#5386 Post by RESET_9999 » Thu Aug 26, 2021 12:43 am
quietvoid wrote: Thu Aug 26, 2021 12:21 am I think the L5 metadata does vary when necessary, so it shouldn't be 276/277 everywhere..
If it is, then I guess it just doesn't matter for UHD BD.
yep, it does vary because with the hdr10plus to DV remux of WW84, the imax scenes play incorrectly in 276/277 on my C8 internal player.
the original dual-layer file (the p8 too) play correctly in 66/66
it plays perfectly in 66/66 and switches to 276/277 without issues on my bluray player x700. surely because l5 metadata are useless to bluray players. shield is fine too
hdr10plus to DV RPU:
Parsing RPU file...
  "dovi_profile": 8,
  "header": {
    "rpu_nal_prefix": 25,
    "rpu_type": 2,
    "rpu_format": 18,
    "vdr_rpu_profile": 1,
    "vdr_rpu_level": 0,
    "vdr_seq_info_present_flag": true,
    "chroma_resampling_explicit_filter_flag": false,
    "coefficient_data_type": 0,
    "coefficient_log2_denom": 23,
    "vdr_rpu_normalized_idc": 1,
    "bl_video_full_range_flag": false,
    "bl_bit_depth_minus8": 2,
    "el_bit_depth_minus8": 2,
    "vdr_bit_depth_minus_8": 4,
    "spatial_resampling_filter_flag": false,
    "reserved_zero_3bits": 0,
    "el_spatial_resampling_filter_flag": false,
    "disable_residual_flag": true,
    "vdr_dm_metadata_present_flag": true,
    "use_prev_vdr_rpu_flag": false,
    "prev_vdr_rpu_id": 0,
    "vdr_rpu_id": 0,
    "mapping_color_space": 0,
    "mapping_chroma_format_idc": 0,
    "num_pivots_minus_2": [
      0,
      0,
      0
    "pred_pivot_value": [
        0,
        1023
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "vdr_rpu_data": {
    "mapping_idc": [
        0
        0
        0
    "mapping_param_pred_flag": [
        false
        false
        false
    "num_mapping_param_predictors": [
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
        0
        0
        0
    "poly_order_minus1": [
        0
        0
        0
    "linear_interp_flag": [
        false
        false
        false
    "pred_linear_interp_value_int": [
        0
        0
        0
    "pred_linear_interp_value": [
        0
        0
        0
    "poly_coef_int": [
          0,
          1
          0,
          1
          0,
          1
    "poly_coef": [
          0,
          1
          0,
          1
          0,
          1
    "mmr_order_minus1": [
        0
        0
        0
    "mmr_constant_int": [
        0
        0
        0
    "mmr_constant": [
        0
        0
        0
    "mmr_coef_int": [
    "mmr_coef": [
  "nlq_data": null,
  "vdr_dm_data": {
    "affected_dm_metadata_id": 0,
    "current_dm_metadata_id": 0,
    "scene_refresh_flag": 1,
    "ycc_to_rgb_coef0": 9574,
    "ycc_to_rgb_coef1": 0,
    "ycc_to_rgb_coef2": 13802,
    "ycc_to_rgb_coef3": 9574,
    "ycc_to_rgb_coef4": -1540,
    "ycc_to_rgb_coef5": -5348,
    "ycc_to_rgb_coef6": 9574,
    "ycc_to_rgb_coef7": 17610,
    "ycc_to_rgb_coef8": 0,
    "ycc_to_rgb_offset0": 16777216,
    "ycc_to_rgb_offset1": 134217728,
    "ycc_to_rgb_offset2": 134217728,
    "rgb_to_lms_coef0": 7222,
    "rgb_to_lms_coef1": 8771,
    "rgb_to_lms_coef2": 390,
    "rgb_to_lms_coef3": 2654,
    "rgb_to_lms_coef4": 12430,
    "rgb_to_lms_coef5": 1300,
    "rgb_to_lms_coef6": 0,
    "rgb_to_lms_coef7": 422,
    "rgb_to_lms_coef8": 15962,
    "signal_eotf": 65535,
    "signal_eotf_param0": 0,
    "signal_eotf_param1": 0,
    "signal_eotf_param2": 0,
    "signal_bit_depth": 12,
    "signal_color_space": 0,
