#5206 Post by RESET_9999 » Mon Jul 26, 2021 3:27 pm
ragico wrote:
Mon Jul 26, 2021 1:16 pm
Trying and got MPC-be follow your advise and found 39 frames difference between the movies .(Star wars- A new hope)
Now what will be the JSON script for this? And what extension this file must have?
Thanks again for your patience with me.
the extension for a json file is....... .json :)
open notepad++ and copy/paste the script. go to language / J and select json
this will remove 39 frames at the start and should add 39 after the last frame (adjust the source and offset if it doesnt):
    "remove": [
        "0-38"
    "duplicate": [
            "source": 179350,
            "offset": 179350,
            "length": 39
@manix and I are doing more comparisons. We will test more movies and I want to test another appleTV+ file to see if there's the same color difference with red and blue.
but so far, IMO it looks like the conversion is working properly because the difference is not the same from one movie/show to another. Therefore the difference must come from the p5 DV grade since the atomos shogun and vertex capture settings are always the same. I'm pretty sure the dynamic metadata (luminance) part is synced properly to the hdr10 bl.
chros
#5207 Post by chros » Mon Jul 26, 2021 6:30 pm
I'm not sure what you try to do is correct (injecting p5 RPU into hdr10 streams), and I don't even mean the color issue: it would be correct, if they would use the same mastering process for the streaming and the UHD-BD version. But I think that's not the case.
And if the UHD-BD is created in hdr10 (or hdr10+ recently) in mind, then the whole movie is graded with a static curve and the dynamic p5 rpu will modify the look the wrong way.
#5208 Post by RESET_9999 » Mon Jul 26, 2021 7:46 pm
I think most movies are graded in single deliverable HDR workflow(DV or hdr10+ or both) and HDR10/SDR are just derived(trim pass) from the HDR master. so the static BL is the same, thats why it works (perfect brightness match with p5)...
Theaters get a different grade and that make sense because of the lower luminance of PJ. But 1 grade for streaming and 1 other grade for bluray releases? sounds like a waste of time and money when you can do it in just 1 grade.
https://www.youtube.com/watch?v=dhxORqncgJE
mulucy
#5209 Post by mulucy » Mon Jul 26, 2021 11:30 pm
Excellent video! Enjoyed every second of it! Thank you for sharing it!
#5210 Post by RESET_9999 » Tue Jul 27, 2021 1:04 am
ok so we did more comparison with more content and it's clear in my mind that the conversion is done properly. Every movie we tried looks pretty much the same in p8 or p5 and they are slightly different than HDR10( LLDV bug ??).
When p5 and p8 doesnt match, it's clearly in the source. We tested another AppleTV+ title and got the same red shift as in ted lasso . Red turns orange so something is different with appletv encodes (cropping?), nothing surprising from apple though, their last two generations of appletv 4k players can't even output proper SDR color (green push) lmao. The brightness and shadow detail are the same as p5 and no brightness jump in all the samples we checked which pretty much confirms that the dynamic metadatas are correctly applied to the HDR10 BL (when synced properly of course).
p5 vs P8 vs HDR10
Mulan:
https://slow.pics/c/uxKywJ6r
https://slow.pics/c/WWu8Ysik
https://slow.pics/c/ar5Wqvqe
Onward:
https://slow.pics/c/W0fnx5TO
https://slow.pics/c/EtaiU1SV
https://slow.pics/c/PrePMVac
AppleTV+ home before dark (ignore the grey-black bars caused by the x700 with cropped content):
https://slow.pics/c/bs569a22
https://slow.pics/c/Ny8jC6GR
https://slow.pics/c/CapqIJlx
for fun, home before dark DV p5 tonemapped to SDR with movies and tv app win10 compared to madvr hdr to sdr:
https://screenshotcomparison.com/comparison/16129
AppleTV+ ted lasso:
https://slow.pics/c/8nVLCFVq
https://slow.pics/c/H6xrVpNu
https://slow.pics/c/CtyxwrRU
Batman v superman:
https://slow.pics/c/lTiFdsxj
https://slow.pics/c/IoBZjQMN
Star Wars new hope:
https://slow.pics/c/Nd423gGO
https://slow.pics/c/qA4L4HUk
https://slow.pics/c/cKSjjNSD
https://slow.pics/c/jKrPq1Vf
Image Image
mattmarsden
#5211 Post by mattmarsden » Tue Jul 27, 2021 2:02 pm
Can HDR10+ be converted to DV now?
ragico
#5212 Post by ragico » Tue Jul 27, 2021 7:26 pm
I want publicly thank @Reset_9999 for his precious help to let me understand and use the basics of this new tool
Thanks a lot also to @quietvoid whose hard work has allowed this to happen.
:D :D :D :D
agentcny
#5213 Post by agentcny » Tue Jul 27, 2021 11:24 pm
Am I missing something, or is it not possible to simply re-use an "old" x265 encode and simply inject the rpu of the uhd (makemkv)?
RPU gets generated successfully, also the inject does not abort.
... No matter what settings I try in the end the hevc only shows HDR10 in mediainfo.
