NGS428
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by NGS428 »
MartyMcNuts wrote: Sun Jun 27, 2021 11:58 pm
NGS428 wrote: Sun Jun 27, 2021 2:45 pm
MartyMcNuts wrote: Sun Jun 27, 2021 3:34 am I think you misread. The recommended firmware for your drive is WH16NS60 1.02-MK, not NS40.
Yes, you use enc the first time you flash and yes, the Unitek 1039 should work just fine.
Marty, thanks for the reply. I see that now in the first post. I assumed that info may have not been updated since when I downloaded the MK firmware pack, "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" was located in the "old" folder.
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin is in the current "WH16NS60" folder.
And the WH16NS60 and the WH14NS40 are the same drive, just different firmware? Just curious how I can flash one to the other.
No, WH16NS60 1.02-MK is the recommended firmware. 1.03 is crap.
No, they share most of the hardware it is just the NS60 is an official UHD drive (and has an AACS 2 chip) but the firmware reads faster and removes the sleep bug.
Thanks Marty! Super easy to flash with your flasher tool. Thanks for all you do!
Also, if you want to, you can add the "Unitek Y-1039" to the first post. It worked just fine.
Product: BD-RE WH16NS60
Revision: 1.02
Highest AACS version: 68
Firmware version: 1.02
fiod3s
Post by fiod3s »
I've already successfully flashed a HL-DT-ST BU40N 1.04 with the original firmware DE_LG_BU40N_1.00 so thanks for this valuable guide and the tools as well.
Now I've got the following
Product: BD-RE BU40N
Revision: FR07
Serial number: XXXXXXXXXXX
Firmware date: 2119-05-10 13:48
Bus encryption flags: 1F
Highest AACS version: 76
The surprise is the firmware date which isn't 2118-01-22 15:36 as expected.
Why? What's the differences? Is that encoded?
Any advice?
russelms
Post by russelms »
Well I went and screwed my drive I believe. It is a WH16NS40 NS50 Manufactered in 2016 and was running 1.02 unpatched.
I tried SDF tool but it would always fail with an error, so then I tried the Blackened2687 unlocked flasher to flash to the WH16NS60 1.02 MK and it failed with a 4//something error.
Now undetectable by MakeMKV but in windows it still shows in device manager but is unable to power-up (something like that).
Is DOS flashing an option to recover?
MrRom92
Post by MrRom92 »
d00zah wrote: Sun Jul 04, 2021 11:04 am The last 2 posters reference, had you carefully read the 1st post in this thread (Billycar11 works diligently to keep it current) , starting from encrypted FWs. This requires flashing w/ either Mike's command line tool, or the SDFtool Flasher, w/ the 'enc' option selected.
Hello, I’ve read it carefully - several times over in fact - but it is still not the easiest thing to follow. Sorry to trouble you :) I am still not quite understanding the difference between FWs 1.00 & 1.02MK for the WH16NS60, or which is better/why, but as I’ve already successfully flashed to 1.00 I suppose I can just stay on this FW if I don’t experience any issues.
Post by d00zah »
MrRom92 wrote: Thu Jul 15, 2021 8:01 am
The only difference I am aware of is that v1,0 FW is unpatched, & is supported by AnyDVD... which is really only important if you also use AnyDVD & it stopped working after you flashed the drive. As FW releases are no longer accompanied by a change log, any other differences are speculative, & perhaps subjective.
The bottom line is "Does it work for you"? As an old engineer, I'm often vexed by this FOMO driven world. :D
MrRom92
Post by MrRom92 »
d00zah wrote: Thu Jul 15, 2021 2:31 pm
Well it at least appears to be working and ripping UHDs so I take it that I’m set! thank you :) I just had an issue ripping/burning a copy of a standard BD but I am presuming it’s unrelated to all of this drive flashing UHD stuff
Post by d00zah »
MrRom92 wrote: Fri Jul 16, 2021 3:10 pm I just had an issue ripping/burning a copy of a standard BD but I am presuming it’s unrelated to all of this drive flashing UHD stuff
For the most part, correct. Once MakeMKV reports LibreDrive is enabled, the primary benefit for BD is w/ AACS. Everything else should just be general stuff related to optical media.
earlymorningmarch
Post by earlymorningmarch »
BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
Is there a reason why we are using 1.02MK when there is only 1.05MK in the MK Firmware pack?
