Ah, I see what you mean. I didn't realise that the RPU data includes which profile it is for. So it's actually reasonable that Infuse would ignore the RPU in my hacked-together file because it's for the wrong profile. So we don't have any evidence that Infuse is playing profile 5 files incorrectly. I'll keep investigating. Thanks again for all your help!
(Sorry if I'm boring anyone to tears with this saga, I'll shut up soon.)
I've now found a profile 5 RPU and have injected that into my test file and it also seems to be ignored when playing back in Infuse (and in Plex). My (LG B7 OLED) TV's built-in video player gives dramatic color changes when playing the test file so it appears to be processing the RPU correctly. I've sent the sample and a video of the LG's playback to the Infuse developers, and I'll report back if they reply.
Please don't..if it really is ignoring RPU appreciate the work getting it fixed.
I worked with them years ago with an SMB issue. They were slow to get it fixed but did. Hopefully here they will be quick to confirm any issues and get them fixed.
Few more p5 Spares.
- D052F53C-013E-4D1C-8CF7-B742CCDD975C.jpeg (1.43 MiB) Viewed 17792 times
- 6CB3B541-5576-4331-979C-B60B1A7FD37A.jpeg (2 MiB) Viewed 17792 times
- 63724362-EEC1-47D4-8E92-CD255A6E18C0.jpeg (1.71 MiB) Viewed 17792 times
nah keep going, this thread is all about experimenting with DV.FubbAyH wrote: ↑Mon Aug 23, 2021 1:56 am(Sorry if I'm boring anyone to tears with this saga, I'll shut up soon.)
in order to properly test if rpu is used, you probably should modify/unsync a true p5 file instead of injecting a p5 rpu to a random HDR10 BL.
You can delay the rpu metadata with a JSON edit and inject it back into the original p5 bl and it should produce visible brightness changes. the file would still follow dv specs.
this json will delay the metadata 120frames.
"duplicate": [
"source": 0,
"offset": 0,
"length": 120
}Re: Dolby Vision now possible through MP4 Mux.
I'll probably have to wait until next weekend to do any more experiments, but thanks very much for the encouragementRESET_9999 wrote: ↑Mon Aug 23, 2021 2:51 amnah keep going, this thread is all about experimenting with DV.
I did a first attempt at generating a RPU from XML: https://github.com/quietvoid/dovi_tool/pull/43Manixx2020beyound wrote: ↑Sun Aug 15, 2021 10:00 pmThat would help the grading community,
For those guys like myself 4k,6k,8k cameras
And do their own grading without doblyvision license fees
No secondary trim pass doe.
To my knowledge the doblyvision fees are only for secondary trim passes/Rpu creation & final encode of the doblyvision master to hevc
Still need to figure out if the L2 trims are correct..
L1 should be fine though, the rest needs testing and sample XML files..
Missing proper L5 (aspect ratio), since I don't really know how to decide whether it's horizontal or vertical letterbox bars.
oh wow. so we can now convert HDR10plus to DV. Amazing, thank you!!
we have to compare original DV with this conversion now..
@manix??? Alita bluray has hdr10+ and DV I believe...
I've watched a couple episodes of The Expanse with the new HDR10+ to DoVi, to me they looked fine..
Black crush in comparison to HDR10, as expected from the Firestick. Didn't affect a lot of scenes though.
Some titles which include both, that I know of:
Doctor Sleep
Wonder Woman 1984
Godzilla vs Kong
Just off the top of my head..
Doctor Sleep
Wonder Woman 1984
Godzilla vs Kong
yep, WW-84 is the ideal title since the bluray is MEL DV and hdr10plus. There's also a profile 5 web-dl. @manix, I'm making you samples to test with your Shogun.
btw, I hope you hide behind a VPN, Dolby must be real mad at you if they are aware of your tool lol...
Fantastic! great news!!quietvoid wrote: ↑Wed Aug 25, 2021 5:40 amI did a first attempt at generating a RPU from XML: https://github.com/quietvoid/dovi_tool/pull/43Manixx2020beyound wrote: ↑Sun Aug 15, 2021 10:00 pmThat would help the grading community,
Thanks, so much will be testing tonight.
“NO BANZ TO MAKE DV DANCE”
Raw footage:
Now I can create a dv music video
With l1
Testing a dv/hdr10plus xml master of beckett which also has secondary trims too
Created by resolve
For raw footage we should be able to define the aspect ratio in the final encoding settings
Last edited by Manixx2020beyound on Wed Aug 25, 2021 5:07 pm, edited 1 time in total.
I'm getting this error:
EDIT. ok looks like im not using the right CMD-LINE...
