#5281 Post by RESET_9999 » Sat Aug 07, 2021 7:52 pm
chros wrote: Sat Jul 31, 2021 9:30 pm Unfortunately, it does not, it produces hue shift.
But the near black glowing (if you have it) can be eliminated with custom 1dlut!
Yep, I took a closer look and you are right. damn :(
I'll try your solution eventhough I'm a newbie for all the calibration and lut file import stuff. I paid someone to calibrate my TV but it is something that I want to learn. (bought an i1 display pro recently)
thank you
fenton wrote: Sat Aug 07, 2021 12:42 am Personally if it was me I would just rip the iso and then play it back on a navidia shield tv as it has Dolby vision support and also Dolby atmos support
well, it is a good DV mediaplayer if you don't care about red push issue and the lack of FEL decoding support. HDR10 is probably better/more accurate than DV on the Shield.
parnexcodes wrote: Sat Aug 07, 2021 4:40 am In my case the bluray source has higher framecount than webdl dv source.
At the same frame , dv = 19641 and bluray = 19664
Will the procedure be same ?
	"duplicate": [
			"source": 0,
			"offset": 0,
			"length": 23
Rainer wrote: Sat Aug 07, 2021 2:51 pm
if you have a newer LG (C9 or newer i think), you might have to convert profile 7 to profile 8 (at least for the FEL movies)
check out this tool
lexyz wrote: Sat Aug 07, 2021 6:44 pm But shield colors... :evil:
https://slow.pics/c/iHbxWsK2
oh wow, WTF... this doesnt happen on my shield + plex + C8
still crushed at 16 though
quietvoid wrote: Sat Aug 07, 2021 3:45 pm
Maybe Dolby is crushing blacks a lot more for 10 000 nits mastered?
Here are samples to try:
7/3079: https://mega.nz/file/scFxEQob#UUiBMJBSV ... 1fwGJZ6URo
62/3696: https://mega.nz/file/YINjjYxK#IqOGwxla5 ... HTgern5QIs
oh wow... it is the first time I can see 66 flashing with a DV black pattern. Usually can only see around 72 flashing
even the p5 pattern which is mastered at 4000nits is crushed: i cant see below 16.
quietvoid
#5282 Post by quietvoid » Sun Aug 08, 2021 5:40 am
I'm actually seeing 72 flashing with L2 metadata target for 600 nits, source min/max 7,3079 and L6 metadata MDL 1000,1.
That was a generated RPU.
So with MDL 1000 metadata, LG player shows down to 68.
Firestick to 72.
So maybe this black level pattern is not really useful, thanks Dolby.
manuelrn wrote: Sat Jul 24, 2021 9:33 pmI believe that the ideal would be that, in case the amount of frames of the video and the RPU does not match, the last frame of the RPU is copied repeatedly the number of times necessary to obtain the same frame length as the video.
And in case the RPU contains more frames than the video, when the last frame of the video is processed with the RPU, skip the next frames of the RPU.
In fact, I think the tool should behave like this by default, without using that '--ignore-framecount' argument or any other argument.
But, when this happens, the tool should show a warning message about it so that the user is aware of it (just in case he did it accidentally).
Regards!
This has been implemented in v0.4.0
chros wrote: Fri Jul 23, 2021 7:39 pm That's interesting what you talk about: can I add fake DoVi metadata (e.g. 1000 MDL, 1000 MaxCLL, 300 FALL) into a HDR10 stream, if so how?
(I want to create a small DoVi sample for FireStick 4k from a HDR10 sample to see whether it triggers tv-led or player-led with LG.)
You can now generate RPU metadata in v0.4.0, see documentation: https://github.com/quietvoid/dovi_tool/ ... nerator.md
You can find it here: https://github.com/quietvoid/dovi_tool/ ... /tag/0.4.0
Rainer
#5283 Post by Rainer » Sun Aug 08, 2021 11:14 am
RESET_9999 wrote: Sat Aug 07, 2021 7:52 pm
check out this tool
>dovi_tool info --input "test.mkv"
Parsing RPU file...
thread 'main' panicked at 'Input file probably too large', src\dovi\mod.rs:82:9
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Where to set this?
