one more comparison...
p5 vs p8 vs HDR10: https://slow.pics/c/e1ssuSEG
I thought maybe the LLDV bug was acting up here but nop, I get a similar difference in tv-led: https://screenshotcomparison.com/comparison/16090
here are the clips if you want to check them yourself:
https://drive.google.com/file/d/1Lh7zmo ... sp=sharing,
https://drive.google.com/file/d/1Oqkvmz ... sp=sharing
but as you say, hard to tell if its the source or the conversion
chros
Post by chros »
quietvoid wrote:
Sat Jul 24, 2021 6:58 pm
chros wrote:
Sat Jul 24, 2021 6:31 pm
This must be it then, can you share your apk? Thanks
I'm not sure if it's going to be a different package, so backup first..
https://mega.nz/file/MdETXSAR#vPtlIY-nm ... NcRsZLlTyk
Thanks, the .ts file plays back as DoVi with your Kodi build (it's installed as a separate package). (The mkv that I created by dragging the .ts file into recent mkvtoolnix still plays back as hdr10.)
And indeed there's no banding/posterization, so my theory was wrong: Firestick 4k also triggers tv-led DoVi with our 2018 LG.
(That's a different thing that FireOS screwed up audio passthrough from external apps (not streaming ones) completely, and I have occasional stutter with high bitrate streaming profile 5 mp4 files :) )
chros
Post by chros »
RESET_9999 wrote:
Sun Jul 25, 2021 4:48 am
Or madvr? :)
quietvoid
Post by quietvoid »
chros wrote:
Sun Jul 25, 2021 10:43 am
Remuxing from TS is not supported, it won't copy the Dolby Vision config. Only MP4 or straight from the bitstream works currently.
Thanks, I'll try to see if I can get anything different by playing with the metadata.
chros wrote:
Sun Jul 25, 2021 10:51 am
Or madvr? :)
madVR?
exactly the same static settings were used and dynamic tone mapping was disabled. the difference is NOT caused by madVR.. plus as i said, I'm seeing the same difference in tv-led...
PQ comparison, no madvr involved: https://slow.pics/c/qZ8YCaN2
Post by Manixx2020beyound »
quietvoid wrote:
Sun Jul 25, 2021 1:59 pm
So Im wondering the p5 funky colors are not created in post only the final stages of doblyvision encoding
While pulling from the doblyvision 12bit master & xml data simultaneously true SDI
To create a profile 5 FULL color & Rpu
To my knowledge the 12bit master is not in done in doblyvision itcp protocol
& I’m sure the color conversion from 12bit master to p5 produces similar differences form the 12bit master as well.
We should test more uhd p8 conversion
To see what the consistency in the results are,
So far I like the hybrid p8 look, I don’t know how u guys feel about it seems to minus some of doblyvision flaws from their original proces
Last edited by Manixx2020beyound on Sun Jul 25, 2021 3:50 pm, edited 5 times in total.
also, it looks like the weird lines (ringing???)mostly in the blue are caused by profile 5 DV decoding because I can see them in TV-LED DV as well while the p8 DV is clean like HDR10.
they dont seem to be present in the p5 source:
p5 clip, no capture no tonemapping VS p8 capture , no tonemapping: https://slow.pics/c/x0YGLSYn
there is also the metadata that are different in the RPU and the BL:
Manixx2020beyound wrote:
Sun Jul 25, 2021 2:34 pm
i agree
@quietvoid, i was looking at the rpu and i noticed this, shouldnt the p8 file set to 0 here ?
on my end, the only way I can get a DV MKV with your p5 to p8 conversion is by using Makemkv.
raw hevc with mkvtoolnix = no DV
mp4 dv with mkvtoolnix = no DV
ts DVwith mkvtoolnix = no DV
even when I simply remux the makemkv DV file with mkvtoolnix, i still lose DV metadata.
chros
Post by chros »
Thanks, I'll try out with the raw streams then.
RESET_9999 wrote:
Sun Jul 25, 2021 2:20 pm
madVR? ... the difference is NOT caused by madVR.. plus as i said, I'm seeing the same difference in tv-led...