    "signal_chroma_format": 0,
    "signal_full_range_flag": 1,
    "source_min_pq": 7,
    "source_max_pq": 3079,
    "source_diagonal": 42,
    "num_ext_blocks": 3,
    "ext_metadata_blocks": [
        "Level1": {
          "block_info": {
            "ext_block_length": 5,
            "ext_block_level": 1,
            "remaining": [
              0,
              0,
              0,
              0
          "min_pq": 0,
          "max_pq": 0,
          "avg_pq": 0
        "Level5": {
          "block_info": {
            "ext_block_length": 7,
            "ext_block_level": 5,
            "remaining": [
              0,
              0,
              0,
              0
          "active_area_left_offset": 0,
          "active_area_top_offset": 276,
          "active_area_bottom_offset": 277
        "Level6": {
          "block_info": {
            "ext_block_length": 8,
            "ext_block_level": 6,
            "remaining": []
          "max_content_light_level": 596,
          "max_frame_average_light_level": 200
  "remaining": [
    0,
    0,
    0,
    0,
    0
  "rpu_data_crc32": 156245703
quietvoid
#5387 Post by quietvoid » Thu Aug 26, 2021 12:50 am
Right, normally you would have to find the scenes where the aspect ratio changes and edit them in the other RPU.
Alternatively I'm pretty sure leaving the L5 to 0 also works.
But you don't have to do any of this since the content is already Dolby VIsion :!:
quietvoid
#5388 Post by quietvoid » Thu Aug 26, 2021 5:00 am
Manixx2020beyound wrote: Wed Aug 25, 2021 7:40 pm Waiting patiently for 4.0
2.9 does not use the resolve dv analysis tool.
The test build should now at least parse v4.0 properly. https://github.com/quietvoid/dovi_tool/ ... -906094633
I don't have enough samples to confirm if L3 is correct nor to add anything more (other than possibly automatically calculated L4).
#5389 Post by Manixx2020beyound » Thu Aug 26, 2021 5:15 am
quietvoid wrote: Thu Aug 26, 2021 5:00 am
Thank you, again much appreciated!
Works like a charm,
Once 4.0xml is parsed
I have 2 choices encode from the Master with Rpu/ encode raw with Rpu both work .
Just brilliant!
"dovi_profile": 8,
"header": {
"rpu_type": 2,
"rpu_format": 18,
"vdr_rpu_level": 0,
"vdr_rpu_id": 0,
0,
0,
0
0,
1023
0,
1023
0,
1023
"vdr_rpu_data": {
"mapping_idc": [
"nlq_data": null,
"vdr_dm_data": {
"source_min_pq": 7,
"num_ext_blocks": 7,
"Level1": {
"block_info": {
"remaining": [
0,
0,
0,
0
"min_pq": 0,
"max_pq": 3209,
"avg_pq": 2048
"Level2": {
"block_info": {
"ext_block_length": 11,
"ext_block_level": 2,
"remaining": [
0,
0,
0
"target_max_pq": 2081,
"trim_slope": 1507,
"trim_offset": 2017,
"trim_power": 1147,
"trim_chroma_weight": 2048,
"trim_saturation_gain": 2048,
"ms_weight": 2048
"Level2": {
"block_info": {
"remaining": [
0,
0,
0
"target_max_pq": 2851,
"trim_slope": 2045,
"trim_offset": 2048,
"trim_power": 2040,
"ms_weight": 2048
"Level2": {
"block_info": {
"remaining": [
0,
0,
0
"target_max_pq": 3079,
"trim_slope": 2089,
"trim_offset": 2049,
"trim_power": 2191,
"ms_weight": 2048
"Level3": {
"block_info": {
"ext_block_length": 2,
"ext_block_level": 3,
"remaining": []
"min_pq_offset": 2048,
"max_pq_offset": 1447,
"avg_pq_offset": 2048
"Level5": {
"block_info": {
"remaining": [
0,
0,
0,
0
"active_area_top_offset": 0,
"Level6": {
"block_info": {
"remaining": []
"max_content_light_level": 0,
"max_frame_average_light_level": 0
"remaining": [
0
"rpu_data_crc32": 3677026044
Last edited by Manixx2020beyound on Thu Aug 26, 2021 3:58 pm, edited 1 time in total.
