First Time No Sound
ssmmbb
First Time No Sound
I was working with Rick and Morty S3 and just could not get sound. Rip was fine just no sound, at first I was thinking encryption. Everything I tried even with other software had the same results. I did receive a SCSI Error and rebooted and that went away. I did notice that during the scan of the disk, it kept repeating audio source 2 & 3 skipped due to being empty then started with 1, 2, 3, and 4 being skipped due to being empty. After re-scanning the disk, I expanded my selection so I could see all audio tracks. Once selecting 5.1 track and then ripping I now have sound. Something about the these disks required me to manually select the proper audio track. Hope this will help someone who runs into the same thing.
fun2163
Re: First Time No Sound
Thanks VERY much ssmmbb... I was SHOCKED to see my EXACT issue (same disc too!)
For others, to clarify a bit more:
- ONLY select the 5.1 audio track (de-select the other audio tracks.)
Anung Un Rama
I am having the same issue. I ripped both Season 4 discs with no errors. I put in Season 3 disc 2 and it keeps saying
"The source file 'DVD+R-DL ATAPI DVD A DH16ABSH YA12' is corrupt or invalid at offset 8192, attempting to work around" over and over again. 2 Hrs later the videos are ripped but they have no audio. I'm trying your solution right now. I hope it works.
Update:
It works. Thank you!
Update:
Last edited by Anung Un Rama on Mon Aug 23, 2021 11:02 pm, edited 1 time in total.
If you're experiencing rip errors, please read here first!Anung Un Rama wrote: Mon Aug 23, 2021 9:49 pmThe source file 'DVD+R-DL ATAPI DVD A DH16ABSH YA12' is corrupt or invalid at offset 8192, attempting to work around
Anung Un Rama
I saw that post before you linked it to me. But yeah didn't help.
The error is telling you that the drive is having problems reading the disk. If cleaning it doesn't help, replacing it is the way to go. Your drive should be one of the more forgiving as far as DVD readability.
Anung Un Rama
I cleaned the disc and then I unticked all the audio tracks except for the " 5.1 audio track" one. It worked.
I did the same for my Season 1-2 discs as well and it worked for those too.
Anung Un Rama
There's nothing wrong with my disc drive. I have a secondary USB external optical drive and it was doing the exact same thing on both of them. I followed OP's instructions and I was able to rip Seasons 1-4. Thank you OP.
