galarond wrote: Sat Aug 14, 2021 12:47 am
not true and it has been discussed many times in this thread (even kept the pictures, i knew someone else would say that again one day lol)....
again, just remux it to TS or M2TS and you will get true DV profile 8 . I actually watched both Endgame and Infinity war on the x700 in DV + atmos :)
real DV (ts dual layer but works with single layer too):
fake DV (ts AVC):
galarond wrote: Sat Aug 14, 2021 2:22 am
1. where did you got a infinity war p8 mkv or mp4 other than the single layer mp4 from disney plus?
2. how do you know that .ts in the x700 is player as dual layer and not single layer?
i did the test with venom and bumblebee like a year ago, comparing mp4 dual layer versus full rip in m2ts and there was a big difference in picture brightness and detail. both displayed as dolby vision on tv and x700
1- I did the P8 remux myself... You can as well, all the info on how to do it is available in this thread.
2- @manix and I did many comparisons with the original, you can find all of them right here in this thread. The x700 is a 1:1 DV device and support all the profiles
DennisTheMenace
Post by DennisTheMenace »
I don't know if this is already known, but the justplayer now also supports Dolby Vision (mkv) and dts-hd sound
https://github.com/moneytoo/Player/releases
glc650
Post by glc650 »
galarond wrote: Sat Aug 14, 2021 3:02 am
Well i though that m2ts just was read as 1 layer dv but good to know now, even when all my dv movies are on mp4.
m2ts is what blu-ray uses so not sure how you got that idea.
glc650
Post by glc650 »
galarond wrote: Sun Aug 15, 2021 4:47 am 4. isnt the dv backup dual layer the best a movie can be seen?
P7 FEL (blu-ray, DTDL) is the best DV available. I believe all streaming services use Profile 5 which is STSL (so no EL). P8 is STSL as well.
galarond wrote: Sun Aug 15, 2021 4:47 am After reading here and there im getting confusing with the dv profiles the mp4muxer and the m2ts/ts files.
I have a Lg C1 and a Sony x700
1. i used to rip a dv movie and just make the mp4 dual layer way putting profile 7 always. That changes for a mel or fel movies?.
2. knowing now i was wrong and i could use a m2ts instead of a mp4 file for a dual layer playback, do i lose something if i change that profile 7 dv mp4 with mkvtoolnix and then tsmuxer?
3. p7 > p8 > p5 ?
5. is better a dovip8 movie than a p7 mp4 muxed movie with their native dual layers from the disk?
Im feeling like a retard with these 4 years old questions but if anybody can explain me this would be very nice.
As glc650 said, the best DV is FEL P7 (dual-layer) but not all the movies are FEL. Note that your TV internal app won't play FEL movies properly because it lack of a 2nd decoder but your x700 will play properly pretty much anything you throw at him
P7 fel(always dual layer) = 1 HDR10 base layer 10bits + 12bits data in EL(2 extra bits) + dynamic metadata in RPU
P7 mel (always dual layer) = 1 HDR10 base layer 10bits + blank EL (no extra bit) + dynamic metadata in RPU
P8 (always mel and single layer) = 1 HDR10 base layer 10bits + dynamic metadata in RPU
P5 (always single layer) = none-tonemapped DV base layer(green and purple colors) + dynamic metadata in RPU
P4 (dual layer,FEL or MEL) = 1 SDR base layer + FEL or MEL + dynamic metadata in RPU
so it goes like this:
P7 fel > P7 mel = P8 = P5
*Profile 7 can be merged in a single track (makemkv) but it's still dual layer DV.
*Profile 8 can also have an HLG base layer (iphone recording) so this format is compatible with HLG, SDR and DV.
*profile 5 DV : I'm not sure if it's 12bits or 10 bits because there's this description about my profile 5 patterns: ''10bits encoded remapped 12bits''. Not really sure what it means but it sounds like profile 5 could be 12bits as well.
- Dolby Laboratories
Since current Dolby Vision test patterns are limited, we decided to create an entire suite utilizing profile 5, the most commonly used profile amongst manufacturers. Profile 5, typically utilized for streaming Dolby Vision content, encompasses Dolby Vision’s proprietary IPT for color primaries and color matrix, along with the use of full range for RGB. This test pattern suite incorporates an UltraHD 3840x2160 resolution, proprietary IPT similar to BT.2100 ICtCp, 10-Bit encoded/12-bit remapped and a ST.2084 transfer function. This project follows the same idea behind our “UltraHD|HDR-10 Test Pattern Suite”, an attainable solution to calibrate and/or measure your new HDR display, without having to spend thousands on a new UHD/HDR test pattern generator.
galarond wrote: Sun Aug 15, 2021 1:49 pm Amazing, even my 4 years old brain (im 40 lol) can understand now, so my mp4 mel dual layer movies are the same as the p8 movies so i guess i only care about p8 movies if theres no uhd dv version of that movie, if not just stick with my original rip.
You can convert dual-layer profile 7 mel uhd bluray to single layer profile 8. You don't lose any quality and there's a benefit in doing that when you use a sony x700 bluray player.
