Converting TV Series DVDs To Blu-Ray
213karaokejoe
#1 Post by 213karaokejoe » Wed Aug 25, 2021 3:41 am
Using MKV's of DVD's and trying to use DVDFAB to compile a Blu-ray disc. Having some video sound syncing problems with a few of the files. Quite annoying. Would like to put one half the season of "Smallville" on one disc 25 gb , and the rest on another. The amount of space does not seem to be an issue Are there settings that I am just not choosing right? The problem again is with syncing video and audio. Anybody acquainted with the issue? Can you help me?
Re: Converting TV Series DVDs To Blu-Ray
#2 Post by Woodstock » Wed Aug 25, 2021 12:17 pm
If the MKV files do not have sync issues when you play them back, then the issue isn't with MakeMKV, and this isn't the DVDFab support forum.
You are going to go through a conversion process to make MPEG2 video (DVD MKV files) and getting a BD-compatible format. That conversion can introduce any number of issues. If you're creating a BD-Data disk with the files, rather than trying to author a BD video disk, things get simpler. Will your playback environment support playing video files from a BD-Data disk?
