chros
#5191 Post by chros » Sun Jul 25, 2021 4:04 pm
quietvoid wrote: Sun Jul 25, 2021 1:59 pmRemuxing from TS is not supported, it won't copy the Dolby Vision config. Only MP4 or straight from the bitstream works currently.
Thanks, I'll try out with the raw streams then.
RESET_9999 wrote: Sun Jul 25, 2021 2:20 pm madVR? ... the difference is NOT caused by madVR.. plus as i said, I'm seeing the same difference in tv-led...
Oh, I see, I missed that.
#5192 Post by RESET_9999 » Sun Jul 25, 2021 4:56 pm
ragico wrote: Sat Jul 24, 2021 11:45 am Hope that @quietvoid will make an easy tool to be used by ignorant people like me as @Yusesope did for his tools.
Thank you.
Perhaps this real content example will help you understand how to do it:
E.G. Disney+ movie Mulan DV web-dl metadata injected into bluray remux
1- extract HDR10 and DV hevc stream (tsmuxer, ffmpeg, mkvextract etc..)
2-
extract and convert profile 5 RPU to 8 with this command:
dovi_tool.exe -m 3 extract-rpu DV.hevc
3- Sync/edit the rpu to match the HDR10 stream.
For this movie, you have to remove 24 frames before the RPU and add 70 frames at the end
EDIT: tool updated, no more needed to match the framecount. RPU still has to start at the same frame as the bluray remux.
so the JSON file to remove 24 frames will look like this
    "remove": [
        "0-23"
*** how to find the frame difference here
if you had to add 23 frames:
	"duplicate": [
			"source": 0,
			"offset": 0,
			"length": 23
4- once the JSON is done, you edit the RPU with this cmd:
dovi_tool.exe editor -i RPU.bin -j edited.json --rpu-out RPU-edited.bin
5- inject the edited RPU into the HDR10 hevc stream with this cmd:
dovi_tool.exe inject-rpu -i HDR10.hevc --rpu-in RPU-edited.bin
6- that's it, the injected_output.hevc contains Profile 8 DV metadata
File size                                : 50.9 GiB
Duration                                 : 1 h 55 min
Overall bit rate                         : 63.3 Mb/s
Video
Bit rate                                 : 58.9 Mb/s
Bits/(Pixel*Frame)                       : 0.296
Stream size                              : 47.4 GiB (93%)
Writing library                          : ATEME Titan File 3.9.6 (4.9.6.2)
Audio #1
Format                                   : MLP FBA AC-3 16-ch
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 8 742 kb/s
Stream size                              : 527 MiB (1%)
Number of dynamic objects                : 13
quietvoid
#5193 Post by quietvoid » Sun Jul 25, 2021 5:01 pm
RESET_9999 wrote: Sun Jul 25, 2021 2:58 pm@quietvoid, i was looking at the rpu and i noticed this, shouldnt the p8 file set to 0 here ?
No, even in profile 7 metadata signal_full_range_flag is always set to 1.
What might make a difference is changing both source_min_pq: 7 and source_max_pq: 3079.
Since limited (HDR10) is expected to be 62 and 3696.
RESET_9999 wrote: Sun Jul 25, 2021 2:58 pmon my end, the only way I can get a DV MKV with your p5 to p8 conversion is by using Makemkv.
raw hevc with mkvtoolnix = no DV
mp4 dv with mkvtoolnix = no DV
ts DVwith mkvtoolnix = no DV
even when I simply remux the makemkv DV file with mkvtoolnix, i still lose DV metadata.
You should be able to get Dolby Vision config when using MKVToolNix v58 or newer only.
And remuxing MakeMKV files was already copying the config a while ago..
As far as HDR10/ST2086 metadata, I will add a way to set specific values soon hopefully.
#5194 Post by RESET_9999 » Sun Jul 25, 2021 5:05 pm
quietvoid wrote: Sun Jul 25, 2021 5:01 pm You should be able to get Dolby Vision config when using MKVToolNix v58 or newer only.
yep, I have the latest version but it doesnt work with the p5 to p8 files. at least on my end.
