The Nun UHD - Fails to decrypt
stuckinkodiagain
Post by stuckinkodiagain »
The Nun (2018) on UHD blu-ray fails to decrypt in the latest version of MakeMKV (1.14.2). Dump file has been submitted to support@makemkv.com.
Thanks for your help!
dmillionz
Re: The Nun UHD - Fails to decrypt
Post by dmillionz »
Same problem here. Dump has been sent to svq@makemkv.com.
powrhaus
Post by powrhaus »
Using MakeMKV version 1.16.4 and The Nun 4K still fails to decrypt.
powrhaus wrote: Mon Jul 12, 2021 6:45 pm Using MakeMKV version 1.16.4 and The Nun 4K still fails to decrypt.
Sometimes the key for a movie is updated… email the .tgz file to svq@makemkv.com.
powrhaus
Post by powrhaus »
I'll do this now, thank you!
powrhaus
Post by powrhaus »
I submitted the .tgz file on July 13th. I just tried to rip The Nun 4k and it still fails with the same error. How long should it take for the keys to be updated?
Post by d00zah »
powrhaus wrote: Fri Jul 30, 2021 4:00 pm How long should it take for the keys to be updated?
Refer to Hashed Keys section... UHD FAQ
powrhaus
Post by powrhaus »
d00zah wrote: Fri Jul 30, 2021 5:04 pm
Thanks. Looks like it takes hours to days or longer. This was originally submitted in 2018 so perhaps it's not going to get done at all. I'll just rip the blu-ray non-UHD version and call it good.
bhampster
Post by bhampster »
My UHD copy of the Nun worked so you may try to get another copy.
Post by d00zah »
powrhaus wrote: Fri Jul 30, 2021 6:40 pm Thanks. Looks like it takes hours to days or longer. This was originally submitted in 2018 so perhaps it's not going to get done at all. I'll just rip the blu-ray non-UHD version and call it good.
The FAQ also says...
I see a movie discussed in the forum, but MakeMKV won't open my disc.
There are multiple versions of UHDs for each movie (countries, retailers, rentals) and there may be multiple keys for even the same version, so it's possible that your particular disc isn't decrypted yet. Submit the dump file! (which you've done... patience).
