LG WH16NS60 Not flashing
anonymouse
Post by anonymouse »
I have a LG drive that isn't flashing
It claims to flash ok :
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d F: rawflash -i C:\Users\johnk\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file C:\Users\johnk\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_XXXXXXXXXX
 100% Operation finished
Done successfully
But when I try it afterwards it still lists the original firmware and doesn't work :
Anyone got any suggestions?
Re: LG WH16NS60 Not flashing
You have to add the "enc" option since your original firmware is encrypted. Good Luck!
Post by d00zah »
Per the Ultimate UHD Drives Flashing Guide Updated 2021
Newer OEM Firmwares and encrypted:
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)
HL-DT-ST-BD-RE_WH16NS60-1.03-N000600-212005081010.bin
Change your command line to include the 'enc' switch...
.\makemkvcon64.exe f --all-yes -d F: rawflash enc -i C:\Users\johnk\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
anonymouse
Thanks guys, that's done the business - up and working now!
:D
hardcore_gamer29
Post by hardcore_gamer29 »
anonymouse wrote: Tue Aug 17, 2021 7:52 pm Thanks guys, that's done the business - up and working now!
do i need to do all this as it is already official uhd drive for my intel i9 10900k system?
hardcore_gamer29 wrote: Sat Jan 15, 2022 7:31 am do i need to do all this as it is already official uhd drive for my intel i9 10900k system?
no we made all these guides and stuff for no reason when we were bored to confuse the new people /s
hardcore_gamer29
Billycar11 wrote: Sat Jan 15, 2022 7:47 am
LOL
greifunk
Post by greifunk »
Thanks so much! I was having issues with my flashing my drive in Linux as well until I found this thread.
For those that may need this help, I ran the following as above and was able to downgrade my 1.05 drive to 1.02 using:
./makemkvcon f --all-yes -d drivename -f /path/to/sdf.bin rawflash enc -i /path/to/flash-file.bin
I hope that helps someone else if they run into this issue!
hardcore_gamer29
which version you used mine also has 1.03. please tell
:D :D :D :D :D :D :D
