Buffalo MediaStation BRXL-PT6U2VB New firmware revision BN13
Bluntman
Post by Bluntman »
Hello all and Mike! I have a new firmware revision for this great slim drive. It was manufactured late May 2021, and is the first drive I have come across with this new revision. When you are able to Mike, could you please work your magic, and release a new update for this specific model. I will link what I hope is a dump you can use, never dumped fw before. Your BN12 firmware has served me so well. I was saddened to see a new revision.
Thank you so much for your great work and efforts!
Also if this isn't a proper dump please inform me and I will try again.
dump_user_BUFFALO_Optical_Drive_BN13_212009251104_MO5L3BI2243.tar
(70.5 KiB) Downloaded 483 times
Re: Buffalo MediaStation BRXL-PT6U2VB New firmware revision BN13
Probably just flash 1.03 with enc then if you want cross flash back to bn12 mk i used a different firmware for those but use what you like
Bluntman
Post by Bluntman »
Billycar11 wrote:
Sat Aug 28, 2021 4:07 am
I had no idea that was an option. I shall try it tomorrow when I get a chance. Thanks for oyu input Billycar11, appreciate greatly.
Bluntman wrote:
Sat Aug 28, 2021 4:26 am
i should be more specific for people not like us i mean 1.03mk for the BU40N
Bluntman
Post by Bluntman »
Billycar11 wrote:
Sat Aug 28, 2021 6:03 am
BillyCar11, you sir are a scholar and a gentleman. Worked perfectly. I would have never figured that out on my own. Thank you. I and a happy customer owe you a debt of thanks. Thank you, Thank you, Thank you. Sincerely.
Bluntman wrote:
Sat Aug 28, 2021 9:51 pm
no problem glad to help just to confirm you do need to use enc on this firmware correct me and Marty are wondering so we can add it to the official encrypted firmware list
Bluntman
Post by Bluntman »
Billycar11 wrote:
Thu Sep 30, 2021 8:21 am
Holy Crap, I apologize for the delay in the response. Sincerely. Yes all you have to do is hit the enc check mark.
Bluntman wrote:
Wed Oct 13, 2021 6:36 am
ok thanks ill add it to the guide and your name
makerbot2
Post by makerbot2 »
What was the max speed you were able to rip at?
I'm trying to see how it compares to the Buffalo 16x External BRXL-16U3
makerbot2 wrote:
Sun Nov 06, 2022 1:10 am
It's a BU40N see guide for speed test it's one of the faster drives