higher
#5390 Post by higher » Thu Aug 26, 2021 2:31 pm
Sorry for asking this but is there a way to mux or convert Dolby Vision mkv's to mp4? Unfortunately LG OLED TV's built-in players are not recognizing DV in the mkv container and I don't have an X700 or Shield 2019. Excuse me if it had been asked earlier.
Keep up the great work!
quietvoid
#5391 Post by quietvoid » Thu Aug 26, 2021 4:09 pm
Manixx2020beyound wrote: Thu Aug 26, 2021 5:15 am Thank you, again much appreciated!
Works like a charm,
Just brilliant!
Good to know.
It's a little weird to see L2 stronger adjustments for 1000 nits but less for 600. Only you would know if it's correct though.
The trim_slope (Gain) is still possibly wrong, since I couldn't match the values all the time with the samples I have.
#5392 Post by Manixx2020beyound » Thu Aug 26, 2021 5:02 pm
quietvoid wrote: Thu Aug 26, 2021 4:09 pm
Works like a charm,
Just brilliant!
Good to know.
Quick test sample works
Possibilities are now endless
What’s great about this tool even if u have a Dolbyvision license u are now able to view your work before it goes mainstream in doblyvision with all the trims well, almost all the trims.
No one can view their workflow in dv well only using rgb tunneling but that’s it u have no acess to your doblyvision created content
Hdr10/sdr only for playback now we have it all.
#5393 Post by RESET_9999 » Thu Aug 26, 2021 6:41 pm
Interestingly, the CX internal app sends a bt2020 flag with DV like the shield used to do...
I bet that explains the difference @galarond is seeing with his C1 internal player and the x700.. I assume the C1 flag bt2020 as well. Doing so saturate the color more: https://screenshotcomparison.com/comparison/16962
damn , DV is a mess!!!
staknhalo
#5394 Post by staknhalo » Thu Aug 26, 2021 10:28 pm
RESET_9999 wrote: Thu Aug 26, 2021 6:41 pm damn , DV is a mess!!!
It looks pretty, but damn I hate this video generation lol
#5395 Post by RESET_9999 » Thu Aug 26, 2021 11:43 pm
hulu recently added dv and hdr10plus support and it looks like they are all in profile 8 DV ... Make sense, no time wasted encoding both HDR10 and DV base layer.
Since it looks like the appleTV is doing fake DV with profile 7/8 , I wonder how it will go lol ...
Complete name                            : The.Handmaids.Tale.S01E01.Offred.2160p.HULU.WEB-DL.DDP5.1.DoVi.H.265.mkv
File size                                : 4.70 GiB
Duration                                 : 57 min 25 s
Overall bit rate                         : 11.7 Mb/s
Video
Format profile                           : Main 10@L5.1@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 11.4 Mb/s
Bits/(Pixel*Frame)                       : 0.058
Stream size                              : 4.59 GiB (98%)
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 212 cd/m2
Maximum Frame-Average Light Level        : 157 cd/m2
#5396 Post by RESET_9999 » Fri Aug 27, 2021 1:15 am
@quietvoid
the hdr10plus to DV conversion works very well IMO. I watched a 2h Amazon movie in DV and I don't see anything wrong. Brightness change is not visible at all, perfectly smooth transition. I didn't create any l2 metadata, I added l6 metadata and I adjusted the active area, that's it. And just to be sure, I made an off-sync version with the RPU late 120 frames and I could easily spot the brightness adjustments. I still would like to take a look at manix shogun lldv capture though... Still, DV couldn't save the horrible amazon encoding, seriously that shit looks like 720p.
