Sorry for bad English.
I downloaded the version 1.16.3 and it compiles without errors.
But when I start the program, the makemkvcon crashes and Makemkv presents the error No_Answer_from_makemkvcon
Version 1.14.7 works normally.
OS: Ubuntu 18.04.5 LTS x86_64
Kernel: 5.4.0-70-generic
Shell: bash 4.4.20
Resolution: 1920x1200, 3840x2160 (two monitor)
DE: KDE
WM: KWin
Theme: Breeze [KDE], Breeze [GTK3]
Icons: Yosa-Max [KDE], Breeze [GTK3]
Terminal: konsole
CPU: AMD Ryzen 7 2700X (16) @ 3.700GHz
GPU: NVIDIA GeForce GTX 1070
Memory: 9504MiB / 15969MiB
what can it be?
thanks
No_Answer_from_makemkvcon [solved]
Re: No_Answer_from_makemkvcon
Can you add some screenshots?
I can show only one image, as mentioned the program does not start.
![Image](https://i.postimg.cc/KvB03kjM/makemkv1.png)
does not work. Same error, also because it is not a compilation error, it is an error of the executable.
Hi giubbe, I was having a similar problem getting NO_ANSWEER_FROM_MAKEMKVCON. MakeMKV would work fine on a fresh linux install but after a while i would start getting a NO_ANSWEER_FROM_MAKEMKVCON. It took me a while to figure out what was causing it, but it turns out it was my anti-virus software causing a conflict with makemkv. I was running eset-nod32 after uninstalling the anti-virus makemkv started working again. i'm not saying you are running anti-virus software but it could just be some other piece of software you've installed that creating problems. have you tried makemkv on a fresh linux install?
Hi Sticly,
It is true, it is the same for me. Thank you! I use eset nod32 as an antivirus. Without antivirus makemkv works perfectly
Have you solved it? Otherwise I try to ask Eset.
Thank you very much!
Re: No_Answer_from_makemkvcon [solved]
guibee, i was looking for a way to pm you this are it's moving a little off topic but i doubt contacting eset would do much good in therms of fixing anything to do with eset nod32 v4 as it's being phased out over the next year or 2. Read this thread from their forum for more info https://forum.eset.com/topic/26944-nod3 ... 28433_menu
Had same error with Eset installed.
Flatpak version worked while PPA did not.
