Need original 1.01 firmware for the archgon MD-8107S-U3-UHD
iBrow
#1 Post by iBrow » Mon Aug 09, 2021 1:21 pm
Hi guys,
sorry for bothering.
But i can't find the original firmware 1.01 for the archgon MD-8107S-U3-UHD on the net.
Does anybody have that one still ?
On the LG page there is only the 1.02 and newer downloadable.
Thanks in advance.
Have a great day and stay safe.
Re: Need original 1.01 firmware for the archgon MD-8107S-U3-UHD
#2 Post by Billycar11 » Mon Aug 09, 2021 7:41 pm
Why would you need 1.01?
#3 Post by MartyMcNuts » Tue Aug 10, 2021 1:23 am
iBrow wrote: Mon Aug 09, 2021 1:21 pm Hi guys,
Thanks in advance.
viewtopic.php?f=16&t=24443
iBrow
#4 Post by iBrow » Tue Aug 10, 2021 2:00 pm
Thanks a lot for trying to help :).
Unfortunately on that page there is only the Taiwan version of the 1.01 not the european one (D).
To answer "Why would you need 1.01?":
I need it to put the original firmware on, as i got it when i bought it.
Because i would like to send it back as it doesn't work as good as my built in ASUS BW-16D1HT (in my old computer). It is quite loud and wasn't able to rip a UHD which my ASUS could (tho it took very long). Otherwise it looks nice but handles very flimsy. But sometimes i need to unplug it otherwise my computer doesn't start up :/ (happend twice already).
It is a new machine and it only happens with this drive (sometimes).
I needed to buy an external one as my new computer case doesn't have any 5.25 inch slots in the front ( i didn't know that is a thing now :/ ) and all the external cases (to put that ASUS drive into) cost as much as the internal ASUS drive itself.
Is it allowed to have done a firmware upgrade when you return something ?
And how does this excerpt from the readme file of the 1.04 orginal flasher relates to the 1.04 (HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin) i currently have flashed on it ?
As it states in the readme of the original firmware:
This firmware update is for drives with original firmware versions below 1.04
The drives must be original LG branded drives with the Blu-ray Writer model number
BU40N0(no OEM units).
Thanks a lot for your help :) and generally for makemkv :)
#5 Post by Billycar11 » Tue Aug 10, 2021 9:14 pm
They won't care or notice you updated firmware what errors did you get on the BU40N vs the Asus I'm guessing it because the dive did not have enough power with both USB chords on separate USB circuits
#6 Post by MartyMcNuts » Tue Aug 10, 2021 11:41 pm
@iBrow,
I'm certain there is no European firmare and that all Archgon drives are from Taiwan.
iBrow
#7 Post by iBrow » Wed Aug 11, 2021 5:13 pm
I got various errors, sometimes they would differ with the archgon. The ASUS drive is in my old computer (internal).
My new computer's case doesn't have any slots in the front to actually put any cd-drive in there. I haven't noticed that when i bought it, as i was not aware that cases might come without it by now :(.
And i realized it only in the end when i already screwed in everything else.
The ASUS had messaged about errors as well but was able to read through them (which took more than 2 hours, the rip-speed at some point said 2.0[safe] and wouldn't get faster anymore even tho it sounded as it was through with the "unreadable" sectors) i had the retry-count set to 20.
But the Archgon always spit out errors at about the same section, tho sometimes it would vary when it started. I tried 6 times or so to rip it with the Archgon.
I tried connecting the 2nd usb-cable to an usb-hub with its own poweradapter, but that didn't seem to make any difference.
At the bottom i pasted what the archgon went through, it sounded really painful ;). The archgon is so loud compare to the ASUS drive.
I often have discs which spit out errors but it (ASUS) mostly ate through them. I only have the Archgon for 2 weeks now and it was for now 1 disc out of 4 which it couldn't rip.
But that is a bad feeling knowing that the archgon would handle less. But the other issue with it, causing my computer to get stuck on boot up when it is connected for some reason, is irritating already.
Would i be able to flash the original 1.04 from taiwan onto the modified version i have flashed right now, i ask because the readme always states i should only flash it onto the original version ?
Thanks a lot for all your help guys :). Makemkv is an amazing tool :) i bought it 9 years ago. It is such a blessing to be able to rip the movies so you don't have to sit through those lengthy annoying announcements...
before the movie starts when i would watch the movies/series directly from the originals in my bluray player. It is unbareable what they make you suffer through.
Here is the errorlog (unfortunately i don't have the log of the successful rip by the ASUS drive, it was a lot less, tho it needed on some sectors nearly 20 times. too)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26365655040'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26365655040'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26365722624'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26365784064'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26365784064'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26365919232'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26365919232'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26365980672'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26365980672'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26366177280'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26366312448'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26366312448'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26366441472'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26366441472'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367227904'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367227904'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367356928'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367356928'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367424512'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367424512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367553536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367621120'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367621120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367688704'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367688704'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367750144'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367750144'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367885312'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367885312'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26367946752'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26367946752'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368014336'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368014336'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368081920'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368081920'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368210944'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368210944'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368339968'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368339968'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368475136'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368475136'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368536576'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368536576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368800768'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368800768'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368868352'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26368868352'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26368997376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369064960'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369193984'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26369193984'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369261568'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26369261568'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369323008'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26369323008'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369458176'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26369458176'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26369519616'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26369519616'
Again thanks a lot for all the help and figuring all the stuff out!!!
Bless you all :)