Can we just convert HDR10plus json straight to DV like this :
dovi_tool.exe generate --hdr10plus-json D:\HDR10plus.JSON --rpu-out D:\RPU_generated.binor do we have to make a json and enter the lenght, target nits etc ? how do we know which value to use? or do we just enter the lenght and static metadata and the tools do the rest ?
does this json correct for WW-84?:
dovi_tool.exe generate --hdr10plus-json D:\HDR10plus.JSON --json D:\edited.json --rpu-out D:\RPU_generated.binCode: Select all
"length": 217408,
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000,
"trim_power": 2096,
"trim_saturation_gain": 2128
"target_nits": 2000,
"trim_slope": 2048,
"trim_offset": 2048,
"trim_power": 2048,
"trim_chroma_weight": 2048,
"trim_saturation_gain": 2048,
"ms_weight": 2048
"level6": {
"max_content_light_level": 596,
"max_frame_average_light_level": 200
You have to specify the config JSON for generating, since the HDR10+ info is only used for L1 metadata.RESET_9999 wrote: ↑Wed Aug 25, 2021 5:05 pmI'm getting this error:
So something like this:
dovi_tool generate -j assets/generator_example.json --hdr10plus-json metadata.jsonFor the L2 to have no effect, something like this should work:
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
By the way, currently it only works for CMv2.9 XML files. Will look at supporting v4.0 but things like secondary trims are not backwards compatible.Manixx2020beyound wrote: ↑Wed Aug 25, 2021 2:22 pmFantastic! great news!!
Raw footage:
With l1
Created by resolve
I'm sooooo confused lol...
I converted my hdr10plus JSON to RPU.bin and I'm comparing the metadata and most of it is the same as the original bluray RPU (p8) except at the end where the original profile 8 RPU has different values for L1 and no L2 metadata but it has L4 metadata.... So my generated is wrong or not? and what the hell is level 4 ? its not even on the dolby documentation. Since L2 is optional, should we NOT generate it? L1 pq max and min doesnt match, why?
the json i used is :
generated RPU:
Profile 8 RPU from bluray:
generated RPU ( no L2)
"length": 217408,
"level2": [
"target_nits": 100
"target_nits": 600
"target_nits": 1000
"target_nits": 2000
"level6": {
}generated RPU:
"num_ext_blocks": 7,
"ext_metadata_blocks": [
"Level1": {
"block_info": {
"ext_block_length": 5,
"ext_block_level": 1,
"remaining": [
0,
0,
0,
0
"min_pq": 0,
"max_pq": 0,
"avg_pq": 0
"Level2": {
"block_info": {
"ext_block_length": 11,
"ext_block_level": 2,
"remaining": [
0,
0,
0
"target_max_pq": 2081,
"trim_slope": 2048,
"trim_power": 2048,
"ms_weight": 2048
"Level2": {
"block_info": {
"remaining": [
0,
0,
0
"target_max_pq": 2851,
"trim_slope": 2048,
"trim_power": 2048,
"ms_weight": 2048
"Level2": {
"block_info": {
"remaining": [
0,
0,
0
"target_max_pq": 3079,
"trim_slope": 2048,
"trim_power": 2048,
"ms_weight": 2048
"Level2": {
"block_info": {
"remaining": [
0,
0,
0
"target_max_pq": 3388,
"trim_slope": 2048,
"trim_power": 2048,
"ms_weight": 2048
"Level5": {
"block_info": {
"ext_block_length": 7,
"ext_block_level": 5,
"remaining": [
0,
0,
0,
0
"active_area_left_offset": 0,
"active_area_top_offset": 0,
"Level6": {
"block_info": {
"ext_block_length": 8,
"ext_block_level": 6,
"remaining": []
"remaining": [
0
"rpu_data_crc32": 562607130Profile 8 RPU from bluray:
"num_ext_blocks": 4,
"Level1": {
"block_info": {
"remaining": [
0,
0,
0,
0
"min_pq": 0,
"max_pq": 2081,
"avg_pq": 819
"Level4": {
"block_info": {
"ext_block_length": 3,
"ext_block_level": 4,
"remaining": []
"anchor_pq": 0,
"anchor_power": 0
"Level5": {
"block_info": {
"remaining": [
0,
0,
0,
0
"active_area_top_offset": 276,
"active_area_bottom_offset": 277
"Level6": {
"block_info": {
"remaining": []
"remaining": [],
"rpu_data_crc32": 326453137
"num_ext_blocks": 3,
"Level1": {
"block_info": {
"remaining": [
0,
0,
0,
0
"min_pq": 0,
"max_pq": 0,
"avg_pq": 0
"Level5": {
"block_info": {
"remaining": [
0,
0,
0,
0
"Level6": {
"block_info": {
"remaining": []
"remaining": [
0,
0,
0,
0,
0
"rpu_data_crc32": 1882379805
