Re: SDFtool Flasher
#286 Post by MartyMcNuts » Sun Aug 22, 2021 11:04 pm
joitronix wrote: Sun Aug 22, 2021 3:56 am
MartyMcNuts wrote: Sat Aug 21, 2021 1:14 am
SteelBookCollector wrote: Fri Aug 20, 2021 1:47 pm Got a brand new WH16NS40 with 1.05 Firmware.
SDFTool v1.2.0, trying to flash to WH16NS60 v1.02 from the old folder, check the enc box.
Getting error code 0x8f056103
On Windows 10 X64. dotNet newer then 4.7.2
What am I doing wrong?
How is your drive connected?
Do you have MakeMKV 1.15.1 or above instlled?
Hi, thnk for your job, i'm a very big jackie chan fan, and i want to transfer them to my pc, seems the ps3 cant read uhd dics.... after investigating too much y found your post and i found a "cheaper" reader that is in your list:https://www.amazon.es/Asus-BC-12D2HT-Bl ... 00F0SQLR8/
Y see in your folder have the same name but i have some questions:
I not see in the list that this hard drive come with encrypted so i not need to mark it in the tool?.
Some people say i need to put sata on ide is necessary with your tool?
Is that easy than select the bin file and select the drive and press write or i need to check something before?
THNK YOU VERY MUCH.
1. ASUS drives do not have encrypted firmware so no need to select it in flasher tool.
2. No need to worry about IDE.
3. Yes, just select drive, select firmware bin file and write. For the BC-12D2HT, I recommend firmware BC-12D2HT_3.11_MK.
joitronix
Re: SDFtool Flasher
#287 Post by joitronix » Sun Aug 22, 2021 11:57 pm
MartyMcNuts wrote: Sun Aug 22, 2021 11:04 pm
THNK YOU VERY MUCH.
Ok i read if it comes with 1.00 version cant be flashed or something that mt1959 can and 1939 no there's any way to check my drive is 100% comaptible with this method?
Its a chance that the drives come with a firmware undowngradable cause its to newer or if its this model and later 2015 its 100% secure that can be flashed?
Thnk you very much, i know its a lot of job for for people that sometimes never more gonna hear it his name, the case its that i don't have too much money, and if i buy a incorrect drive or i brick it i think gonna cry.
Re: SDFtool Flasher
#288 Post by MartyMcNuts » Mon Aug 23, 2021 2:42 am
joitronix wrote: Sun Aug 22, 2021 11:57 pm
THNK YOU VERY MUCH.
If it is a new drive (after October 2015) it would come with 3.xx firmware. Most likely 3.11 and is ok to flash. If the drive is older than October 2015 and comes with firmware 1.xx, then it is too old and cannot be flashed. Simply open MakeMKV and you will see on the right hand pane what firmware is currently on the drive.
SteelBookCollector
Re: SDFtool Flasher
#289 Post by SteelBookCollector » Mon Aug 23, 2021 8:44 pm
Coopervid wrote: Fri Aug 20, 2021 10:11 pm First flash 1.05 MK with enc. Then downgrade to whatever you want.
After that don't check enc anymore.
That did not work.
SteelBookCollector
Re: SDFtool Flasher
#290 Post by SteelBookCollector » Mon Aug 23, 2021 8:45 pm
Drive connected directly via SATA,
MakeMKD 1.16.4 installed
SteelBookCollector
Re: SDFtool Flasher
#291 Post by SteelBookCollector » Mon Aug 23, 2021 8:46 pm
Billycar11 wrote: Sat Aug 21, 2021 12:41 am
that should have worked try the command line.
Screen Shot 2021-08-23 at 4.43.35 PM.png (725.33 KiB) Viewed 38232 times
Re: SDFtool Flasher
#292 Post by Billycar11 » Tue Aug 24, 2021 1:06 am
SteelBookCollector wrote: Mon Aug 23, 2021 8:46 pm
open a bluray in makemkv then try again and make sure allow server updates is on
Re: SDFtool Flasher
#293 Post by Coopervid » Tue Aug 24, 2021 9:23 am
Your command line includes -mtk1939 but this drive uses the 1959 chip.
joitronix
Re: SDFtool Flasher
#294 Post by joitronix » Mon Aug 30, 2021 11:19 am
THNK YOU VERY MUCH.
Ok i flashed the BC12D2HT, with the firmware provided in this thread this: ASUS-BC-12D2HT-3.11-WM00300-211902271319 is in the mk folder so i assume that is the mk version cause is in the mk folder, but the file no say nothing about mk and in makemkv not say nothing about mk.
Its all okay with the flash?, here screenshot of makemkv:
Mr_Orange
Re: SDFtool Flasher
#295 Post by Mr_Orange » Mon Aug 30, 2021 11:42 am
Looks good!
joitronix
Re: SDFtool Flasher
#296 Post by joitronix » Mon Aug 30, 2021 11:53 am
Mr_Orange wrote: Mon Aug 30, 2021 11:42 am Looks good!
Little problem dvd fab says firmware is not good, cause i think dvd fab uses de firmware 3.00 and detect that i have 3.11 can work normally with dvd fab with the 3.11mk version or need to do the downgrade with the dvdfab downgrader?
Mr_Orange
Re: SDFtool Flasher
#297 Post by Mr_Orange » Mon Aug 30, 2021 12:02 pm
You can't use MK firmware with DVDFab.
joitronix
Re: SDFtool Flasher
#298 Post by joitronix » Mon Aug 30, 2021 1:05 pm
Mr_Orange wrote: Mon Aug 30, 2021 12:02 pm You can't use MK firmware with DVDFab.
For decrypt 4k uhd who is better dvdfab or makemkv?
Bluntman
#299 Post by Bluntman » Mon Aug 30, 2021 5:44 pm
Best really doesn’t come into play. If it works it works.
Re: SDFtool Flasher
#300 Post by Coopervid » Mon Aug 30, 2021 6:22 pm
joitronix wrote: Mon Aug 30, 2021 11:53 am
You can also downgrade to 3.00 DE-Firmware.