Which profile does MakeMKV use?
Edit:
These tools do not seem to work when I have already a 1-layer-movie.
At least I did not manage it.
#5284 Post by RESET_9999 » Sun Aug 08, 2021 1:16 pm
quietvoid wrote: Sun Aug 08, 2021 5:40 am I'm actually seeing 72 flashing with L2 metadata target for 600 nits, source min/max 7,3079 and L6 metadata MDL 1000,1.
Firestick to 72.
Nah 66 is clearly visible using the C8 internal player with the 7/3079 sample but I have the perfect pitch black room with light absorbent material on walls, ceiling, and floor ( black velvet) and I'm young with a 20/20 vision.
I'm not sure what that means though, I would like to know what Stacey thinks about that.
wow this is great.. thank you works great... so much easier than before!!!!
also, I noticed that sometimes the maxcll/fall of the rpu are set to 0 while the hdr10 stream have metadatas. Do you recommend changing the metatadas of the rpu ?
BTW, I watched two p8 injected DV movies this weekend. Not a single issue. works just perfect. really amazing work man!!!
Rainer wrote: Sun Aug 08, 2021 11:14 am Edit:
the tools work. you have to demux the hevc stream first.
quietvoid
#5285 Post by quietvoid » Sun Aug 08, 2021 3:15 pm
RESET_9999 wrote: Sun Aug 08, 2021 1:16 pmalso, I noticed that sometimes the maxcll/fall of the rpu are set to 0 while the hdr10 stream have metadatas. Do you recommend changing the metatadas of the rpu ?
L6 metadata is optional as far as I know, but maybe.
It's not currently possible in the editor though but is something I wanted to add.
I just tried the S&M benchmark with generated Dolby Vision and it looks the exact same as the TV-led vs player-led comparison.
That's probably because the trim passes aren't present, so saturation is wrong.
Otherwise the tonemapping is a lot better than the default HDR10 on the C8 for 10000 nits..
#5286 Post by RESET_9999 » Sun Aug 08, 2021 5:53 pm
quietvoid wrote: Sun Aug 08, 2021 3:15 pm I just tried the S&M benchmark with generated Dolby Vision and it looks the exact same as the TV-led vs player-led comparison.
that's right, I just tested this too. Once the rpu is modified(7/3079), DV becomes blown-out like(but not as much as) HDR10 @10k nits and i can see the same color difference as in the vincent video
So the LLDV bug is caused by the player not sending the correct trim pass when it's decoding DV? So the brighter the HDR grade is, the more the LLDV bug will be visible.
quietvoid
#5287 Post by quietvoid » Sun Aug 08, 2021 6:11 pm
RESET_9999 wrote: Sun Aug 08, 2021 5:53 pmthat's right, I just tested this too. Once the rpu is modified(7/3079), DV becomes blown-out like(but not as much) HDR10 @10k nits and i can see the same color difference as in the vincent video
The bug is definitely the same thing, because creative adjustments aren't being applied by the player. I think Stacey mentioned that the L2 metadata was ignored, and that's what causes the image to be worse.
Obviously the brighter the grade, then L2 metadata has stronger adjustments depending on target display nits.
However that's all creative intent, so it would be complicated to add "proper" adjustments for non-DoVi HDR10 movies.
#5288 Post by RESET_9999 » Sun Aug 08, 2021 6:26 pm
yep, it all makes sense now.
the eagle beak still remains relatively yellow though while in LLDV with original fel, it turns greenish.
chros
#5289 Post by chros » Mon Aug 09, 2021 8:42 pm
RESET_9999 wrote: Sun Aug 08, 2021 1:16 pmI have the perfect pitch black room with light absorbent material on walls, ceiling, and floor ( black velvet)
:D That's a hardcore setup, congrats!
chros wrote: Sat Aug 07, 2021 11:10 amBtw, since you are the DoVi guru (and we know a lot about hdr10), I don't really understand what the min (max) limunance setting does in reality. I don't see the point. Do you know anything about this? Thanks
I'm not sure what min/max you're talking about, in the RPU metadata?
It's usually the measured values for a frame/scene, so that's the dynamic part..