#5214 Post by RESET_9999 » Tue Jul 27, 2021 11:31 pm
So I'm now even more convinced that 1, the dynamic metadata are working properly and 2 , the slight color difference with HDR10 is caused by the LLDV bug (because we can't capture tv-led)
*** appleTV files color issues is not related to this though
1- one of these sample RPU is synced properly and the other is out of sync.
you can see the brightness jump at the 4-5second mark.
https://drive.google.com/file/d/19xODV3 ... sp=sharing,
https://drive.google.com/file/d/1PepCc6 ... sp=sharing
2- Remember HDTVTEST Vincent video about tv-led vs player-led ??
well we captured the LLDV signal in PQ of the SM clip, and compared it to the HDR10 BL tonemapped in SDR. The difference is literally the same as in Vincent's video.
https://screenshotcomparison.com/comparison/16173
HarperVision
#5215 Post by HarperVision » Wed Jul 28, 2021 1:13 am
RESET_9999 wrote:So I'm now even more convinced that 1, the dynamic metadata are working properly and 2 , the slight color difference with HDR10 is caused by the LLDV bug (because we can't capture tv-led)
What I find funny and not very scientifically thorough is that he only tried one brand, Oppo I believe, and then blamed the results on LLDV instead of trying multiple sources that could do LLDV, like the Sony X800M2 to see if it was the player itself OR LLDV causing the issue. He seemed to jump to conclusions that just because the Oppo caused this, it must mean ALL LLDV sources do this. That’s not sound science based analysis!
I had the Oppo 203 and the Sony X800M2 here shortly after I was the one who discovered this LLDV trick and the Sony was clearly the better device to use for Dolby Vision on otherwise non-Dolby Vision displays and projectors. Oppo had some sort of color bug that resulted in much less saturated colors. I believed and stated at the time that it was most likely due to the same bug that caused its tone mapping to only use Rec709 color gamut even if you chose BT2020 when using its SDR/BT2020 mode. Something to do with the mediatek chip if I recall.
I bet it also has to do with him not inputting custom Dolby Vision data block info like we do now, so the player then maps the signal to the exact specs of the display and/or projector, just as it does with TV-Led. If he didn’t use the right max nits, etc. then it results in improper tone mapping, meaning compression, which could easily have been the cause of these so called “issues”!
LLDV looks absolutely stunning here in my setup using a BenQ LK990 projector, new AppleTV 4K and an HDFury Vertex2 for the LLDV EDID spoof. I just watched Army of the Dead on Netflix last night in DV on my LK990 and it was probably the single best HDR/DV experience I’ve had!!! Pure eye candy with HDR effects that I’ve not seen on a projector before!!!
#5216 Post by RESET_9999 » Wed Jul 28, 2021 1:21 am
Well, it is possible that Dolby updated their SDK on the newer players.
Our test was done on the Sony x700 which is pretty old and the result 100% matches those of Vincent. @Manix should be able to compare all his device's LLDV output but he doesnt own the Sony x800m2.
I don't know about the custom Dolby Vision data block info though.
HarperVision
#5217 Post by HarperVision » Wed Jul 28, 2021 1:24 am
Did you see my updated information in my post? Did anyone use custom DV data block info? Also the tone Mapping (compression) as I said could easily have been the cause for these anomalies because when you do player led you have to manually tell the player what the specs are for the display, unlike TV led which gets the raw info from the player and then uses it’s already known specs internally to do the processing.
It doesn’t sound like Vincent did any of this.
#5218 Post by RESET_9999 » Wed Jul 28, 2021 1:32 am
do you have a link / more info about that ?
or please tell manix which settings(DV block) exactly to use on the vertex for the Spears and Munsil video. He can capture without the limitation of his CX by using only the Atomos Shogun which has a 3000nits peak brightness and he'll be happy to test anything you wish.
#5219 Post by Manixx2020beyound » Wed Jul 28, 2021 1:36 am
Yes, but this custom block sinc to the tv max
Values cx so yes it’s tone mapping to the CX
Edid sinc,
I can also do it without CX tx0 sinc & check the results.
Or no tv connected but 3000nit monitor and send the correct dv meta
HarperVision
#5220 Post by HarperVision » Wed Jul 28, 2021 3:50 am
Have you read the dedicated threads at AVS Forum and AVForums? All the info should be in those threads. Search for user Mark Swift as he is the one who deciphered the DV Data block and then based on that, HDFury included the capability to write Custom DV Data.
Here is what the Tab looks like in the Vertex2’s GUI:
I personally use settings that no one else seems to be using or trying for some reason. Maybe they’re afraid to go so extreme or be ridiculed from others saying “that can’t work”, when it actually does AMAZINGLY WELL!!!
I use a 10,000 nit Custom HDR EDID and also the DV Data Block’s Max Luminance at 10,000 nits. This works awesome and presents the least amount of compression (tone mapping) it seems. The image is so clean and detailed and you can see every nuance in dark scenes and the specular highlights are incredible without being blown out, when paired with the right HDR curve in your display/projector. It appears to work best when watching streaming content like last night with Netflix and iTunes movies with DV are amazing. When used with Infuse app on AppleTV with ripped HDR UHD blurays is the pinnacle though. I can’t even tell they’re not native DV!
I have gone back and forth with a DV Data Block between 1,000 nits and 10,000 nits and for some content 1,000 may be better, but overall I think 10,000 wins. I’ve setup different macros to switch depending on content so it’s easy if I need to.
For extreme high nit sources like The Meg chapter 8, if I set Custom HDR/AVI Tab’s Max Luminance to 10,000 nits and the DV Data Block’s max luminance to 1,000 nits (or use Custom EDID 9 or 10 on Vertex2) then it dynamically tone maps to where there are absolutely no blown out highlights or crushed and dark blacks or low level. The details you see are astonishing. Low APL movies like Blade Runner 2049 and Arrival and The Mandalorian have awesome low level details and brightness, which many complain are too dark.