#5195 Post by Manixx2020beyound » Sun Jul 25, 2021 6:40 pm
Bat vs sup p8 vs p5
Bat vs sup p8 vs p5
Looks very close almost identical
Uploading test files
staknhalo
#5196 Post by staknhalo » Sun Jul 25, 2021 6:54 pm
anyone have problems making a p8.1 of cloverfield from p7 with all the tools?
they all just hang and never complete or spit out a 0mb file on this movie even though they work with other movies
Edit: does anyone have the old version of dolby muxer version 1.0? maybe that's my problem with this file I can only find the current 1.0.1 to try
#5197 Post by RESET_9999 » Sun Jul 25, 2021 8:22 pm
Manixx2020beyound wrote: Sun Jul 25, 2021 6:40 pm Looks very close almost identical
looks like you have madVR dynamic clipping active for those pictures manix ...
this frame is interesting though. You can see a small green tint on the building that clearly comes from the HBO p5 (or manix dv to hdr10 settings).
p5 vs p8 vs HDR10 HBO vs HDR10 bluray:
https://slow.pics/c/lTiFdsxj
https://slow.pics/c/IoBZjQMN
ragico
#5198 Post by ragico » Sun Jul 25, 2021 9:01 pm
RESET_9999 wrote: Sun Jul 25, 2021 4:56 pm
Thank you.
1- extract both HDR10 and DV hevc stream
2-
3- Sync/edit the rpu to match the frame count of the HDR10 stream.
For this movie, you have to remove 23 frames before the RPU and add 71 frames at the end
so the JSON file would look like this:
    "remove": [
        "0-22"
    "duplicate": [
            "source": 165632,
            "offset": 165632,
            "length": 71
Video
Audio #1
Codec ID                                 : 131
Thank you for your help. Pls what is JSON and how to use it? And how I know about the frames to be removed/added etc. for a given a film?
#5199 Post by RESET_9999 » Sun Jul 25, 2021 9:48 pm
the json file is a simple text file in which you copy/paste the script of step 3. ( you change the number according to the movies you're syncing)
first, you have to find the frame difference between the two videos. Personally, I use MPC-BE and find the same frame for both videos, press ''control-g'' and calculate the frame number difference. You can navigate frame by frame with ''control left/right arrow'' when the video is paused.
Another method that could be easier for you is to open both videos with staxrip ''video comparison'' (tool/advanced) and navigate to the same frame.
I prefer mpc because you don't have to load the video like you have to do with staxrip. if your pc/gpu is powerful enough you could open two instances of MPC.
then the framecount of both rpu and hdr10 video must match. so you calculate how many frames you have to remove or add at the end of the rpu. (include the frame you added or removed from the start of the rpu) ... just math at this point.
EDIT: it is no more needed to calculate the framecount since the latest update. You only need to calculate the frame difference so the rpu is in sync with the bluray remux.
this is the json for SOUL
ragico
#5200 Post by ragico » Mon Jul 26, 2021 1:16 pm
RESET_9999 wrote: Sun Jul 25, 2021 9:48 pm the json file is a simple text file in which you copy/paste the script of step 3. ( you change the number according to the movies you're syncing)
then for the frame at the end, the framecount of both rpu and hdr10 video must match. so you find out the total number of frames and you match it with the dv video (include the frame you added or removed from the start) ... just math at this point.
hope you understand, I'm not very good at explaining things
Trying and got MPC-be follow your advise and found 39 frames difference between the movies .(Star wars- A new hope)
Now what will be the JSON script for this? And what extension this file must have?
Thanks again for your patience with me.