Anyway, another major achievement by you, well done. we can basically do anything now thank's to you :D
higher wrote: Thu Aug 26, 2021 2:31 pm Sorry for asking this but is there a way to mux or convert Dolby Vision mkv's to mp4? Unfortunately LG OLED TV's built-in players are not recognizing DV in the mkv container and I don't have an X700 or Shield 2019. Excuse me if it had been asked earlier.
if you don't care about subtitles, the easiest and fastest way is tsMuxer .. wont be an mp4 but should play on your lg tv (assuming you're talking about p5 files)
otherwise, you have to demux and remux with the mp4muxer
quietvoid
#5397 Post by quietvoid » Fri Aug 27, 2021 1:25 am
RESET_9999 wrote: Fri Aug 27, 2021 1:15 amthe hdr10plus to DV conversion works very well IMO. I watched a 2h Amazon movie in DV and I don't see anything wrong. Brightness change is not visible at all, perfectly smooth transition. I didn't create any l2 metadata, I added l6 metadata and I adjusted the active area, that's it. And just to be sure, I made an off-sync version with the RPU late 120 frames and I could easily spot the brightness adjustments. I still would like to take a look at manix shogun lldv capture though... Still, DV couldn't save the horrible amazon encoding, seriously that shit looks like 720p.
That's good, I had no problem on my side either.
There's a difference between the target nits but now that we have production profile 8 files with both, it looks like HDR10+ tools just measure slightly differently.
higher
#5398 Post by higher » Fri Aug 27, 2021 11:19 am
galarond wrote: Fri Aug 27, 2021 12:31 am
well, depending on the model of the oled you can play dv mp4 dual or single layer, that will show what you need to do. for example in my LgC1 i can only play 1 layer mp4/m2ts/ts files and trigger dv, i had a lgb6 where i could play dual layer mp4 but only mel movies and fel very very buggy.
so first to know that to see what you need to do to make a watchable file in the internal player of your tv and trigger dv
I have an LG C8 and it plays dual and single layer mp4's flawlessly. I tried remuxing to ts with tsMuxer but it doesn't trigger DoVi so I guess it's P8 which the TV doesn't support.
RESET_9999 wrote: Fri Aug 27, 2021 1:15 am if you don't care about subtitles, the easiest and fastest way is tsMuxer .. wont be an mp4 but should play on your lg tv (assuming you're talking about p5 files)
Thanks for the reply. So shall I demux the video track with tsMuxer then remux it with mp4muxer using profile 5?
#5399 Post by RESET_9999 » Fri Aug 27, 2021 2:07 pm
higher wrote: Fri Aug 27, 2021 11:19 am I have an LG C8 and it plays dual and single layer mp4's flawlessly. I tried remuxing to ts with tsMuxer but it doesn't trigger DoVi so I guess it's P8 which the TV doesn't support.
the C8 supports all the DV profiles.
The ts file you tried must be dual-layer which the c8 won't trigger DV in this container (or it will even say ''corrupted'').
so you have to demux and remux with the mp4muxer using profile 7
higher
#5400 Post by higher » Fri Aug 27, 2021 2:26 pm
RESET_9999 wrote: Fri Aug 27, 2021 2:07 pm the C8 supports all the DV profiles.
I was trying with a Hulu DoVi mkv file floating on the web which is Profile 8 but remuxing it to ts didn't trigger Dolby Vision, only regular HDR.
