mulucy
Post by mulucy » Tue Aug 03, 2021 11:19 am
RESET_9999 wrote: Tue Aug 03, 2021 12:04 am
deadchip12 wrote: Mon Aug 02, 2021 11:12 pm Since you own a sony x700 bluray player, may I ask whether the usb port is 2.0 or 3.0? If I want to play movies on an hdd connected to that usb port, does the hdd need to be formatted as fat32?
usb 2.0 but more than fast enough. NTFS works.
quietvoid wrote: Sun Aug 01, 2021 12:53 am
I think I might have found one difference with appleTV profile 5 web-dls that could explain the color difference we noticed here .
I looked at the mediainfo of a couple of the appleTV p5 rip and they are all missing the color range flag FULL . this includes even the rip from itunes, not only the appleTV+ original. you can tell they are from itunes because they are also cropped (often overcropped). I think something is not right with either the way they rip appletv or the way Appletv files are encoded.
I am not sure if this missing FLAG discovery is the issue why all rips from Apple TV Plus are freezing after certain time at exact timestamp with my Fire TV Stick.
quietvoid
Post by quietvoid » Tue Aug 03, 2021 12:27 pm
chros wrote: Tue Aug 03, 2021 10:40 am@quietvoid, can you try out the profile8 sample on yours, which one is blinking for you using Kodi, 81?
Yes, 81. Though the RPU looks incorrect for profile 7 to me.
mulucy wrote: Tue Aug 03, 2021 11:19 amI am not sure if this missing FLAG discovery is the issue why all rips from Apple TV Plus are freezing after certain time at exact timestamp with my Fire TV Stick.
Most cases of freezing are usually caused by a setup of Plex (server) + an Android device, with MP4 files.
mulucy
Post by mulucy » Tue Aug 03, 2021 1:56 pm
quietvoid wrote: Tue Aug 03, 2021 12:27 pm
I think it's an MP4 container. It does not happen with MKV files. Spot on, thanks!
Post by Manixx2020beyound » Tue Aug 03, 2021 5:19 pm
lexyz wrote: Tue Aug 03, 2021 9:09 am
RESET_9999 wrote: Sun Aug 01, 2021 2:36 am @lexyz and @ragico . How does it look on your TVs?
Will check next weekend
The best players for lossless DV rips are still the oppo and the x700 (or x800m2).
Both have LLDV issues
Oppo is inaccurate in DV output after HDR10 playback.
X700 can't auto switch to DV
Sadly, any DV-capable device has issues
Well some comparison news:
We can now compare RGB 8bit DV so we don’t need to do (LLDV/bug,)
Still a few more tests to come.
Bypassing the pink screen in rgb 8 dv
This clip is from the x700.
mulucy
Post by mulucy » Tue Aug 03, 2021 7:14 pm
Manixx2020beyound wrote: Tue Aug 03, 2021 5:19 pm
Sorry for a silly question, but I see "RGB 8bit DV " and 12-bit something referred a lot here with TV-Led and LLDV, would you mind telling the difference, please?
deadchip12
Post by deadchip12 » Wed Aug 04, 2021 12:12 am
So I just read this and it says the sony x700 can only support bitrate up to 100Mbps? So movies with higher bitrate than that will be scaled down in picture quality?
https://www.sony.ca/en/electronics/supp ... s/00190648
HarperVision
Post by HarperVision » Wed Aug 04, 2021 7:01 pm
I believe when you are playing ripped files with the Sonys and not discs, it actually does auto switch DV and HDR10. At least that’s been my experience with my X800M2.
With discs you have to manually switch though, as you’re saying.
quietvoid wrote: Sun Aug 01, 2021 12:53 am I think I might have found one difference with appleTV profile 5 web-dls that could explain the color difference we noticed here .
I’m wondering if maybe since LLDV was built for and based on Sony HDR displays that didn’t have enough horsepower to decode full RGB 8 bit TV Led DV, that LLDV is supposed to be at Full range, and not Limited Range like normal HDR10 YCbCr 4:2:2 10 bit? Normally it is changed from Full to Limited in the DV decoding and processing before it’s presented to the display panel.
I doubt they ever intended anyone like me to discover the trick with an HDFury to get sources like an AppleTV and various UHD Bluray players to exploit using LLDV for displays that otherwise wouldn’t be DV capable. So maybe with a Sony LLDV UHD TV it knows it’s getting a Full range signal and processes it accordingly, but when that same LLDV signal is being tricked by an HDFury and sent to a normal HDR10 display, it thinks it’s getting a Limited Range HDR10 signal but in fact is actually getting Full range and the TV processes it thinking it’s Limited Range, causing a mismatch?
Or maybe I’m not understanding what you wrote and its intentions?
Post by RESET_9999 » Wed Aug 04, 2021 7:57 pm
mulucy wrote: Tue Aug 03, 2021 7:14 pm Sorry for a silly question, but I see "RGB 8bit DV " and 12-bit something referred a lot here with TV-Led and LLDV, would you mind telling the difference, please?
