See my reply above about using 10,000 nits. The lower you go, the flatter and less “HDR-Like” the image gets. I noticed once you get down to about 600-800 nits and below the image is way too flat and lifeless. 1,000 is about as low as I’ll go.Manixx2020beyound wrote:Yes, but this custom block sinc to the tv maxHarperVision wrote: ↑Wed Jul 28, 2021 1:24 amDid you see my updated information in my post? Did anyone use custom DV data block info? Also the tone Mapping (compression) as I said could easily have been the cause for these anomalies because when you do player led you have to manually tell the player what the specs are for the display, unlike TV led which gets the raw info from the player and then uses it’s already known specs internally to do the processing.
It doesn’t sound like Vincent did any of this.
Values cx so yes it’s tone mapping to the CX
Edid sinc,
I can also do it without CX tx0 sinc & check the results.
Or no tv connected but 3000nit monitor and send the correct dv meta
Test it with 10,000 nits and tell me what you get and see. I’d love to know what your Atomos shows. I was thinking of getting one myself! A lot of it could have to do with what the display’s characteristics add to it though. My experiences are with a BenQ LK990 and Samsung LSP9T so far. Others like the JVCs act a little differently from what I read.
