Any way to run a command line to force this problem DVD to be read successfully?
I'm trying to rip the first and largest title from The Dean Martin Celebrity Roasts Complete Collection disc #7 (publisher disc ID 30439-X) for my own collection so I don't put any wear on my DVDs.
All discs up to the first title on disc #7 (and the rest of disc #7) have so far been ripped with no issues.
This is the first problem I ran into with this series, brand new out of the box, never opened.
The 1st title cannot be ripped by MakeMKV on two different Blu-Ray/DVD drives.
Titles 2 through 10 on this same disc, no problem at all.
Information when opening disc manually (I only include info on the one title I'm trying to rip).
Disc Information
Label : DEAN_MARTIN_ROASTS_D7
Titles count : 10
Title information
1: 1/1 - 47 chapter(s) 1:55:51 49 cell(s)
Source size (of Title 1 above): 4803.4 M
Always rips up to 1777.4 M (37% of the way through Title 1) and fails.
Log is below:
Open DVD manually : "1"
Cells 49-end were skipped due to cell commands (structure protection?)
Title #1 was added (48 cell(s), 1:55:29)
Title #1/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..022ED3C0..00C04 to device 'SPTI:\Device\CdRom0'
Saving 1 titles into directory C:/Users/PENGUIN/Videos/MakeMKV/Dean Martin Celebrity Roasts--The Complete Collection using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
DEBUG: Code 0 at &wOh_.+E)Z'ysj'nN:213130237
DEBUG: Code 0 at X2*S=quXQAT`[?@-MidaB:121262233
DEBUG: Code 0 at X2*S=quXQAT`[?@-MidaB:121261635
DEBUG: Code 0 at _F=TJ=?~\M53F{GL3/=:213131042
DEBUG: Code 0 at 72t4l!{# {tPL( wM](m9:213130559
DEBUG: Code 0 at (Ozlj5a8<WCZ~:q8:121264579
DEBUG: Code 0 at 3^I}\]5zSt1@'wRY|:h4:121261773
DEBUG: Code 1 at 4j8sikbee]wQ/+$W:213132537
DEBUG: Code 0 at &laO~GKEY~}UeZMm)C%fM:213137068
DEBUG: Code 20 at (Ozlj5a8<WCZ~:q8:213131732
DEBUG: Code 0 at (Ozlj5a8<WCZ~:q8:213133066
DEBUG: Code 0 at X2*S=quXQAT`[?@-MidaB:213129984
Failed to save title 0 to file C:/Users/PENGUIN/Videos/MakeMKV/Dean Martin Celebrity Roasts--The Complete Collection/title_t00.mkv
0 titles saved, 1 failed
particular DVD title fails at about 1777MB (included -disc and -tree output from DiscInfo.bat)
- DEAN_MARTIN_ROASTS_D7-tree.txt
- (14.91 KiB) Downloaded 512 times
- DEAN_MARTIN_ROASTS_D7-disc.txt
- (1.41 KiB) Downloaded 535 times
Re: particular DVD title fails at about 1777MB (included -disc and -tree output from DiscInfo.bat)
I may have turned the corner on this.
It's possible even though the disc was brand new that there could have been a nearly undetectable film on it that was enough to interfere with the first title, even though the other nine titles read properly.
It's also possible there was an issue with the external blu-ray drive needing to be air dusted.
Despite other configuration options tried yesterday (including setting read retry count to 99 and changing protection removal method, those seemed not to help whatsoever.
It seemed to be a combination of merely polishing the disc (using circular motion I discovered and reasoned was better than wiping by spinning the disc while pinching with cloth in other hand) and blowing out the external drive.
Anyway, it got through the first title completely. In fact it divided the first title into four separate chapters when I used manual read option (tried but failed yesterday exactly the same as a normal rip) but that's OK.
In fact I found the 1st chapter of the 1st title was 1778 M which was barely larger than where it used to fail yesterday. That explains why manual read produced 4 chapters from title 1 instead of just trying to produce one full title.
I suspect it could not see the first chapter boundary in manual read and didn't bother trying to go any further in telling me about separate chapters.
Data from MakeMKV for this successful attempt was much different (next try will be normal mode where the four separate chapters should produce one title as expected):
MakeMKV v1.16.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\PENGUIN/MakeMKV_log.txt
Fake cells occupy 34% of the title - assuming fake title
Cells 20-20 were removed from title end
Title #2 was added (19 cell(s), 0:49:14)
Cells 1-1 were removed from title start
Cells 14-14 were removed from title end
Title #3 was added (12 cell(s), 0:26:24)
Cells 12-12 were removed from title end
Title #4 was added (11 cell(s), 0:29:12)
CellTrim algorithm failed since title has only 4 chapters
DEBUG: Code 0 at KGzc**/C_:Xog4WZ];:121273894
Title #5 (0:35:34) was skipped due to navigation error
CellTrim algorithm failed since title has only 3 chapters
Title #6 (0:22:16) was skipped due to navigation error
Title #7 (0:17:28) was skipped due to navigation error
CellTrim algorithm failed since title has only 2 chapters
Title #8 (0:08:23) was skipped due to navigation error
Title #9 (0:07:39) was skipped due to navigation error
Cells 5-5 were removed from title end
Title #10 was added (4 cell(s), 0:10:37)
Saving 4 titles into directory C:/Users/PENGUIN/Videos/MakeMKV/Dean Martin Celebrity Roasts--The Complete Collection using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
AV synchronization issues were found in file 'C:/Users/PENGUIN/Videos/MakeMKV/Dean Martin Celebrity Roasts--The Complete Collection/title_t02.mkv' (title #3)
AV sync issue in stream 1 at 0:00:00 with duration of 160ms : 5 frame(s) dropped to reduce audio skew to -30.066ms
AV sync issue in stream 1 at 0:00:00 with duration of 30.066ms : audio gap was filled with silence
4 titles saved
4 titles saved
No dice...where I was able to use manual mode earlier which chopped title 1 into 4 chapters (maybe sections is a better word)...it died at 1777.2 again after attempting rip of title 1 in normal mode:
When it treats the title as a whole unit it has a problem.
When it knows about separate chapters or sections in the title, then it's OK.
Now I just have to figure out how to use manual mode to glue the 4 chapters (or maybe sections of title 1 is a better description) into one title, then I'm done.
Here's the output from the failed normal (non-manual) mode attempt:
Cells 20-end were skipped due to cell commands (structure protection?)
Title #2/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Title #3 was added (13 cell(s), 0:26:25)
Cells 12-end were skipped due to cell commands (structure protection?)
Title #4/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Cells 4-end were skipped due to cell commands (structure protection?)
Title #5 was added (3 cell(s), 0:35:32)
Title #5/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #6 was added (2 cell(s), 0:22:14)
Title #6/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Title #7 was added (2 cell(s), 0:17:26)
Title #7/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #8 was added (1 cell(s), 0:08:22)
Title #8/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:07:38)
Title #9/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
Cells 5-end were skipped due to cell commands (structure protection?)
Title #10/0/1 has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