Also, setting the source min and max PQ in the RPU to proper values for limited has an effect.
Now I see down to 78 with 62/3696 (as spec says for profile 7), and 74 with 7/3079
Somehow 7/3079 is also being used in UHD BD.
From the data I can collect with the level 6 metadata (mastering display)..
Max 1000, min 1-10 should be 7/3079.
Max 4000, min 50 should be 62/3696.
RESET_9999 wrote: Sat Aug 07, 2021 7:52 pmoh wow... it is the first time I can see 66 flashing with a DV black pattern. Usually can only see around 72 flashing
quietvoid wrote: Sun Aug 08, 2021 5:40 am I'm actually seeing 72 flashing with L2 metadata target for 600 nits, source min/max 7,3079 and L6 metadata MDL 1000,1. That was a generated RPU.
So with MDL 1000 metadata, LG player shows down to 68. Firestick to 72.
RESET_9999 wrote: Sun Aug 08, 2021 1:16 pmNah 66 is clearly visible using the C8 internal player with the 7/3079 sample ... I'm not sure what that means though, I would like to know what Stacey thinks about that.
:) That's a really interesting finding!
I meant the measured values for a frame/scene in the RPU, but I thought there's a min value as well, but there isn't, only maxCLL and maxFall per frame.
But you now brought up the "Source min and max PQ", what does it mean exactly? And what are those "7/3079" and "62/3696" numbers corresponding to? Which metric? (I bet it's not nits.)
And what is the L1 min_pq/max_pq/avg_pq?
Here all the 3 sources (internal Plex, Oppo, Firestick4k) produces different results with those files :)
Firestick4k is the best with the 3079 sample (as you said), here I can see 74 flashing, but it cuts everything under it, no matter which picture preset I select.
The brightest source out of all is the internal Plex, 2nd is Oppo, then Firestick at the last place :) (Maybe HDMI signal cuts black at certain point as well, not sure.)
quietvoid wrote: Sun Aug 08, 2021 5:40 am This has been implemented in v0.4.0
RESET_9999 wrote: Sun Aug 08, 2021 1:16 pmwow this is great.. thank you works great... so much easier than before!!!!
Indeed, You have created an amazing, useful tool, thank You!
E.g. now we can easily create DoVi test patterns out of our HDR10 ones :)
Here's the previously posted DP p8.1 DoVi banding sample (05-2160p_23fps_dovi_p81-dp_s02e03_banding.ts) with generated RPU (I measured the maxFALL with madvr's madmeasure):
    "length": 1000,
    "target_nits": 1000,
    "level6": {
        "max_content_light_level": 1000,
        "max_frame_average_light_level": 67
What is the "target_nits" for? (for L2 target_max_pq?) Is it in nits? If so, can we use any value here? (e.g. 2435)
Initially I used 600 (as in your sample), but the result didn't "pop", after that I did it with 1000 and it's much better this way.
So, if you also agree, then this value needs to be changed in your sample as well.
quietvoid wrote: Sun Aug 08, 2021 3:15 pmI just tried the S&M benchmark with generated Dolby Vision and it looks the exact same as the TV-led vs player-led comparison.
RESET_9999 wrote: Sun Aug 08, 2021 5:53 pmSo the LLDV bug is caused by the player not sending the correct trim pass when it's decoding DV?
quietvoid wrote: Sun Aug 08, 2021 6:11 pmI think Stacey mentioned that the L2 metadata was ignored, and that's what causes the image to be worse.
I guess you meant the 10.000 nits SM version.
Nice finding, again! But what is a trim pass in DoVi world and what is it used for? (I saw it in the RPU as well.)
#5290 Post by Manixx2020beyound » Tue Aug 10, 2021 8:07 pm
chros wrote: Mon Aug 09, 2021 8:42 pm
    "length": 1000,
    "level6": {
Trim pass process.
https://learning.dolby.com/hc/en-us/art ... Trim-Pass-
quietvoid
#5291 Post by quietvoid » Wed Aug 11, 2021 12:26 am
chros wrote: Mon Aug 09, 2021 8:42 pm:) That's a really interesting finding!
Source min and max PQ are PQ code values in 12 bit, converting to nits should be simple, it's just a division by 4095 and converting from PQ to nits.
