Ah, thank you. I did a bit of Googling about profile 8.1 on Apple TV and couldn't find anything. I tried the Dolby profile 8.1 sample video playing through Infuse on Apple TV 4K and it plays as HDR10 for me. I know it's not possible to losslessly convert profile 7 to 5 because of the different color spaces, but I'm hoping that re-encoding the whole video stream would work?RESET_9999 wrote: ↑Sat Aug 21, 2021 9:26 pmAFAIK, it's not possible to encode to from profile 7 to 5 yet but you can encode to profile 8. I think I read some weeks ago in this thread that the appleTV now supports this profile ?
viewtopic.php?p=110931#p110931FubbAyH wrote: ↑Sun Aug 22, 2021 12:40 amAh, thank you. I did a bit of Googling about profile 8.1 on Apple TV and couldn't find anything. I tried the Dolby profile 8.1 sample video playing through Infuse on Apple TV 4K and it plays as HDR10 for me. I know it's not possible to losslessly convert profile 7 to 5 because of the different color spaces, but I'm hoping that re-encoding the whole video stream would work?
mulucy wrote: ↑Thu Jul 22, 2021 11:54 pmI am not sure what the deal is. But my Apple TV 4K ( the previous Gen ) plays P7 MEL and P8 with Plex. What's interesting is, Plex plays P5 files with messed-up green or purple colors lol. Infuse Pro falls back to HDR10 with all profiles, but P5. Anybody knows what's happening, is it Plex magic or has Apple added more support via software update?
Plex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.RESET_9999 wrote: ↑Sun Aug 22, 2021 1:46 ammulucy wrote: ↑Thu Jul 22, 2021 11:54 pm
If the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:FubbAyH wrote: ↑Sun Aug 22, 2021 2:06 amPlex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
https://www.avsforum.com/threads/dune-p ... f.3188469/
That's exactly how I have my gen2 Apple TV 4K setup and my HDFury confirms that Infuse plays DV (P8 & 5) back correctly.RESET_9999 wrote: ↑Sun Aug 22, 2021 2:44 amIf the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:
I don't use Plex but if Infuse works as expected and Plex doesn't then I'd have to assume the issue is Plex (or possibly not having 4K SDR with match DR set on the Apple TV as RESET_9999 mentioned above).FubbAyH wrote: ↑Sun Aug 22, 2021 2:06 amPlex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
Does Apple TV 4K have TV-led or Player-led?
RGB/DV/8b so that beak should be better than LLDVFubbAyH wrote: ↑Sat Aug 21, 2021 8:19 pmI noticed that x265 can do Dolby Vision encoding now, and I'm thinking about transcoding my DV UHDBD rips to profile 5 so that they're playable with DV on my beloved Apple TV. I used to think transcoding was sacrilege, but I've softened in my old age and am now thinking that if I throw enough CPU time and bitrate allowance at the encode then hopefully it will be indistinguishable from the source, and if it gives a better experience overall (for me) then it might be worth it.
Some questions:
1) Has anyone tried this, and if so do you have any advice?
2) I understand that I can extract the source RPU with dovi_tool, but since profile 5 uses a different color space to profile 7 I assume the RPU would need conversion before passing it to x265? Is that conversion a feature that I could add to dovi_tool using the information that we have available (e.g. the Dolby test files with the same content in profile 5 and profile 8.1)?
3) Do I still need to jump through some hoops to get the static HDR10 metadata and give that to x265, or does the DV RPU completely replace and obsolete that information?
4) Is there anything else I haven't thought of that makes transcoding to profile 5 infeasible or a bad idea?
Spares to p5
Still would need convert the p7 Rpu to p5
If that would ever be possible.
- F0E45BB3-2A6F-4978-B55C-3B0DEECB18C3.jpeg (523.87 KiB) Viewed 17359 times
- 5B05CDF8-28CB-4BCC-B054-AE4B25C243DB.jpeg (404.25 KiB) Viewed 17359 times
Thank you. That's great news because Infuse is my preferred player too. I'm testing the 8.1 test files from Dolby and from Mystery Box, though, and they are both playing as HDR10 for me. I've set output to 4K SDR with Match Dynamic Range on as you suggested, but I get the HDR10 logo on my TV when playing the files rather than the DV logo. Do you have some sample files that are working for you that I could try?
That's exactly how my setup is. My ATV is the fists Gen 4k version. It's strange since Apple does not officially support P8 or MEL P7. Not that I am unhappy, but it's Apple we are taking about lolRESET_9999 wrote: ↑Sun Aug 22, 2021 2:44 amIf the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:FubbAyH wrote: ↑Sun Aug 22, 2021 2:06 amPlex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
Use Plex instead. For some reason, Plex does support P7 MEL/P8, but it fails to play P5 correctly. Infuse is total opposite of it lolFubbAyH wrote: ↑Sun Aug 22, 2021 6:28 pmThank you. That's great news because Infuse is my preferred player too. I'm testing the 8.1 test files from Dolby and from Mystery Box, though, and they are both playing as HDR10 for me. I've set output to 4K SDR with Match Dynamic Range on as you suggested, but I get the HDR10 logo on my TV when playing the files rather than the DV logo. Do you have some sample files that are working for you that I could try?
I have noticed weird color issues with online P5 files, mainly from HBO Max and Disney Plus. On Apple TV 4k 1st Gen with Infuse/Plex or my built-in TV apps using USB files, I have these green, purple, and sometimes red color issues. I have two Apple TV 4ks, tested on my Vizio and TCL. But Fire TV 4k Stick has been super stable and rock-solid, with no issues so far. I have had some problems with P5 DV titles in the MP4 container, mainly was related to freezing. I am assuming it has nothing to do with Fire TV itself. There is something wrong with MP4 encoding ( I am at least assuming ).
Thank you very much for that link, those files are super useful. I just tested them out and the MKV plays in Plex and triggers the DV logo on the TV (yay!) but there are no dramatic brightness changes from 27 seconds as described in the post, so the RPU is being ignored and it is indeed fake DV (boo!) Playing the MP4 version puts the TV in HDR10 mode and the playback is extremely stuttery, so maybe it's trying to transcode on the fly.RESET_9999 wrote: ↑Sun Aug 22, 2021 2:44 amIf the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:FubbAyH wrote: ↑Sun Aug 22, 2021 2:06 amPlex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
Are not those files all FEL P7? We need P8 and P7 MEL to properly test to see if it's indeed fake DVFubbAyH wrote: ↑Sun Aug 22, 2021 7:23 pmThank you very much for that link, those files are super useful. I just tested them out and the MKV plays in Plex and triggers the DV logo on the TV (yay!) but there are no dramatic brightness changes from 27 seconds as described in the post, so the RPU is being ignored and it is indeed fake DV (boo!) Playing the MP4 version puts the TV in HDR10 mode and the playback is extremely stuttery, so maybe it's trying to transcode on the fly.RESET_9999 wrote: ↑Sun Aug 22, 2021 2:44 amIf the appletv is set to 4k SDR with Dynamic Range Match on and it triggers DV, i don't think it's fake DV. Could be easily tested with the files in this post:FubbAyH wrote: ↑Sun Aug 22, 2021 2:06 amPlex on Apple TV does some fakery unfortunately, so it isn't real profile 7 or profile 8 support. It switches the TV to DV mode, but is actually just playing the HDR10 version.
Good point. Yes, they are FEL P7.The Dolby 8.1 test file I tried played in Plex as HDR10 and with the extreme stutter. Do we know of any P7 MEL test files that have a very noticeable RPU for testing? Perhaps we could make one of those from the FEL test file using dovi_tool?
