Feature Request : Drag and Drop audio tracks
ancient
#1 Post by ancient » Sat Aug 21, 2021 2:59 pm
Apologies if this is not in the right area, (if not can a Mod pls move it)
Can we please have the ability to drag and drop the order of Audio tracks / ie so then it changes the weight, rather than the other way around?
Many thanks.
Re: Feature Request : Drag and Drop audio tracks
#2 Post by d00zah » Sat Aug 21, 2021 3:17 pm
Not quite what you want, but IF you check Preferences > General tab > 'Expert mode' & restart MakeMKV, you can make 'adjustments' to the default selection rule on Preferences > Advanced tab per the following tutorials.
Changing default track selection
Changing track order in output file
Similar stuff available in Advanced MakeMKV usage
ancient
#3 Post by ancient » Sat Aug 21, 2021 6:45 pm
I did read both of those posts....but still different to my feature request...thank you though :)