Oh, I see, I missed that.
ragico wrote:
Sat Jul 24, 2021 11:45 am
Hope that @quietvoid will make an easy tool to be used by ignorant people like me as @Yusesope did for his tools.
Thank you.
Perhaps this real content example will help you understand how to do it:
E.G. Disney+ movie Mulan DV web-dl metadata injected into bluray remux
1- extract HDR10 and DV hevc stream (tsmuxer, ffmpeg, mkvextract etc..)
2-
extract and convert profile 5 RPU to 8 with this command:
dovi_tool.exe -m 3 extract-rpu DV.hevc
3- Sync/edit the rpu to match the HDR10 stream.
For this movie, you have to remove 24 frames before the RPU and add 70 frames at the end
EDIT: tool updated, no more needed to match the framecount. RPU still has to start at the same frame as the bluray remux.
so the JSON file to remove 24 frames will look like this
    "remove": [
        "0-23"
*** how to find the frame difference here
if you had to add 23 frames:
	"duplicate": [
			"source": 0,
			"offset": 0,
			"length": 23
4- once the JSON is done, you edit the RPU with this cmd:
dovi_tool.exe editor -i RPU.bin -j edited.json --rpu-out RPU-edited.bin
5- inject the edited RPU into the HDR10 hevc stream with this cmd:
dovi_tool.exe inject-rpu -i HDR10.hevc --rpu-in RPU-edited.bin
6- that's it, the injected_output.hevc contains Profile 8 DV metadata
File size                                : 50.9 GiB
Duration                                 : 1 h 55 min
Overall bit rate                         : 63.3 Mb/s
Video
Bit rate                                 : 58.9 Mb/s
Bits/(Pixel*Frame)                       : 0.296
Stream size                              : 47.4 GiB (93%)
Writing library                          : ATEME Titan File 3.9.6 (4.9.6.2)
Audio #1
Format                                   : MLP FBA AC-3 16-ch
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 8 742 kb/s
Stream size                              : 527 MiB (1%)
Number of dynamic objects                : 13
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Sun Jul 25, 2021 2:58 pm
No, even in profile 7 metadata signal_full_range_flag is always set to 1.
What might make a difference is changing both source_min_pq: 7 and source_max_pq: 3079.
Since limited (HDR10) is expected to be 62 and 3696.
You should be able to get Dolby Vision config when using MKVToolNix v58 or newer only.
And remuxing MakeMKV files was already copying the config a while ago..
As far as HDR10/ST2086 metadata, I will add a way to set specific values soon hopefully.
quietvoid wrote:
Sun Jul 25, 2021 5:01 pm
yep, I have the latest version but it doesnt work with the p5 to p8 files. at least on my end.
Bat vs sup p8 vs p5
Bat vs sup p8 vs p5
Looks very close almost identical
Uploading test files
staknhalo
Post by staknhalo »
anyone have problems making a p8.1 of cloverfield from p7 with all the tools?
they all just hang and never complete or spit out a 0mb file on this movie even though they work with other movies
Edit: does anyone have the old version of dolby muxer version 1.0? maybe that's my problem with this file I can only find the current 1.0.1 to try
Sun Jul 25, 2021 6:40 pm
looks like you have madVR dynamic clipping active for those pictures manix ...
this frame is interesting though. You can see a small green tint on the building that clearly comes from the HBO p5 (or manix dv to hdr10 settings).
p5 vs p8 vs HDR10 HBO vs HDR10 bluray:
https://slow.pics/c/lTiFdsxj
https://slow.pics/c/IoBZjQMN
ragico
Post by ragico »
RESET_9999 wrote:
Sun Jul 25, 2021 4:56 pm
Thank you.
1- extract both HDR10 and DV hevc stream
2-
3- Sync/edit the rpu to match the frame count of the HDR10 stream.
For this movie, you have to remove 23 frames before the RPU and add 71 frames at the end
so the JSON file would look like this:
    "remove": [
        "0-22"
    "duplicate": [
            "source": 165632,
            "offset": 165632,
            "length": 71
Video
Audio #1
Codec ID                                 : 131
Thank you for your help. Pls what is JSON and how to use it? And how I know about the frames to be removed/added etc. for a given a film?
