Optical Drive not being found
bib1963
Re: Optical Drive not being found
Post by bib1963 » Sat Oct 10, 2020 6:52 pm
jvian1 wrote: Thu Oct 08, 2020 1:15 am
alisonken1 wrote: Fri Oct 04, 2019 11:43 am[...]
Is your user part of the cdrom group?
if you do "ls -l /dev/sr?" you will likely get something like this
brw-rw----+ 1 root cdrom 11, 0 Oct 7 19:39 /dev/sr0
brw-rw----+ 1 root cdrom 11, 1 Oct 7 19:38 /dev/sr1
As you can see root is the owner and cdrom is the group (in fedora at least) and both have read and write permissions.
If your user is part of the cdrom group you can use the device easily.
And the '+' means there are extended ACLs in operation, which can be shown with "getfact /dev/sr?"
B
TheTester
Post by TheTester » Thu Oct 15, 2020 11:49 am
I have a blueray-writer drive and installed(makemkv) from arch but the drive is not recognized.
ls -l /dev/sr?
brw-rw----+ 1 root optical 11, 0 Oct 15 08:47 /dev/sr0
MakeMKV v1.15.3 linux(x64-release) started
The program can't find any usable optical drives.
What is the command or commands to fix this please?
I just installed it via yay makemkv so I haven't actually done anything other than that.
jvian1
Post by jvian1 » Sat Oct 17, 2020 12:42 am
That tells you the group owning /dev/sr0 is "optical".
You need to make your user part of the optical group if not already, then you should be able to see a disk in the drive and use it.
The user running makemkv must have access to the drive before makemkv can use it, so this step is first.
Using the "groups" command will tell you which groups your user is assigned and using
 sudo usermod -a -G optical exampleusername
will add the example user to the optical group. After adding the user to the new group it will be necessary for that user to log out and log back in before the change is effective.
TheTester
Post by TheTester » Sat Oct 17, 2020 2:40 pm
jvian1 wrote: Sat Oct 17, 2020 12:42 am That tells you the group owning /dev/sr0 is "optical".
Sorry I ran the command you put,
 sudo usermod -a -G optical thetester
and rebooted however the problem still exsit's.
@AdminPC ~]$ groups
sys network scanner power rfkill users video storage optical lp audio wheel thetester
Wondering if makemkv should be run as sudo or something like that.
pipo233
Post by pipo233 » Sat Oct 17, 2020 6:19 pm
Drive not been found is a common problem, here is how i fixed it on Manjaro
Open a Terminal, Note: running with sudo does not work
su root
Enter your Password
echo sg > /etc/modules-load.d/sg.conf
Exit
Reboot
After this my drive has been found (pioneer drive)
This also helps for Nero not be able to find a usable drive.
TheTester
Post by TheTester » Sat Oct 17, 2020 9:38 pm
pipo233 wrote: Sat Oct 17, 2020 6:19 pm Drive not been found is a common problem, here is how i fixed it on Manjaro
su root
Enter your Password
Exit
Reboot
Thanks that sorted it now seeing optical drive, probably need the other fix to.
gnollo
Post by gnollo » Thu Aug 05, 2021 1:21 pm
Just upgraded to version 1.16.4 for windows, and the program now cannot find any usable optical drives.
Previous version worked fine.
I can see the drive and play the bluray so I am not sure how I can fix this.
Can I use the previous version again?
Post by Woodstock » Thu Aug 05, 2021 3:27 pm
You're asking in the Linux forum.
Windows has issues where newly-installed programs that haven't been blessed by Microsoft will not be given access to removable drives. A search for "ransomware exception" will come up with how to grant MakeMKV an exemption from that policy.
chuutlu
Post by chuutlu » Sun Feb 05, 2023 12:41 pm
su root
Enter your Password
Exit
Reboot
This is it for me. Thanks.
HalMello
Post by HalMello » Sun Dec 15, 2024 2:31 am
Hello, I've been using linux less than a week, I am on Linux Mint 22, and my makemkv is also not detecting my disk driver, i tried the su root method from pipo233 without any change and I honestly don't understand the other stuff being discussed in the various comments, if anyone could try to explain some of this stuff really broken down into baby steps I'd appreciate it, because otherwise i find it very hard to follow
K@mpfH@mster
Post by K@mpfH@mster » Sun Dec 22, 2024 7:54 pm
Hello guys, I have the same problem. I am using ARCH with the FLATPAK version and the software doesnt recognise my optical drives
