DE7D35 0B770E682440E1FFC4C03FE2955E1861860D721587AC138DB4A9EF124E2439AF008567EF954DD0B613EDE9A9B9B895EEC2161529AF0D53E7CA9F3DAD5F5527BB292683077DB7EFA13B42FA14F734E2577DC444E23A13263945776F5FBE535DF3E7CFA1CDAD09F3A7509ED86AAA95A7BC1CD34CADAAEA6A9F3F4CA9F3F4C45FB9
s=11 n=1 o=12370575360
   11   2560 002001  1692325440000       34560000 A2D41576 0B7783592440E1FFC8C03FE595DE1861860D6EB57DEFD60E790A7D74EDEECDAEFC8BE7D5A1B9A749F2AAD514C2855A0115310B29855E13A7CFD7417D0DF2DDDA1F2652B6BC356E9EBEA50D73E83616437DBDC7E36FA74E49CAAADAD5AA2496DBA535DF5284F6C0D5B0DD2B494DEEF7B6E13F430DD2A7E96B437EE6BBE7B4ABD2
s=12 n=1 o=12358643712
   12   2560 002001  1691426880000       34560000 6C81B4D7 0B7771AD2440E1FFDCC03FEE9D6E1861860D12927850DF9348FE757262B0D2E049C5D716DDA55D36DAA7D6133986F63BA837152585ADFA4AF4ABBE7D49F3E5559EDB235EC3D7D5ABBA535DF3E7CFA2707DB8D62A62C2712066080877E07D0E9C2C6BC286FEB2B8511257A55D541B94ABA67BC4647834ABBA4AFE93EAF45FC1A6
brymer28
Post by brymer28 »
log comment #5
005003:0000 Failed to save title 0 to file /dead/xcode/mmcdump/sr2/Jumanji- Welcome To The Jungle.2017.mkv
002023:0000 Encountered 41 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=3 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
error=0x06043E02 count=38 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Encountered 27 unclassified errors
error=0x40000005 count=27 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
DEBUG: Code 4279607298 at r_@L.-a9'5>uU$kP-:121265246
DEBUG: Code 0 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 1 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 2 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 3 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 4 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 5 at r_@L.-a9'5>uU$kP-:213133388
DEBUG: Code 4279607298 at r_@L.-a9'5>uU$kP-:29396943
DEBUG: Code 0 at #b[W~AcF~cB0d?gP:29401750
001003:0020 DEBUG: Code 100941314 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941314 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:121263429
001003:0020 DEBUG: Code 100941314 at <mz-%C})09hs`Vw;I^:121262302
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '524288'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '1048576'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '32768'
001003:0020 DEBUG: Code 0 at >ktoW_gY2kQVc0_@a>e:213129777
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_M68I9IB5756
001003:0020 DEBUG: Code 100999428 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100999428 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 100941312 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 100941312 at N]DAZnR|jdbq4LVk:213130559
brymer28
Post by brymer28 »
log comment #6
001003:0020 DEBUG: Code 101000192 at #b[W~AcF~cB0d?gP:121271617
001003:0020 DEBUG: Code 101000192 at N]DAZnR|jdbq4LVk:213130559
001003:0020 DEBUG: Code 101000192 at <mz-%C})09hs`Vw;I^:121263429
001003:0020 DEBUG: Code 101000192 at <mz-%C})09hs`Vw;I^:121262302
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '524288'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '1048576'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS60 1.03 M68I9IB5756' at offset '32768'
Application exited at Wed Apr  3 05:14:39 2024
Here's the first error that I see in brymer28's first log post.
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '12378568704'
001003:0020 DEBUG: Code 1073741829 at N]DAZnR|jdbq4LVk:213130559
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/sr2' at offset '12378568704'
DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:29394896
001003:0020 DEBUG: Code 1073741829 at <mz-%C})09hs`Vw;I^:213131502
What ever is at that spot on the disc (offset 12378568704) the optical drive failed to read it. That the drive took a hardware timeout is probably why MakeMKV hangs. I wouldn't be surprised if the optical drive had to be power cycled to work properly again.
In any case, the standard advice is to gently clean the disc and try again.
brymer28
Post by brymer28 »
I have 5 optical drives. It's been cleaned and placed in every one. It's either a manufactured defect in disk or software bug.
My copy of Jumanji (1995) ripped okay, so I don't think there's a software bug.
