Some Best Rifle Bipods on the market today
Re: Makemkv changes aspect ratio of DVD rip. How to fix it?
#1 Post by Woodstock » Wed Aug 04, 2021 12:36 pm
Searching for "aspect ratio" comes up with over 750 hits. After you remove the stuff on Dolby Vision, you'll see that MakeMKV is copying ONE of the two places where the aspect ratio is stored... and the disk authors didn't make them match. You can use the header editor from mkvtoolnix to fix it.
thetoad
#2 Post by thetoad » Sat Aug 07, 2021 1:37 pm
as I just documented here viewtopic.php?f=7&t=25853 its a bug in MakeMKV it really needs to follow the IFO.
