ancient
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by ancient » Sat Aug 21, 2021 11:13 am
Billy Just to let you know (for the guide) it looks like the BU40N no longer has the svc code on the label
Carter0108
Post by Carter0108 » Sat Aug 21, 2021 3:14 pm
I followed this guide about a year ago with a newly purchased LG WH16NS40 but have only just purchased my first UHD Blu-Ray. MakeMKV is stuck indefinitely trying to load the disc and the drive just gets very noisy. Any idea what's wrong?
Post by d00zah » Sat Aug 21, 2021 3:48 pm
Carter0108 wrote: Sat Aug 21, 2021 3:14 pm I followed this guide about a year ago with a newly purchased LG WH16NS40 but have only just purchased my first UHD Blu-Ray. MakeMKV is stuck indefinitely trying to load the disc and the drive just gets very noisy. Any idea what's wrong?
From the 1st post:
Sleep Bug:
All UHD Friendly drives have the sleep bug, this is when a UHD disk is left idle in the drive for 2 minutes. Once the drive goes to sleep, the UHD Friendly drive will no longer be able to read the disk without opening and closing the disk tray and will make horrible seeking noises until this is done.
Sleep Bug Fix:
To fix the sleep bug on a UHD Friendly drive flash firmware from an UHD Official drive like WH16NS60 DE 1.00 or 1.01MK
joitronix
Post by joitronix » Sun Aug 22, 2021 4:01 am
Hi, thnk for your job, i'm a very big jackie chan fan, and i want to transfer them to my pc, seems the ps3 cant read uhd dics.... after investigating too much y found your post and i found a "cheaper" reader that is in your list:
https://www.amazon.es/Asus-BC-12D2HT-Bl ... 00F0SQLR8/
Y can't see in your list, not work or something?, i found the bin and other posts that have it:
Some people say i need to put sata on ide is necessary with your tool?
Is that easy than select the bin file and select the drive and press write or i need to check something before?
THNK YOU VERY MUCH.
Post by Billycar11 » Sun Aug 22, 2021 4:11 pm
joitronix wrote: Sun Aug 22, 2021 4:01 am Hi, thnk for your job, i'm a very big jackie chan fan, and i want to transfer them to my pc, seems the ps3 cant read uhd dics.... after investigating too much y found your post and i found a "cheaper" reader that is in your list:
THNK YOU VERY MUCH.
This guide is correct the other ones with ide are old
joitronix
Post by joitronix » Sun Aug 22, 2021 9:40 pm
Billycar11 wrote: Sun Aug 22, 2021 4:11 pm
THNK YOU VERY MUCH.
But not appear this model: 12D2HT and the firmware patched is not in the file its for any particular reason?, its the only uhd drive that can y buy i'm from spain and buy already patched is too expensive for me.
Post by Billycar11 » Mon Aug 23, 2021 4:05 am
joitronix wrote: Sun Aug 22, 2021 9:40 pm
if its mt1959 your fine to flash it
Mizkreant
Post by Mizkreant » Tue Aug 24, 2021 3:46 pm
The label on my drive (WP50NB40) says SVCNB50. Is it safe to flash? Everything else checks out.
Post by MartyMcNuts » Tue Aug 24, 2021 11:14 pm
Mizkreant wrote: Tue Aug 24, 2021 3:46 pm The label on my drive (WP50NB40) says SVCNB50. Is it safe to flash? Everything else checks out.
Yes.
dvdbr
Possibly found a working drive enclosure available in Europe
Post by dvdbr » Fri Aug 27, 2021 1:48 pm
@Billycar11
I wanted to provide some hopefully useful information about drive enclosures, that worked with MakeMKV and the BU40N drive.
I am no expert in the matter, so further testing from more seasoned board members could help verify this.
I got a BU40N and flashed it via a "SATA 22-pin to Micro SATA 16-pin" adapter from inside my computer (just did not want to risk any experiments).
As for the enclosure, I tried out one, that I already had and is readily available in Europe, before ordering the Vantec NST-510S3-BK from overseas.
"External Enclosure for 5.25″ Ultra Slim SATA Drives 9.5 mm to USB Type-A male", Item No. 42603, by "Delock"
https://www.delock.com/produkte/G_651_5-25-.html
The chipset in the enclosure (Initio INIC-3619) is also used in other enclosures of their product line.
What I did not try was to flash the firmware - just was not sure, whether I could brick the drive by trying.
I could do a firmware dump with the SDFTool Flasher though, if this gives any indication, that the communication between the computer, the enclosure and the drive works...
So, your are welcome to test the enclosure and eventually put it on your list, if you want to.
jedipizza
Post by jedipizza » Thu Sep 02, 2021 2:58 pm
Hi guys, first thanks for this guide, that's very helpful.
But just to be 100% sure of what I'm doing and what it will do, here's my question:
I just received my WH16NS40, it is a 2020 model with 1.05 as per its sticker (SVC NS50).
If I got it right, I could simply downgrade it directly to the according MK firmware to get BD and UHD BD ripping capability without the sleep bug?
Post by Billycar11 » Fri Sep 03, 2021 12:43 am
jedipizza wrote: Thu Sep 02, 2021 2:58 pm Hi guys, first thanks for this guide, that's very helpful.
yes if you follow the guide you wont have the sleep bug or get an automated flasher from me or Marty
jedipizza
Post by jedipizza » Fri Sep 03, 2021 2:53 pm
Got it, thanks!
bwkoppen
Post by bwkoppen » Fri Sep 03, 2021 5:07 pm
Why am I getting this error?
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc - i C:\Users\Acer\Downloads\Downgrade Enabled Firmware V.2r\DE_LG WH16NS60_1.00.bin
Input file in raw format is required
DEBUG: Code 4280426501 at Mx=Q{%DdK23UWRSK}6/xi^l-6'?wWl*&:29397564
Command produced error code 0x8f222005
Drive
LG WH14NS40
Firmware 1.05
I am having trouble with some of the new Disney movies so I was going to try the LB WH16NS60 1.00
Post by mike admin » Fri Sep 03, 2021 5:37 pm
bwkoppen wrote: Fri Sep 03, 2021 5:07 pm Why am I getting this error?
space between dash and 'i'
