No_Answer_from_makemkvcon [solved]
giubbe
Post by giubbe » Sun Mar 28, 2021 2:39 pm
Sorry for bad English.
I downloaded the version 1.16.3 and it compiles without errors.
But when I start the program, the makemkvcon crashes and Makemkv presents the error No_Answer_from_makemkvcon
Version 1.14.7 works normally.
OS: Ubuntu 18.04.5 LTS x86_64
Kernel: 5.4.0-70-generic
Shell: bash 4.4.20
Resolution: 1920x1200, 3840x2160 (two monitor)
DE: KDE
WM: KWin
Theme: Breeze [KDE], Breeze [GTK3]
Icons: Yosa-Max [KDE], Breeze [GTK3]
Terminal: konsole
CPU: AMD Ryzen 7 2700X (16) @ 3.700GHz
GPU: NVIDIA GeForce GTX 1070
Memory: 9504MiB / 15969MiB
what can it be?
thanks
dianagreece49
Re: No_Answer_from_makemkvcon
Post by dianagreece49 » Thu Apr 01, 2021 8:06 am
Can you add some screenshots?
giubbe
Post by giubbe » Thu Apr 01, 2021 9:01 pm
I can show only one image, as mentioned the program does not start.
DenverDave
Post by DenverDave » Fri Apr 23, 2021 5:05 pm
Why compile when you can use a PPA?
https://launchpad.net/~heyarje/+archive ... kemkv-beta
giubbe
Post by giubbe » Sat Apr 24, 2021 5:41 pm
does not work. Same error, also because it is not a compilation error, it is an error of the executable.
Stickly
Post by Stickly » Sat Jul 24, 2021 9:28 pm
Hi giubbe, I was having a similar problem getting NO_ANSWEER_FROM_MAKEMKVCON. MakeMKV would work fine on a fresh linux install but after a while i would start getting a NO_ANSWEER_FROM_MAKEMKVCON. It took me a while to figure out what was causing it, but it turns out it was my anti-virus software causing a conflict with makemkv. I was running eset-nod32 after uninstalling the anti-virus makemkv started working again. i'm not saying you are running anti-virus software but it could just be some other piece of software you've installed that creating problems. have you tried makemkv on a fresh linux install?
giubbe
Post by giubbe » Wed Jul 28, 2021 7:04 pm
Hi Sticly,
It is true, it is the same for me. Thank you! I use eset nod32 as an antivirus. Without antivirus makemkv works perfectly
Have you solved it? Otherwise I try to ask Eset.
Thank you very much!
Stickly
Re: No_Answer_from_makemkvcon [solved]
Post by Stickly » Fri Jul 30, 2021 5:09 am
guibee, i was looking for a way to pm you this are it's moving a little off topic but i doubt contacting eset would do much good in therms of fixing anything to do with eset nod32 v4 as it's being phased out over the next year or 2. Read this thread from their forum for more info https://forum.eset.com/topic/26944-nod3 ... 28433_menu
tomas3
Post by tomas3 » Wed Sep 08, 2021 1:07 am
Had same error with Eset installed.
Flatpak version worked while PPA did not.
