Getting Stuck on MacBook Pro
I am trying to convert a BluRay on a MacBook Pro, using Make MKV 1.16.4, the program seems to get stuck at the point on the screenshot. I then tried on my MacBook Air running 1.15.4 and it worked perfectly. Can anyone help?
- Screenshot 2021-08-14 at 13.58.50.png (224.36 KiB) Viewed 6338 times
Re: Getting Stuck on MacBook Pro
What version of MacOS are you using? And what version of Java?