P8 is actually the profile I use for all the MEL DV bluray because the x700 doesnt have the green screen bug with profile 8.
so here's how I watch DV movies on the x700
FEL P7 : remuxed to AVCHD bluray folder structure
MEL P7: converted to single layer profile 8 TS
*ts p8 playback will still have seeking issues with long movies and no automatic forced subtitles though.
staknhalo
Post by staknhalo »
I keep a DL P7 mp4 and a SL P8 mp4 inline together in Plex just so that I have DV7, HDR10 and/or DV8 all already available depending on the local device's playback capability
Sucks having to keep 2 versions of each movie space wise (why I encode my digital copies' base HDR10 layer to 45mbps - I find this quality still alright over streaming 4K and I have the physical disc still for first watching and 1:1 hard copy backup if I ever need it), but it makes it the easiest for broad playback support
Malatesta
Post by Malatesta »
Hi all,
i have a problem with one specific DV video the x700 won't play.
Its a SAW (2004) remux, taken the video from the US UHD and the german DTS HD MA blu-ray audio source.
Mediainfo
Format                      : Matroska
Format version              : Version 4
File size                   : 61.4 GiB
Duration                    : 1 h 42 min
Overall bit rate mode       : Variable
Overall bit rate            : 85.4 Mb/s
Encoded date                : UTC 2021-05-21 23:24:23
Writing application         : mkvmerge v52.0.0 ('Secret For The Mad') 64-bit
Writing library             : libebml v1.4.1 + libmatroska v1.6.2
Video
ID in the original source m : 4113 (0x1011)
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L5.1@High
HDR format                  : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                    : V_MPEGH/ISO/HEVC
Bit rate                    : 78.3 Mb/s
Width                       : 3 840 pixels
Height                      : 2 160 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0 (Type 2)
Bit depth                   : 10 bits
Bits/(Pixel*Frame)          : 0.394
Stream size                 : 56.2 GiB (92%)
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.2020
Transfer characteristics    : PQ
Matrix coefficients         : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 973 cd/m2
Maximum Frame-Average Light : 838 cd/m2
Original source medium      : Blu-ray
Audio #1
Format                      : DTS XLL
Format/Info                 : Digital Theater Systems
Commercial name             : DTS-HD Master Audio
Codec ID                    : A_DTS
Bit rate mode               : Variable
Bit rate                    : 2 430 kb/s
Channel(s)                  : 8 channels
Channel layout              : C L R LFE Lb Rb Lss Rss
Sampling rate               : 48.0 kHz
Frame rate                  : 93.750 FPS (512 SPF)
Bit depth                   : 16 bits
Compression mode            : Lossless
Stream size                 : 1.75 GiB (3%)
Title                       : Deutsch DTS-HD MA 7.1 (Blu-ray)
Language                    : German
Default                     : Yes
Forced                      : No
As always using ts-muxer converting mkv to ts.
This time with activated DV the x700 doesn't play the movie. With DV off the movie played fine in HDR10.
I have no problem playing DV for this types of "selfmade remux" before, for example Donnie Darko has no issues at all.
So whats the problem with SAW and is there anything i can do, onvert DV Profil, FEL to MEL, single track to dual track?
Thanks.
lexyz
Post by lexyz »
quietvoid wrote: Sun Aug 08, 2021 5:40 am You can now generate RPU metadata in v0.4.0, see documentation: https://github.com/quietvoid/dovi_tool/ ... nerator.md
You can find it here: https://github.com/quietvoid/dovi_tool/ ... /tag/0.4.0
I wonder is it possible (in theory) to generate a dynamic RPU based on data from MadVR MadmeasureHDR Optimizer tool? :roll:
quietvoid
Post by quietvoid »
lexyz wrote: Sun Aug 15, 2021 6:53 pm I wonder is it possible (in theory) to generate a dynamic RPU based on data from MadVR MadmeasureHDR Optimizer tool? :roll:
Of course it's possible, but there would be no creative intent adjustments.
Post by Manixx2020beyound »
What about content that is graded for dv
& includes the (DV-meta-XML adjustments) but of course does not have an Rpu is that possible?
Eg.Dv master file with xml.
For those who don’t have the dv encoding tools to build an Rpu tru sdi.
quietvoid
Post by quietvoid »
Well yes, the RPU is usually generated from the XML.
I just don't personally have a usecase for it, talked about it here: https://forum.doom9.org/showthread.php? ... ost1949650
Malatesta wrote: Sun Aug 15, 2021 5:14 pm i have a problem with one specific DV video the x700 won't play.
yep, some single-track dual-layer movies won't play on the x700. This is why it's better to use the dual-track dual-layer format because every single movie will work. Nothing i hate more than getting ready to watch a movie just to realize it doesnt play...
So you have two options:
1, demux with yusesope tool and rebuild a new DT-DL TS.
or
2, Get the original disc and remux a new DT-DL TS.
quietvoid wrote: Sun Aug 15, 2021 9:09 pm Well yes, the RPU is usually generated from the XML.
That would help the grading community,
For those guys like myself 4k,6k,8k cameras
And do their own grading without doblyvision license fees
No secondary trim pass doe.
To my knowledge the doblyvision fees are only for secondary trim passes/Rpu creation & final encode of the doblyvision master to hevc