I'm not exactly sure what they specify, but I think it might have to do with the mastering display, since they seem correlated to the L6 metadata.
L1 metadata are measurements done per frame/scene (depends) by analysis. It's supposed to help with the tonemapping.
chros wrote: Mon Aug 09, 2021 8:42 pmWhat is the "target_nits" for? (for L2 target_max_pq?) Is it in nits? If so, can we use any value here? (e.g. 2435)
Target nits is for L2 target_max_pq, yes. It is in nits.
Normally it is used for creative adjustments per trim ("different displays"), because the grading is done at multiple brightness to map properly across the whole range while keeping creative intent.
I didn't think a single L2 target would make any difference, but maybe. Currently everything is left default, so no adjustments at all.
From what I noticed, highlights are tonemapped OK but I'm not sure if FALL is lower. Saturation might be different for higher nits.
I didn't really compare properly with different targets.
I don't really expect generated metadata to be very useful, since it's missing creative intent and measurements.
And since measurements often depend on denoised video (L4 metadata) and properly separated scenes, it would be quite complex to do.
#5292 Post by RESET_9999 » Thu Aug 12, 2021 2:08 pm
galarond wrote: Wed Aug 11, 2021 3:25 am Hi guys im getting crazy with this, i dont even know if its possible or not.
I have a dolby vision single layer mp4, ripped from web, inside theres multiple audio tracks so i just want to have the dolby vision single layer with 1 track.
there is no EL in profile 5 DV from streaming.
demux, then :
mp4muxer_64bits.exe --dv-profile 5 --input-file X:\video.hevc --input-file X:\audio.ec3 --output-file output.mp4
galarond wrote: Thu Aug 12, 2021 7:07 am
Hi, sorry for the noob question but how and what do i need to use to extract both layer from the dv web mp4 rip? for dovi tool i need the hevc already but how i go from the dv mp4 ripped from web and the hevc keeping both layers?
with mp4demux i only get 1 hevc that doest contain the dolby layer...
you have to extract and convert the RPU to profile 8(step #2). Once you know the frame difference with the bluray remux, you make a json and you can inject the rpu from the web-dl.
#5293 Post by RESET_9999 » Thu Aug 12, 2021 6:19 pm
galarond wrote: Thu Aug 12, 2021 5:55 pm
Tnx for your answer
1. when i use that line for mp4muxer i get a SDR file with greenish look, using the .h265 (not .hevc) that is extracted with mp4demuxer.
2. how do i extract the rpu from a mp4 (not .hevc) DV rip from disney plus?
1- probably because you are using the latest mp4muxer which doesnt work for me as well. Try with this old version instead: https://drive.google.com/file/d/1yZ1EgB ... sp=sharing
2- demux to hevc(or h265) with tsmuxer, ffmpeg, mp4demuxer etc...
then:
dovi_tool.exe -m 3 extract-rpu DV.hevc
Poker354
#5294 Post by Poker354 » Thu Aug 12, 2021 8:03 pm
RESET_9999 wrote: Thu Aug 12, 2021 2:08 pm
demux, then :
Tnx for your answer
What I do with the Mp4 file is run it through MKVToolnix (latest v60) to create a mkv file
then use the command line: mkvextract.exe tracks YourFileName.mkv -f 0:DV.hevc
then extract the RPU with the command line: dovi_tool.exe -m 3 extract-rpu DV.hevc
#5295 Post by RESET_9999 » Fri Aug 13, 2021 2:14 pm
galarond wrote: Fri Aug 13, 2021 1:11 am
Im confused too, i have that file too and its in mkv, its only hdr10 or Dv? i only understand the merge or the rpu and the uhd disc rip hdr10 file but the result is a hdr or dv mkv? if its a dv in mkv theres any way to revert back and get 2 layers to form a mp4 dv? i only have a x700 to reproduce dv so i all mkv, dv or hdr10 shows as hdr.
anyway that file is dv or hdr?
It's both DV and HDR10 compatible. For playback on your x700, just remux the file with tsmuxer .
you will have to add the AC3 core back into the TrueHD stream if you want to keep Atmos.
