HELP! MAKEMKV always freezes now after creating an mkv
Sethgun
Post by Sethgun »
As it says above, after its finished creating an mkv from my bluray m2ts main movie files, it seems to have finished as it says its now saving the file....then the timer stops and the beachball starts spinning and doesnt stop. CPU usage is pretty low but it still says the thread is runnung nearly 100%
As its creating the mkv, it is generating an increasingly large file, but then once it freezes it deletes that mkv file being generated....strange.
Ive got a new macbook pro 15" i7 2.8ghz, 8gb ram, main drive is on a owc mercury ssd and user directory and backups on momentus xt hybrid ssd 500gb (taken out superdrive to fit 2nd drive). Latest version of osx 10.6.6.
IT DID manage to do one successfully (bluray rip of v for vendetta). It doesnt generate an error report specific for the app ( have to force quit to get out of makemkv) but it does generate an osx error report....unless that is specific to the app when it freezes?
Cheers in advance, any help would be much appreciated :)
Re: HELP! MAKEMKV always freezes now after creating an mkv
Post by mike admin »
Sethgun wrote:As it says above, after its finished creating an mkv from my bluray m2ts main movie files, it seems to have finished as it says its now saving the file....then the timer stops and the beachball starts spinning and doesnt stop. CPU usage is pretty low but it still says the thread is runnung nearly 100%
Please send me the OSX report. Make sure you're using latest version, 1.6.5
Sethgun
Post by Sethgun »
ok will do. As an update, I just managed to save the main bluray movie file m2ts for "King of New York" from 1990 and it worked fine. For everything else, forget it. Tried matrix again and alot of other blu rays and still freezing and getting the beachball...then needing to force quit. Check your inbox for the dump. Thanks for your help :)
opfer88
Post by opfer88 »
any news? i have the same bug ...
MakeMKV v1.6.5 darwin(x86-release) gestartet
Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als /Users/13/MakeMKV_log.txt
Das Programm konnte keine verwendbaren optischen Laufwerke finden.
?ffne Dateien auf Festplatte in /TEST/
DEBUG: Code 0 at 2lM9Ev%QOBbg?3:29394390
DEBUG: Code 0 at }m7#Kt#@~Q`L;5-0:29398093
AVCHD-Metadaten gefunden
DEBUG: Code 0 at wqj0:-"(5NbtJBhV:29396667
DEBUG: Code 0 at wqj0:-"(5NbtJBhV:29396299
DEBUG: Code 0 at wqj0:-"(5NbtJBhV:121265591
DEBUG: Code 0 at wqj0:-"(5NbtJBhV:29395195
DEBUG: Code 1 at LkJRuR4>8_:-9I.:213130559
DEBUG: Code 24 at LkJRuR4>8_:-9I.:213130582
?bernahme der AVCHD-Metadaten Ihrer Kamera schlug fehl. Weitere Details unter http://www.makemkv.com/forum.
Datei 00000.m2ts wurde als Titel 0 hinzugef?gt
Die Aufgabe wurde erfolgreich abgeschlossen
is that helpfully?
opfer88 wrote:any news? i have the same bug ...
is that helpfully?
You have a quite different error. What disc are you trying to open?
opfer88
Post by opfer88 »
I dont use a BD-Disc, its a AVCHD folder. The name of the movie ist "the dark knight".
But makemkv freezed, at the beginning of remux/reencode..
At Windows the same Problem. The *.m2ts file ist corrupt ..
I think, that's not the Problem of makemkv.
