Nice, so you could listen the undubbed versionRESET_9999 wrote: ↑Sat Jul 31, 2021 2:20 pmthank you, yes i know this guy, I'm French too... hat's me @TbeRw01 on bluray forum
Thanks for this, so it's the firestick ...RESET_9999 wrote: ↑Sat Jul 31, 2021 2:20 pmI also compared my devices with this pattern and the x700, the Shield, the Ugoos, and my C8 internal app all start crushing black at the same 70-72.chros wrote: ↑Sun Jul 25, 2021 10:43 amFirestick 4k + patched Kodi ... And indeed there's no banding/posterization, so my theory was wrong: Firestick 4k also triggers tv-led DoVi with our 2018 LG.
To add another variable into the mix
We know now that Firestick also triggers TV-Led Dovi with 2018 LGs, but the whole image is noticably darker, e.g. compared to internal apps.
Here's the profile 8.1 version of Spears's black clipping DoVi pattern, so I fired it up on FIrestick and Oppo as well (Plex didn't recognised it, dunno how that works):
- Oppo: 72 barely flashing
- Firestick: 81 barely flashing!!!
But it's not just the low end that is affected, the whole image seems to be a bit darker, it's like double-expanded is set in madvr ...
So, guys, if you like, you can also try this out (in a pitch black room) with your display and other devices to see how they behave.
And I also managed to check this via Plex (I had to separate categories), and that's also fine (~>=72 is blinking).
Just checked and that's fine in normal mode (PC mode clips black, only >=76 is visible, but that happens with all the sources).RESET_9999 wrote: ↑Sat Jul 31, 2021 2:20 pmUsing the same clip in HDR10 I can see flashing 65-66 on all my device. hows HDR10 on the firestick?
Can you check with the profile8 clip with default settings? (brightness 50, contrast 100, oled light 50)
The Pulsar 0.005 nits rectangle is also clipped at the middle top, I hope you will get the same ~70 result, that would mean a firestick setting is responsible for my 81 result ...
I just asked couple of owners over doom9, so we will know more soon.RESET_9999 wrote: ↑Sat Jul 31, 2021 2:20 pmI'm reading comments about the same issue with the newer CX and C1 TV so I guess it's a Dolby problem. I wonder if it's also crushed on Sony and Panasonic TV, of course as you said, you need to have a pitch-black room.
Unfortunately, it does not, it produces hue shift.RESET_9999 wrote: ↑Sat Jul 31, 2021 5:52 pmcontrast 99 ... yes, that works very well to fix the raised black I was getting with DV content. ... and it doesnt affect the shadow details nor the colors at all... Netflix ending credits are now truly black instead of grey. It even works for Atomic Blonde BD which I used to find unwatchable in DV.
But the near black glowing (if you have it) can be eliminated with custom 1dlut!
That's interesting you mentioned this, because I started to enjoy HDR10 on our 2018 LG in the last couple of weeks, since madvr added 3dlut support for hdr10 output!RESET_9999 wrote: ↑Sat Jul 31, 2021 5:52 pmIn the past months, I've been enjoying DV on my C8 more than ever before
