new 4k uhd driver help
hardcore_gamer29
First of all i am very much new to this topic . I am looking for bluray drive that can play bluray and 4k UHD movies as well on my pc . What are the steps required and all that?
My pc specs:
i9 10900k
32 gb 4266mhz ram
My pc specs:
i9 10900k
32 gb 4266mhz ram
Re: new 4k uhd driver help
Play UHD directly to your TV, or through software?
Ripping, or just playing?
with your specs you should be able to do it officially but if you dont use the igpu then you need to do it unofficially and for that i recommend makemkvs integration with vlc or mpc with mad vrhardcore_gamer29 wrote: ↑Sun Aug 08, 2021 5:26 pmFirst of all i am very much new to this topic . I am looking for bluray drive that can play bluray and 4k UHD movies as well on my pc . What are the steps required and all that?
My pc specs:
i9 10900k
32 gb 4266mhz ram
hardcore_gamer29
hardcore_gamer29
Which model of bluray drive should i buy for windows 10 pc?
There's a Ultimate UHD Drives Flashing Guide post that's kept up-to-date. (viewtopic.php?f=16&t=19634) Billycar11 even has it linked in his signature.
It has a list of drives recommended for ripping. If you want to play UHDs directly from the optical discs with official software, then you'll need to buy a UHD official drive.
Check out the drive guide… it has answers to most of your questions.
hardcore_gamer29
ok so if i want to play directly from uhd drive by using official powerdvd ultra . then i have no choice but to buy official UHD drive?dcoke22 wrote: ↑Fri Aug 13, 2021 1:00 pmThere's a Ultimate UHD Drives Flashing Guide post that's kept up-to-date. (viewtopic.php?f=16&t=19634) Billycar11 even has it linked in his signature.
yes but trust me dont buy one for that reason it is extremely buggy even if you meet the requirements sometimes it does not work.hardcore_gamer29 wrote: ↑Sun Aug 15, 2021 5:48 amok so if i want to play directly from uhd drive by using official powerdvd ultra . then i have no choice but to buy official UHD drive?dcoke22 wrote: ↑Fri Aug 13, 2021 1:00 pmThere's a Ultimate UHD Drives Flashing Guide post that's kept up-to-date. (viewtopic.php?f=16&t=19634) Billycar11 even has it linked in his signature.
if you want an official one fine but dont buy it just for official playback be open to unofficial playback on pc its nearly the same
hardcore_gamer29
ok fine so which unofficial drive you would suggest asus pioneer or lg and which model so that i can play uhd disks well on my pc without loosing quality. also after ripping can i play them with powerdvd?Billycar11 wrote: ↑Sun Aug 15, 2021 8:07 amyes but trust me dont buy one for that reason it is extremely buggy even if you meet the requirements sometimes it does not work.hardcore_gamer29 wrote: ↑Sun Aug 15, 2021 5:48 amok so if i want to play directly from uhd drive by using official powerdvd ultra . then i have no choice but to buy official UHD drive?dcoke22 wrote: ↑Fri Aug 13, 2021 1:00 pmThere's a Ultimate UHD Drives Flashing Guide post that's kept up-to-date. (viewtopic.php?f=16&t=19634) Billycar11 even has it linked in his signature.
I recommend the BU40N it's an official drive.
It won't lose any quality.
Yes you can play them in powerdvd after ripping
I sell pre flashed and tested BU40Ns below if you want one
hardcore_gamer29
i have bought asus bw-16d1ht can you please help me run 4k uhd with this
thanks
thanks
all the info you need is linked below to do it your self or buy an automated flasherhardcore_gamer29 wrote: ↑Sun Sep 05, 2021 4:34 pmi have bought asus bw-16d1ht can you please help me run 4k uhd with this
thanks
