The Last Full Measure (2019) US Retail Blu-ray
StaffInfection
Post by StaffInfection »
What is the correct mpls? Thanks.
SickPup404
Re: The Last Full Measure (2019) US Retail Blu-ray
Post by SickPup404 »
FYI,
I used the AnyDVD method posted by djwilso on this post. I'm using the current v8.4.8.0 (I'm a full registered user) and found it pointed to 00380.mpls on NF disk (not sure if RB or retail will match).
I tried using ProcMon with Leawo player, but the M2TS file numbers were all over the place and some were repeated numerous times. Both times I played the movie, it picked up 660+ file close operations on M2TS files! Maybe I wasn't doing it right...
I verified movie looks good - no odd scene jumps or out of sequence errors. So, here's the info:
Name: The Last Full Measure (English)
Source file name: 00380.mpls
Duration: 1:56:10
Chapters count: 16
Segment count: 18
Segment map: 505,514,503,513,511,507,510,517,500,512,502,508,515,504,501,516,506,509
File name: The Last Full Measure_t158.mkv
kevonator
Post by kevonator »
I'm Using the netflix dvd US. Using the 380mpls.
Everything is the same except this.
File name: The Last Full Measure_t157.mkv
It's says t157 instead of t158.
Is this the correct one?
Post by d00zah »
kevonator wrote:
Wed Aug 11, 2021 6:58 pm
Title number is variable, based on the value set in Preferences > Video tab > Minimum title length (seconds)