#5201 Post by RESET_9999 » Mon Jul 26, 2021 3:27 pm
ragico wrote: Mon Jul 26, 2021 1:16 pm Trying and got MPC-be follow your advise and found 39 frames difference between the movies .(Star wars- A new hope)
the extension for a json file is....... .json :)
open notepad++ and copy/paste the script. go to language / J and select json
this will remove 39 frames at the start and should add 39 after the last frame (adjust the source and offset if it doesnt):
    "remove": [
        "0-38"
    "duplicate": [
            "source": 179350,
            "offset": 179350,
            "length": 39
@manix and I are doing more comparisons. We will test more movies and I want to test another appleTV+ file to see if there's the same color difference with red and blue.
but so far, IMO it looks like the conversion is working properly because the difference is not the same from one movie/show to another. Therefore the difference must come from the p5 DV grade since the atomos shogun and vertex capture settings are always the same. I'm pretty sure the dynamic metadata (luminance) part is synced properly to the hdr10 bl.
chros
#5202 Post by chros » Mon Jul 26, 2021 6:30 pm
I'm not sure what you try to do is correct (injecting p5 RPU into hdr10 streams), and I don't even mean the color issue: it would be correct, if they would use the same mastering process for the streaming and the UHD-BD version. But I think that's not the case.
And if the UHD-BD is created in hdr10 (or hdr10+ recently) in mind, then the whole movie is graded with a static curve and the dynamic p5 rpu will modify the look the wrong way.
#5203 Post by RESET_9999 » Mon Jul 26, 2021 7:46 pm
chros wrote: Mon Jul 26, 2021 6:30 pm I'm not sure what you try to do is correct (injecting p5 RPU into hdr10 streams), and I don't even mean the color issue: it would be correct, if they would use the same mastering process for the streaming and the UHD-BD version. But I think that's not the case.
I think most movies are graded in single deliverable HDR workflow(DV or hdr10+ or both) and HDR10/SDR are just derived(trim pass) from the HDR master. so the static BL is the same, thats why it works (perfect brightness match with p5)...
Theaters get a different grade and that make sense because of the lower luminance of PJ. But 1 grade for streaming and 1 other grade for bluray releases? sounds like a waste of time and money when you can do it in just 1 grade.
https://www.youtube.com/watch?v=dhxORqncgJE
mulucy
#5204 Post by mulucy » Mon Jul 26, 2021 11:30 pm
RESET_9999 wrote: Mon Jul 26, 2021 7:46 pm
Excellent video! Enjoyed every second of it! Thank you for sharing it!
#5205 Post by RESET_9999 » Tue Jul 27, 2021 1:04 am
ok so we did more comparison with more content and it's clear in my mind that the conversion is done properly. Every movie we tried looks pretty much the same in p8 or p5 and they are slightly different than HDR10( LLDV bug ??).
When p5 and p8 doesnt match, it's clearly in the source. We tested another AppleTV+ title and got the same red shift as in ted lasso . Red turns orange so something is different with appletv encodes (cropping?), nothing surprising from apple though, their last two generations of appletv 4k players can't even output proper SDR color (green push) lmao. The brightness and shadow detail are the same as p5 and no brightness jump in all the samples we checked which pretty much confirms that the dynamic metadatas are correctly applied to the HDR10 BL (when synced properly of course).
p5 vs P8 vs HDR10
Mulan:
https://slow.pics/c/uxKywJ6r
https://slow.pics/c/WWu8Ysik
https://slow.pics/c/ar5Wqvqe
Onward:
https://slow.pics/c/W0fnx5TO
https://slow.pics/c/EtaiU1SV
https://slow.pics/c/PrePMVac
AppleTV+ home before dark (ignore the grey-black bars caused by the x700 with cropped content):
https://slow.pics/c/bs569a22
https://slow.pics/c/Ny8jC6GR
https://slow.pics/c/CapqIJlx
for fun, home before dark DV p5 tonemapped to SDR with movies and tv app win10 compared to madvr hdr to sdr:
https://screenshotcomparison.com/comparison/16129
AppleTV+ ted lasso:
https://slow.pics/c/8nVLCFVq
https://slow.pics/c/H6xrVpNu
https://slow.pics/c/CtyxwrRU
Batman v superman:
Star Wars new hope:
https://slow.pics/c/Nd423gGO
https://slow.pics/c/qA4L4HUk
https://slow.pics/c/cKSjjNSD
https://slow.pics/c/jKrPq1Vf
Image Image