LLDV / player-led : it's the player doing the tonemapping which is buggy. It's sending a decoded 422 12bits signal (decoded so thats why we can capture it)
RGB 8bit tunneling/ tv-led: it's the TV doing the tonemapping which is accurate. it's still sending 422 12bits but wrapped in an 8bit RGB container. ( @manix thinks he found how to capture it but i don't believe him)
deadchip12 wrote: Wed Aug 04, 2021 12:12 am So I just read this and it says the sony x700 can only support bitrate up to 100Mbps? So movies with higher bitrate than that will be scaled down in picture quality?
don't worry about that. there is no quality scaled-down, the x700 doesnt have the power to do that. Many users here and I are using this player for DV and we never had any playback issues for any movies. (except for the known green screen bug with TS files)
HarperVision wrote: Wed Aug 04, 2021 7:01 pm I believe when you are playing ripped files with the Sonys and not discs, it actually does auto switch DV and HDR10. At least that’s been my experience with my X800M2.
You're almost right. The x700 will auto switch to DV and HDR10 if your HDR10 container is MKV but the problem is that the x700 only supports Atmos in a ts/m2ts/bluray container. (because mkvtoolnix splits the ac3 core)
Any TS/M2TS/bluray (HDR10 /SDR) will then get converted to DV. Netflix will also output everything in DV if you don't turn off DV in the settings.
It's really not an issue for me as I only use it for DV: I use my HTPC for HDR10/SDR.
The x700 will go even further and convert DV (even FEL) to HDR10 if you connect an HDR10 only display and leave DV turned on. Not only for file playback but on Netflix too. But I don't recommend doing that because it raises the black floor and you get incorrect metadata from netflix.
I think only profile 5 from streaming is supposed to be Full range and I think you are correct, it's converted from full to limited when the player does the tonemapping.
I tried to force the full range on the AppleTV files which are somehow signaling a limited range and it didn't make any difference...
btw the trick you found for LLDV in HDR10 with the vertex, well the x700 has been doing exactly that since day 1 when you connect an HDR10 display. So, it is part of the DV SDK capabilities.
The vertex is doing it better though, it doesnt raise the black floor like the x700 does.
deadchip12
Post by deadchip12 » Wed Aug 04, 2021 11:51 pm
RESET_9999 wrote: Wed Aug 04, 2021 7:57 pm
Does the green screen bug happen to m2ts files too? And I thought you once said it is no longer an issue if we remux the bmdv folder structure using tsmuxer and put it in root folder of the hdd?
Do we need to do anything in the settings to make sure the x700 is outputting tv led dolby vision?
Post by RESET_9999 » Thu Aug 05, 2021 12:01 am
1-yes, m2ts too.
2-yes this is no longer an issue if we remux to a folders structure.
3-nothing to set up for tv-led, unlike the oppo you can't force it to output LLDV. It will send by default the best mode according to your TV EDID.
mulucy
Post by mulucy » Thu Aug 05, 2021 2:32 am
thank you so much!
tr000
Post by tr000 » Fri Aug 06, 2021 11:26 pm
I check on this thread every two or three months, and every time I see DV is still in disarray :(
fenton
Post by fenton » Sat Aug 07, 2021 12:42 am
Personally if it was me I would just rip the iso and then play it back on a navidia shield tv as it has Dolby vision support and also Dolby atmos support
parnexcodes
Post by parnexcodes » Sat Aug 07, 2021 4:40 am
RESET_9999 wrote: Sun Jul 25, 2021 9:48 pm the json file is a simple text file in which you copy/paste the script of step 3. ( you change the number according to the movies you're syncing)
first, you have to find the frame difference between the two videos. Personally, I use MPC-BE and find the same frame for both videos, press ''control-g'' and calculate the frame number difference. You can navigate frame by frame with ''control left/right arrow'' when the video is paused.
Another method that could be easier for you is to open both videos with staxrip ''video comparison'' (tool/advanced) and navigate to the same frame.
I prefer mpc because you don't have to load the video like you have to do with staxrip. if your pc/gpu is powerful enough you could open two instances of MPC.
then the framecount of both rpu and hdr10 video must match. so you calculate how many frames you have to remove or add at the end of the rpu. (include the frame you added or removed from the start of the rpu) ... just math at this point.
hope you understand, I'm not very good at explaining things
this is the json for SOUL
In my case the bluray source has higher framecount than webdl dv source.
At the same frame , dv = 19641 and bluray = 19664
Will the procedure be same ?
chros
Post by chros » Sat Aug 07, 2021 11:10 am
Thanks for testing, I don't think the RPU matters much here (we get 72 from other sources).
That's not a good news: I have to use the internal Plex app then when I can't use the Oppo (e.g. with cropped files).
Btw, since you are the DoVi guru (and we know a lot about hdr10), I don't really understand what the min (max) limunance setting does in reality. I don't see the point. Do you know anything about this? Thanks
What do you think guys, what is the best way to test double/tripple expansion? E.g. with grayscale ramps? (we can inject some fake RPUs into hdr10 stream)
