FubbAyH
Post by FubbAyH »
RESET_9999 wrote:
Sat Aug 21, 2021 9:26 pm
AFAIK, it's not possible to encode to from profile 7 to 5 yet but you can encode to profile 8. I think I read some weeks ago in this thread that the appleTV now supports this profile ?
Ah, thank you. I did a bit of Googling about profile 8.1 on Apple TV and couldn't find anything. I tried the Dolby profile 8.1 sample video playing through Infuse on Apple TV 4K and it plays as HDR10 for me. I know it's not possible to losslessly convert profile 7 to 5 because of the different color spaces, but I'm hoping that re-encoding the whole video stream would work?
FubbAyH wrote:
Sun Aug 22, 2021 12:40 am
viewtopic.php?p=110931#p110931
mulucy wrote:
Thu Jul 22, 2021 11:54 pm
I am not sure what the deal is. But my Apple TV 4K ( the previous Gen ) plays P7 MEL and P8 with Plex. What's interesting is, Plex plays P5 files with messed-up green or purple colors lol. Infuse Pro falls back to HDR10 with all profiles, but P5. Anybody knows what's happening, is it Plex magic or has Apple added more support via software update?
FubbAyH
Post by FubbAyH »
RESET_9999 wrote:
Sun Aug 22, 2021 1:46 am
mulucy wrote: ↑Thu Jul 22, 2021 11:54 pm
Plex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
FubbAyH wrote:
Sun Aug 22, 2021 2:06 am
If the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:
https://www.avsforum.com/threads/dune-p ... f.3188469/
glc650
Post by glc650 »
RESET_9999 wrote:
Sun Aug 22, 2021 2:44 am
That's exactly how I have my gen2 Apple TV 4K setup and my HDFury confirms that Infuse plays DV (P8 & 5) back correctly.
I don't use Plex but if Infuse works as expected and Plex doesn't then I'd have to assume the issue is Plex (or possibly not having 4K SDR with match DR set on the Apple TV as RESET_9999 mentioned above).
ragico
Post by ragico »
Does Apple TV 4K have TV-led or Player-led?
ragico
Post by ragico »
ragico wrote:
Sun Aug 22, 2021 10:20 am
Edit: found the answer on AVS forum.
Post by Manixx2020beyound »
FubbAyH wrote:
Sat Aug 21, 2021 8:19 pm
I noticed that x265 can do Dolby Vision encoding now, and I'm thinking about transcoding my DV UHDBD rips to profile 5 so that they're playable with DV on my beloved Apple TV. I used to think transcoding was sacrilege, but I've softened in my old age and am now thinking that if I throw enough CPU time and bitrate allowance at the encode then hopefully it will be indistinguishable from the source, and if it gives a better experience overall (for me) then it might be worth it.
Some questions:
1) Has anyone tried this, and if so do you have any advice?
2) I understand that I can extract the source RPU with dovi_tool, but since profile 5 uses a different color space to profile 7 I assume the RPU would need conversion before passing it to x265? Is that conversion a feature that I could add to dovi_tool using the information that we have available (e.g. the Dolby test files with the same content in profile 5 and profile 8.1)?
3) Do I still need to jump through some hoops to get the static HDR10 metadata and give that to x265, or does the DV RPU completely replace and obsolete that information?
4) Is there anything else I haven't thought of that makes transcoding to profile 5 infeasible or a bad idea?
RGB/DV/8b so that beak should be better than LLDV
Spares to p5
Still would need convert the p7 Rpu to p5
If that would ever be possible.
FubbAyH
Post by FubbAyH »
glc650 wrote:
Sun Aug 22, 2021 3:27 am
Thank you. That's great news because Infuse is my preferred player too. I'm testing the 8.1 test files from Dolby and from Mystery Box, though, and they are both playing as HDR10 for me. I've set output to 4K SDR with Match Dynamic Range on as you suggested, but I get the HDR10 logo on my TV when playing the files rather than the DV logo. Do you have some sample files that are working for you that I could try?
mulucy
Post by mulucy »
That's exactly how my setup is. My ATV is the fists Gen 4k version. It's strange since Apple does not officially support P8 or MEL P7. Not that I am unhappy, but it's Apple we are taking about lol
mulucy
Post by mulucy »
FubbAyH wrote:
Sun Aug 22, 2021 6:28 pm
Use Plex instead. For some reason, Plex does support P7 MEL/P8, but it fails to play P5 correctly. Infuse is total opposite of it lol
mulucy
Post by mulucy »
I have noticed weird color issues with online P5 files, mainly from HBO Max and Disney Plus. On Apple TV 4k 1st Gen with Infuse/Plex or my built-in TV apps using USB files, I have these green, purple, and sometimes red color issues. I have two Apple TV 4ks, tested on my Vizio and TCL. But Fire TV 4k Stick has been super stable and rock-solid, with no issues so far. I have had some problems with P5 DV titles in the MP4 container, mainly was related to freezing. I am assuming it has nothing to do with Fire TV itself. There is something wrong with MP4 encoding ( I am at least assuming ).
FubbAyH
Post by FubbAyH »
Thank you very much for that link, those files are super useful. I just tested them out and the MKV plays in Plex and triggers the DV logo on the TV (yay!) but there are no dramatic brightness changes from 27 seconds as described in the post, so the RPU is being ignored and it is indeed fake DV (boo!) Playing the MP4 version puts the TV in HDR10 mode and the playback is extremely stuttery, so maybe it's trying to transcode on the fly.
mulucy
Post by mulucy »
FubbAyH wrote:
Sun Aug 22, 2021 7:23 pm
Are not those files all FEL P7? We need P8 and P7 MEL to properly test to see if it's indeed fake DV
FubbAyH
Post by FubbAyH »
mulucy wrote:
Sun Aug 22, 2021 7:28 pm
Good point. Yes, they are FEL P7.The Dolby 8.1 test file I tried played in Plex as HDR10 and with the extreme stutter. Do we know of any P7 MEL test files that have a very noticeable RPU for testing? Perhaps we could make one of those from the FEL test file using dovi_tool?
