Hi all,
Bought a box set of all 4 Hunger Games films from Amazon. Having issues ripping Mockingjay Part 1. Only 1 instance of the full film is shown in the list, but when I rip this all the chapters are in the wrong order.
I did have issues with a couple of the other disks having lots of 'fake' playlists, but this one only seems to have one as far as I can see. The disk does play correctly in my Sony BluRay player.
Anyone help?
Andy
Hunger Games Mockingjay Part 1
adhawkins
Re: Hunger Games Mockingjay Part 2
Apologies, that should be Part 2, not Part 1.
This is all I see when I open the disk in MakeMKV:
It's interesting that there's only 1 segment in the title that's been detected as 'main feature'. That's the only Title that's the correct size and length.
Also interestingly, PowerDVD seems to play the disk in the wrong order.
Appreciate any suggestions.
Andy
Andy
Re: Hunger Games Mockingjay Part 1
I think if you turn on Expert Mode you'll be able to see all the playlists. Open MakeMKV's Preferences and on the General tab about half way down should be a check box for Expert mode. Turn that on and restart MakeMKV.
The Hunger Games: Mockingjay Part 1: viewtopic.php?f=8&t=8885
The Hunger Games: Mockingjay Part 2: viewtopic.php?f=8&t=14356
adhawkins
Thanks @dcoke22. Further investigation does suggest that it was choosing the correct playlist after all.
Apologies for the noise!
Andy
Andy
