GBC-H20L Flash
Great_Dane22
GBC-H20L Flash
#1 Post by Great_Dane22 » Thu Aug 05, 2021 3:05 am
Hi i need help i want to cross flash this to GGC-H20L i read its possible but all steps and programs are outdated
i have the .exe for firmware but how do i get the bin out of the exe LG updater tool
what program can i use to flash would the uhd flasher work if i can get the bin on that drive if im using GGC-H20L
im trying get HD Dvd Support i have hundreds i want to back up and my 360 hd dvd players broke
i would no use the utiliy but use different bin not UHD
Re: GBC-H20L Flash
#2 Post by Coopervid » Thu Aug 05, 2021 9:19 am
Great_Dane22
Re: GBC-H20L Flash
#3 Post by Great_Dane22 » Thu Aug 05, 2021 2:54 pm
Here is the firmware:
https://www.firmwarehq.com/LG/GGC-H20L/files.html
You can use mediacodespeedit to flash it.
https://www.videohelp.com/software/MediaCodeSpeedEdit
Hi Coopervid Thanks for the info. i actually tried that before i posted when i use Mediacodespeedit 1.2.0.10 03, it has no option with that firmware to enable cross flash i have tried all 3 1.07 1.03 1.02 i read Mediacodespeedit only supported the G.x.W models because they are also Bdrom Writers and the GBC is just a reader but it is compatible to cross flash to the GGC which supports HD DVD roms
Does anyone know how to just simply edit the Firmware EXE to detect all drives its only looking for the GGC for Safety
or Perhaps rip the .bin from the exe and can use another flash tool
i Appreciate all help and Input
Re: GBC-H20L Flash
#4 Post by Coopervid » Thu Aug 05, 2021 9:41 pm
I just used google and remembered the old days. Please do so as well to find your solution.
Re: GBC-H20L Flash
#5 Post by Coopervid » Fri Aug 06, 2021 9:51 am
It should work with the official flasher with 1.03 according to this info putting the drive in safe mode.
Your GBC drive id starts with DVDRWBD instead of the GGC prefix BDDVDRW ?
Take the drive into safe mode:
power off your PC
press the eject button and keep it pressed
power on your PC
wait 10 seconds
release the eject button
Now you can flash the GGC-H20N_1.03 firmware.
From this link:
https://club.myce.com/t/lg-blu-ray-cros ... /238076/34
Read posts #29 to #33
