LG WH14NS40 flashed to WH16NS60 1.02MK - Only reads BD but not DVD
Re: LG WH14NS40 flashed to WH16NS60 1.02MK - Only reads BD but not DVD
That's how I do it. From inside straight out the edge, rotate, repeat.
DiegoLeite23
Good morning, how are you?
How did you manage to do that?
I have LG WH14NS40 or LG WH14NS60. However, they do not recognize Blu-ray 4K UHD discs.
After you make this firmware update (different model)
He recognized 4k UHD discs ???
What would be the procedure for me to do this update as well.
thank you
thank you
Pay attention to and take the time to read the guides/pinned info post in the appropriate forums. They are there to answer these common questions and to try and help avoid future problems/headaches. Start here:DiegoLeite23 wrote: Tue Nov 10, 2020 2:45 pm Good morning, how are you?
thank you
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
thiagosouza5501
Good morning, I'm trying to recover my WH14NS40 manufactured in 2013.
I booted with a Windows PE - X86, with sata in IDE mode.
When I open DOSFlash and start the "Read Flash" procedure I get the following message: "No Know flash chip on this port"
Can you help me.
Thank you very much
Can you help me.
Thank you very much
Put your drive in port 1 and try again
thiagosouza5501
It's already on the SATA 1 port, but unfortunately the same message... I even switched PCs, but the same model (Lenovo M93p, I'm using desktops from my work, as mine is newer and doesn't have IDE mode).
Before the message I quoted above appears, this one comes: MTK Vendor Intro to Master on Port 0xF0F0 failed. If you should turn the drive off and on after you pressed "Yes". Do you want to resend the command until the drive responds? (Press ESC key to abort!)
I am also having the same issue. I have LG WH14NS40 from 2014 flashed to an unsupported version not supported pre-2015. Device connected on SATA port 1, set to IDE. booted from USB from the forum. Is the firmware ruined because the wrong version was written to the chip?