viewtopic.php?f=19&t=19113
Are there firmware versions where it is better/worse for certain task/ software?
earlymorningmarch wrote: Sat Jul 24, 2021 6:55 am
Yes because it's faster, has no sleep bug and causes less confusion because it's not encrypted
It's in the all you need firmware pack
KentaZX
Post by KentaZX »
Okay my WH16NS40 drive stopped working in general, as in not reading ANY discs whatsoever after I made a mistake of upgrading the firmware from 1.02 to 1.05 through LG's site. I have tried to follow this guide to flash the firmware to WH16NS60 1.02MK firmware, and while it did flashed, it will STILL not read any discs at all. my I bought this drive back at 2014 too if that helps. I've also tried using the W1H16NS60 1.00, WH16NS40 1.05 again, 1.02 NS50 firmware to see if that makes a difference, using the patched downgrade flasher and then the asus modified flasher. but nothing worked at all. Is my drive screwed?
KentaZX
Post by KentaZX »
Ive been trying to follow this guide to fix my LG WH16NS40 drive since its not reading any disc anymore ever since I updated its firmware to 1.05. I tried flashing different firmwares like WH16NS60 1.00, 1.02, and 1.02MK and WH16NS40 1.05MK as well and nothing worked.
KentaZX wrote: Fri Jul 30, 2021 11:44 pm Okay my WH16NS40 drive stopped working in general, as in not reading ANY discs whatsoever after I made a mistake of upgrading the firmware from 1.02 to 1.05 through LG's site. I have tried to follow this guide to flash the firmware to WH16NS60 1.02MK firmware, and while it did flashed, it will STILL not read any discs at all. my I bought this drive back at 2014 too if that helps. I've also tried using the W1H16NS60 1.00, WH16NS40 1.05 again, 1.02 NS50 firmware to see if that makes a difference, using the patched downgrade flasher and then the asus modified flasher. but nothing worked at all. Is my drive screwed?
every thing needed to prevent this and fix this is in the first post
Billycar11 wrote: Mon May 27, 2019 5:20 am
IMPORTANT Before you flash:
1. Make sure your Drive was built after 2015 on label
2. Drive Platform MT1959<Most important in makemkv
3. SVC NS50+ LG only on label
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
https://www.youtube.com/watch?v=eXgybNfHhcg - Obsolete but can be useful for recovery
only use the recovery steps for older NS40 drives!!:
Ok here's a summary of what you need to do
Try the recovery option in sdf tool if that fails do this:
Downgrade your drive to WH16NS60 1.00 with sdftool or makemkv command line
Full shutdown pull power plug or flip switch push power button for 10 seconds
Then reflash WH16NS60 1.00 again with the unlocked lg or Asus flasher
Then boot in to your dosflash bottable and dump the firmware
Use the transfer tool to your correct firmware and flash it.
NS40 Recovery Image:
Flashed an NS50 firmware to an NS40 drive and can no longer read disks this IMG has all the NS40 FW you need to recover your drive just follow my dos flash video guide linked above
https://www.mediafire.com/file/8by2zqop ... D.zip/file Made by
KentaZX
Post by KentaZX »
Billycar11 wrote: Sat Jul 31, 2021 3:26 am
Is there no way at all to boot the dosflash in a 64-bit windows computer? Also I've checked the IMG and couldnt find any of the NS40 firmware in there, let alone my firmware.
EDIT: I just realized I could just boot into that image to open DOSFlash, but now my Drive is not being detected by dosflash at all and I cant even dump the firmware.
rblood01
Post by rblood01 »
At this point, I'd do one of two things.
1) get a different drive and try again
or
2) see if one of the experts here that do remote flashing is willing to assist you in getting this drive properly functional.
I know, from experience that this process can be confusing as I just went through it myself. Even reading the instructions and such (when finding the most current ones) can leave someone with questions. The fact that you have a problem disk after flashing firmware, makes me believe this step, which should be pretty easy and safe, isn't possible on this drive for you. Reason I suggests to see if someone with experience can remotely check, and if possible repair the drive. At least at that time, you'd have a solid reliable answer to your issue.
KentaZX
Post by KentaZX »
Okay for option 2, Do I just private message one of the experts here? IF so, who do I talk to? If not, is there some sort of a proper procedure to get some remote flashing help here?
