Yesterday I converted "Journey to the center of the earth" 2005 DVD and it plays without any issues what so ever..
I then converted "Back to the Future" and when I try and start it from the beginning the sound is always out of sync - unless you jump to the second chapter (26mins) into the film and the it works fine, I have converted it twice once with DD & DTS selected and once with just DD and it the same... I also have the same problem with "We were Soldiers"...
Any suggestions as its driving me mad now....MakeMKV v1.6.4 win(x86-release) started
Cells 22-end were skipped due to cell commands (structure protection?)
Title #0 was added (21 cell(s), 1:51:08)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #1 was added (1 cell(s), 0:14:28)
Title #2 was added (1 cell(s), 0:15:29)
Title #3 was added (1 cell(s), 0:02:44)
Title #4 was added (1 cell(s), 0:08:49)
Title #5 was added (1 cell(s), 0:02:17)
Title #6 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 was added (1 cell(s), 0:05:02)
Title #13 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/TODO/B2F
1 titles saved
