Optical drive to rip Blu-ray (25/50)
Frosafelix
Post by Frosafelix »
Hi! This is my first post. I tried to find out about this searching for my question but couldn't find an answer to it. I see that there is a list of optical drives that are UHD friendly, but what if I want to begin ripping BR and DVD, couldn't I make do with any drive as long as it reads BR?
Re: Optical drive to rip Blu-ray (25/50)
You can assume that any of the drives listed as UHD-friendly can also read the "lower standard" disks, like CD, DVD, and regular BD. Most have the symbols for these on their drive trays.
Even the "UHD-official" drives, which are not UHD-friendly, will also rip most everything.
The exception is HD-DVD, which you won't see on many modern drives.
Frosafelix wrote: Sun Aug 08, 2021 3:32 pm Hi! This is my first post. I tried to find out about this searching for my question but couldn't find an answer to it. I see that there is a list of optical drives that are UHD friendly, but what if I want to begin ripping BR and DVD, couldn't I make do with any drive as long as it reads BR?
Yes. If you currently have a drive and it works with MakeMKV to rip DVDs and/or regular blu-rays, then by all means, use it.
If you're going to buy a drive, then (generally speaking) it makes sense to get one of the drives on the list (viewtopic.php?f=16&t=19634).
Frosafelix
dcoke22 wrote: Sun Aug 08, 2021 7:00 pm
Thanks for the tip. That guide is pretty comprehensive. I am going to use the one I have right now to make remuxes of my DVDs, and will buy one of those drives later.
