Hi Mike,
Today I ripped the DVD St. Elmo's Fire on macOS Big Sur 11.5.1 with the newest MakeMKV 1.16.4.
MakeMKV threw a DEBUG message. I have also submitted a dump file. What does this debug message mean?
The rip seemed to be successful though.
Thanks for looking!
MakeMKV v1.16.4 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/davycleys/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BP55EB40 1.00d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=0E01B47864F6)
Complex multiplex encountered - 29 cells and 12937 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (29 cell(s), 1:43:35)
Title #2 has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/MyPassport/RIPS HD
DEBUG: Code 0 at eJ|OPs]U~U(<g\[%k:213130237
1 titles saved
Debug message DVD rip St. Elmo's fire
Re: Debug message DVD rip St. Elmo's fire
Debug messages tell the author when certain events happen, in case there was a problem. Since the file was saved, they're not needed and can be ignored.
dcleys
Thanks for the feedback!
